[petsc-users] DM question.
Mon Oct 26 06:52:00 CDT 2015
On Mon, Oct 26, 2015 at 6:45 AM, Afanasiev Michael <
michael.afanasiev at erdw.ethz.ch> wrote:
> Hi Matthew,
> No. There are (k-1)^2 unknowns in the interior of the cell, so that we have
>   4 + 4 * (k-1) + (k-1)^2 = (k+1)^2
> Right, makes sense. With some insight from Dave, I’m getting what I expect
> for a simple 4-cell mesh distributed amongst 4 processors (length of 91 for
> the global vector, length of 25 for the local vectors, for 4th order
> polynomial and the GLL basis). Now I imagine what’s left is to figure out
> how these vectors are globally numbered.
> I usually do this by having a consistent way of numbering the dofs on the
> reference element (i.e. given a (u, v)-space loop through v, then u), and
> then getting the local->global map via finding coincident points in a
> kd-tree. My question is: in which order are the local vectors now defined?
> If I knew this, I could create my local->global map as before. From the way
> the section was created, I guess it might be something like loop vertices,
> edges, and then interior?
The numbering is cell unknowns, vertex unknowns, face unknowns, and then
edge unknowns. This is, of course, arbitrary and therefore
you can change the order using
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/PetscSectionSetPermutation.html#PetscSectionSetPermutation
which renumbers all the mesh points in the PetscSection defining the space.
You should be able to reproduce your old ordering using
this.
    Matt
> Thanks for all your help,
> Mike.
> Michael Afanasiev
> Ph.D. Candidate
> Computational Seismology
> Institut für Geophysik
> ETH Zürich
> Sonneggstrasse 5, NO H 39.2
> CH 8092 Zürich
> On Oct 23, 2015, at 5:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Oct 23, 2015 at 9:03 AM, Afanasiev Michael <
>> Hi Matthew,
>> Yes, however I have some questions. Starting out, I think the GLL points
>> include the endpoints, so
>> that means for polynomial degree k that numDof[] should really have 4*1
>> dofs on each vertex,
>> 4*(k-1) dofs on each edge, and 4*(k-1)^2 on each quad. It looks like
>> below you have numDof[] for
>> a 1D mesh with DG element.
>> For the GLL basis we have (k+1) points in each dimension, including the
>> endpoints. So for example a 2D element with 4-order polynomials will have
>> 25 locally numbered points per element. I should also mention that the
>> velocity, displacement, and acceleration fields are vectors, with d=dim
>> components at each integration point, whereas strain has (2^dim)-1
>> components. In what you’ve written above, does this then become (sum over
>> the 4 fields):
>> (sum(compPerField*dofPerField)) -> vertex
>> (sum((compPerField*dofPerField)*(k+1)) -> edge
>> (sum((compPerField*dofPerField)*(k+1)^2) -> quad
>> With elements like these, it is common (I think) to eliminate the cell
>> unknown explicitly, since the
>> system is dense and not connected to other cells. For this, you would
>> retain the vertex and edge
>> unknowns, but not the cell unknowns. I have not tried to do this myself,
>> so I do not know if there
>> are any pitfalls.
>> I believe I don’t worry about this. Everything is solved in a matrix-free
>> sense, on each element. The relevant physical quantities are calculated on
>> each element, and then summed into the global degrees of freedom. The
>> summed global dof are then brought back to the element level, where updates
>> to the acceleration, velocity, and displacement are calculated via a
>> Newmark time step. So no global system of equations is ever formed.
> You accumulate into the global dofs, so you would need more storage if you
> do not do static condensation. It just good to know this,
> but you do not have to do it.
>> This being said, all the routines to a) integrate the element matrices,
>> b) calculate the gll point locations, c) construct the local->global dof
>> mapping, and d) do the element-wise matrix free time stepping are already
>> written.  My problem is really that I do my mesh decomposition by hand
>> (poorly), and I’d like to transfer this over to Petsc. Of course if I do
>> this, I might as well use DM's LocalToGlobal vector routines to sum my
>> field vectors across mesh partitions.
