[petsc-users] Scaling with number of cores
TAY wee-beng zonexo at gmail.com
Sat Oct 31 11:34:44 CDT 2015
I understand that as mentioned in the faq, due to the limitations in
memory, the scaling is not linear. So, I am trying to write a proposal
to use a supercomputer.
Its specs are:
Compute nodes: 82,944 nodes (SPARC64 VIIIfx; 16GB of memory per node)
8 cores / processor
Interconnect: Tofu (6-dimensional mesh/torus) Interconnect
Each cabinet contains 96 computing nodes,
One of the requirement is to give the performance of my current code
with my current set of data, and there is a formula to calculate the
estimated parallel efficiency when using the new large set of data
There are 2 ways to give performance:
1. Strong scaling, which is defined as how the elapsed time varies with
the number of processors for a fixed
problem.
2. Weak scaling, which is defined as how the elapsed time varies with
fixed problem size per processor.
I ran my cases with 48 and 96 cores with my current cluster, giving 140
and 90 mins respectively. This is classified as strong scaling.
Cluster specs:
CPU: AMD 6234 2.4GHz
8 cores / processor (CPU)
6 CPU / node
So 48 Cores / CPU
Not sure abt the memory / node
The parallel efficiency ‘En’ for a given degree of parallelism ‘n’
indicates how much the program is
efficiently accelerated by parallel processing. ‘En’ is given by the
following formulae. Although their
derivation processes are different depending on strong and weak scaling,
derived formulae are the
same.
 From the estimated time, my parallel efficiency using Amdahl's law on
the current old cluster was 52.7%.
So is my results acceptable?
For the large data set, if using 2205 nodes (2205X8cores), my expected
parallel efficiency is only 0.5%. The proposal recommends value of > 50%.
Is it possible for this type of scaling in PETSc (>50%), when using
17640 (2205X8) cores?
Btw, I do not have access to the system.
Sent using CloudMagic Email
<https://cloudmagic.com/k/d/mailapp?ct=pa&cv=7.4.10&pv=5.0.2&source=email_footer_2>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151101/b4068fc4/attachment.html>
