[petsc-users] DM question.
Afanasiev Michael michael.afanasiev at erdw.ethz.ch
Mon Oct 26 12:15:13 CDT 2015
Hi Matt,
Re: a chat with Dave, I’ve constructed a minimal working example of the problem here: https://github.com/michael-afanasiev/salvus2. The relevant stuff is in example/main.c. There’s a little note in there detailing what we’d like to accomplish. It should compile fine with a quick modification of the CMakeLists to tell the makefile where your petsc is. This is all detailed in the Readme, and there’s a small test exodus file hanging out in there as well. A hint would be great.
Best,
Mike.
Michael Afanasiev
Ph.D. Candidate
Computational Seismology
Institut für Geophysik
ETH Zürich
Sonneggstrasse 5, NO H 39.2
CH 8092 Zürich
michael.afanasiev at erdw.ethz.ch<mailto:michael.afanasiev at erdw.ethz.ch>
On Oct 26, 2015, at 12:52 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Mon, Oct 26, 2015 at 6:45 AM, Afanasiev Michael <michael.afanasiev at erdw.ethz.ch<mailto:michael.afanasiev at erdw.ethz.ch>> wrote:
Hi Matthew,
No. There are (k-1)^2 unknowns in the interior of the cell, so that we have
  4 + 4 * (k-1) + (k-1)^2 = (k+1)^2
Right, makes sense. With some insight from Dave, I’m getting what I expect for a simple 4-cell mesh distributed amongst 4 processors (length of 91 for the global vector, length of 25 for the local vectors, for 4th order polynomial and the GLL basis). Now I imagine what’s left is to figure out how these vectors are globally numbered.
I usually do this by having a consistent way of numbering the dofs on the reference element (i.e. given a (u, v)-space loop through v, then u), and then getting the local->global map via finding coincident points in a kd-tree. My question is: in which order are the local vectors now defined? If I knew this, I could create my local->global map as before. From the way the section was created, I guess it might be something like loop vertices, edges, and then interior?
The numbering is cell unknowns, vertex unknowns, face unknowns, and then edge unknowns. This is, of course, arbitrary and therefore
you can change the order using
  http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/PetscSectionSetPermutation.html#PetscSectionSetPermutation
which renumbers all the mesh points in the PetscSection defining the space. You should be able to reproduce your old ordering using
this.
    Matt
Thanks for all your help,
Mike.
Michael Afanasiev
Ph.D. Candidate
ETH Zürich
CH 8092 Zürich
On Oct 23, 2015, at 5:11 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Oct 23, 2015 at 9:03 AM, Afanasiev Michael <michael.afanasiev at erdw.ethz.ch<mailto:michael.afanasiev at erdw.ethz.ch>> wrote:
Hi Matthew,
Yes, however I have some questions. Starting out, I think the GLL points include the endpoints, so
that means for polynomial degree k that numDof[] should really have 4*1 dofs on each vertex,
4*(k-1) dofs on each edge, and 4*(k-1)^2 on each quad. It looks like below you have numDof[] for
a 1D mesh with DG element.
For the GLL basis we have (k+1) points in each dimension, including the endpoints. So for example a 2D element with 4-order polynomials will have 25 locally numbered points per element. I should also mention that the velocity, displacement, and acceleration fields are vectors, with d=dim components at each integration point, whereas strain has (2^dim)-1 components. In what you’ve written above, does this then become (sum over the 4 fields):
(sum(compPerField*dofPerField)) -> vertex
(sum((compPerField*dofPerField)*(k+1)) -> edge
(sum((compPerField*dofPerField)*(k+1)^2) -> quad
With elements like these, it is common (I think) to eliminate the cell unknown explicitly, since the
system is dense and not connected to other cells. For this, you would retain the vertex and edge
unknowns, but not the cell unknowns. I have not tried to do this myself, so I do not know if there
are any pitfalls.
I believe I don’t worry about this. Everything is solved in a matrix-free sense, on each element. The relevant physical quantities are calculated on each element, and then summed into the global degrees of freedom. The summed global dof are then brought back to the element level, where updates to the acceleration, velocity, and displacement are calculated via a Newmark time step. So no global system of equations is ever formed.
You accumulate into the global dofs, so you would need more storage if you do not do static condensation. It just good to know this,
but you do not have to do it.
This being said, all the routines to a) integrate the element matrices, b) calculate the gll point locations, c) construct the local->global dof mapping, and d) do the element-wise matrix free time stepping are already written.  My problem is really that I do my mesh decomposition by hand (poorly), and I’d like to transfer this over to Petsc. Of course if I do this, I might as well use DM's LocalToGlobal vector routines to sum my field vectors across mesh partitions.
Yes.
Perhaps a better question to ask would be in the form of a workflow:
1) Read in exodus mesh and partition (done)
2) Set up local and global degrees of freedom on each mesh partition (done)
Here you just have to setup PetscSections that mirror your local and global layout. Then the LocalToGlobal and its inverse will work.
   Matt
3) Integrate element matrices (done)
for i 1, nTimeSteps
3) Step fields forward on each partition (done)
4) Sum to global degrees of freedom on each partition (done)
5) Sum to global degrees of freedom across partitions (????)
6) Retrieve summed global degrees of freedom across partitions (????)
7) Continue
So really what I hope Petsc will help with is just steps 5 and 6. I guess this involves, given a partitioned DMPlex object, which has been partitioned according to the geometry and topology defined in an exodus file, adding the degrees of freedom to each partition-local vector (via a DMPlexSection?). Then, ensuring that the dof added along the partition boundaries sum together properly when a LocalToGlobal vector operation is defined.
Does this make sense? If so, is this something that DMPlex is designed for?
Michael Afanasiev
Ph.D. Candidate
ETH Zürich
CH 8092 Zürich
On Oct 23, 2015, at 1:14 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Oct 23, 2015 at 3:01 AM, Afanasiev Michael <michael.afanasiev at erdw.ethz.ch<mailto:michael.afanasiev at erdw.ethz.ch>> wrote:
Hi Matthew,
So I’m discretizing via a tensor product of Lagrange polynomials co-located at the Gauss-Lobatto-Legendre (GLL) points. The polynomial order might range from 4 to 10 or something like that. The current problem is solved on 2D hexes.
I had found DMPlexCreateSection, and followed plex/ex1to get things set up. You can see my attempt below. Basically I’ve got 4 fields (displacement, velocity, acceleration, and strain) over each element. Here I’ve tried to setup a tensor product of 4th order (5 GLL points) Lagrange polynomials (line 11). This seemed to somewhat achieve what I wanted — I created a global vector and wrote it to a vtk file with VecView, and the numbering seemed to make sense. You can also see my attempt at defining a boundary condition (it looked like DMPlexCreateFromExodus labeled side sets as “Face Sets”, seems to have worked).
Does this seem to be headed in the right direction?
The "Face Sets" is the right label to use for boundary conditions. This will eliminate those variables
from the global system, but they will be present in the local spaces.
are any pitfalls.
You can see an example of a similar implementation specifically for the kind of spectral elements
you are considering here: https://github.com/jedbrown/dohp. It would probably be useful to understand
what is done there as you implement.
     Matt
Cheers,
Mike.
DM
mesh::createSection(const DM &dm)
01        // displacement, velocity, acceleration, strain
02        IS bcPointIs[1];
03        PetscInt numBc = 1;
04        PetscInt bcField[1];
05        PetscInt numFields = 4;
06        PetscInt dim; DMGetDimension(dm, &dim);
07        PetscInt numComp[numFields];
08        for (auto i=0; i<numFields; i++) {numComp[i] = dim;}
09        PetscInt numDof[numFields*(dim+1)];
10        for (auto i=0; i<numFields*(dim+1); i++) {numDof[i] = 0;}
11        for (auto i=0; i<numFields; i++) {numDof[i*(dim+1)+dim] = 5;}
12        bcField[0] = 0;
13        PetscSection section;
14        DMPlexGetStratumIS(dm, "Face Sets", 1, &bcPointIs[0]);
15        DMPlexCreateSection(dm, dim, numFields, numComp, numDof, numBc, bcField,
16                                                NULL, bcPointIs, NULL, &section);
17        ISDestroy(&bcPointIs[0]);
18        PetscSectionSetFieldName(section, 0, "u");
19        PetscSectionSetFieldName(section, 1, "v");
20        PetscSectionSetFieldName(section, 2, "a");
21        PetscSectionSetFieldName(section, 3, "e");
22        DMSetDefaultSection(dm, section);
23        return dm;
Michael Afanasiev
Ph.D. Candidate
ETH Zürich
CH 8092 Zürich
On Oct 22, 2015, at 2:32 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Oct 21, 2015 at 3:07 PM, Dave May <dave.may at erdw.ethz.ch<mailto:dave.may at erdw.ethz.ch>> wrote:
Hey Mike,
On 21 October 2015 at 18:01, Afanasiev Michael <michael.afanasiev at erdw.ethz.ch<mailto:michael.afanasiev at erdw.ethz.ch>> wrote:
Hey Dave,
So I’ve got a couple of days where there’s nothing pressing to work on… was thinking of ripping out the parallel routines (ugly) in my wave propagation code and replacing them with Petsc DM routines. I can read in my exodusii mesh with DMPLEX, and partition it with chaco, which gives me a nicely partitioned DM. This takes me like 5 lines of code.  That’s amazing.
But here I’m stuck, and am having a whale of a time with the documentation. All I think I need is a way to modify the exodus-created DM, and add to it the degrees of freedom that are introduced by my quadrature rule. This would be really neat. I can just treat each sub-domain as its own mesh, with its own global numbering. Then whenever necessary I can scatter stuff the the real global degrees of freedom with something like VecLocToGlob. Most of the things I like about the code could stay the same (element-wise, matrix-free nature), just these parallel broadcasts would be infinitely nicer.
First off - I don't use DMPLEX.
Dave is refreshingly candid about his shortcomings ;)
But I just can’t figure out how to set this up. The main problem really boils down to: what’s the best way to add my quadrature points to an already-created DM, which was constructed with an exodus file? I guess I could do this after the file is read, but before the partitioning. In this case though, what’s stopping the partitioner from cutting an element in half? It seems like it would be a lot cleaner to do this post-partitioning.
Presumably what is read from exodus is just the vertices of the hexes, and what you want to do is define the function space (given by your GLL locations) on top of element geometry read in. Is that what you are asking about?
So Dave is right. We read in topology and geometry from ExodusII. Then you define a function space on top. How
exactly are you discretizing? In order to create vectors, do local to global, etc. Petsc really only need to know the
amount of data associated with each mesh piece. You can define this with PetscSection. If you give me an idea
what you want I can help you write the code easily I think.
     Matt
Any hints here?
Actually I have no experience with this object.
I would just send an email to
  petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
asking for help.
The developer of DMPLEX (Matt Knepley) will definitely answer within in 1 day.
Cheers,
  Dave
Best,
Mike.
Michael Afanasiev
Ph.D. Candidate
ETH Zürich
CH 8092 Zürich
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151026/f05d0863/attachment-0001.html>