> Yes.
>> Perhaps a better question to ask would be in the form of a workflow:
>> 1) Read in exodus mesh and partition (done)
>> 2) Set up local and global degrees of freedom on each mesh partition
>> (done)
> Here you just have to setup PetscSections that mirror your local and
> global layout. Then the LocalToGlobal and its inverse will work.
>    Matt
>> 3) Integrate element matrices (done)
>> for i 1, nTimeSteps
>> 3) Step fields forward on each partition (done)
>> 4) Sum to global degrees of freedom on each partition (done)
>> 5) Sum to global degrees of freedom across partitions (????)
>> 6) Retrieve summed global degrees of freedom across partitions (????)
>> 7) Continue
>> So really what I hope Petsc will help with is just steps 5 and 6. I guess
>> this involves, given a partitioned DMPlex object, which has been
>> partitioned according to the geometry and topology defined in an exodus
>> file, adding the degrees of freedom to each partition-local vector (via a
>> DMPlexSection?). Then, ensuring that the dof added along the partition
>> boundaries sum together properly when a LocalToGlobal vector operation is
>> defined.
>> Does this make sense? If so, is this something that DMPlex is designed
>> for?
>> Michael Afanasiev
>> Ph.D. Candidate
>> ETH Zürich
>> CH 8092 Zürich
>> On Oct 23, 2015, at 1:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Oct 23, 2015 at 3:01 AM, Afanasiev Michael <
>>> Hi Matthew,
>>> So I’m discretizing via a tensor product of Lagrange polynomials
>>> co-located at the Gauss-Lobatto-Legendre (GLL) points. The polynomial order
>>> might range from 4 to 10 or something like that. The current problem is
>>> solved on 2D hexes.
>>> I had found DMPlexCreateSection, and followed plex/ex1to get things set
>>> up. You can see my attempt below. Basically I’ve got 4 fields
>>> (displacement, velocity, acceleration, and strain) over each element. Here
>>> I’ve tried to setup a tensor product of 4th order (5 GLL points) Lagrange
>>> polynomials (line 11). This seemed to *somewhat* achieve what I wanted
>>> — I created a global vector and wrote it to a vtk file with VecView, and
>>> the numbering seemed to make sense. You can also see my attempt at defining
>>> a boundary condition (it looked like DMPlexCreateFromExodus labeled side
>>> sets as “Face Sets”, seems to have worked).
>>> Does this seem to be headed in the right direction?
>> The "Face Sets" is the right label to use for boundary conditions. This
>> will eliminate those variables
>> from the global system, but they will be present in the local spaces.
>> are any pitfalls.
>> You can see an example of a similar implementation specifically for the
>> kind of spectral elements
>> you are considering here: https://github.com/jedbrown/dohp. It would
>> probably be useful to understand
>> what is done there as you implement.
>>   Thanks,
>>      Matt
>>> Cheers,
>>> Mike.
>>> DM
>>> mesh::createSection(const DM &dm)
>>> 01        // displacement, velocity, acceleration, strain
>>> 02        IS bcPointIs[1];
>>> 03        PetscInt numBc = 1;
>>> 04        PetscInt bcField[1];
>>> 05        PetscInt numFields = 4;
>>> 06        PetscInt dim; DMGetDimension(dm, &dim);
>>> 07        PetscInt numComp[numFields];
>>> 08        for (auto i=0; i<numFields; i++) {numComp[i] = dim;}
>>> 09        PetscInt numDof[numFields*(dim+1)];
>>> 10        for (auto i=0; i<numFields*(dim+1); i++) {numDof[i] = 0;}
>>> 11        for (auto i=0; i<numFields; i++) {numDof[i*(dim+1)+dim] = 5;}
>>> 12        bcField[0] = 0;
>>> 13        PetscSection section;
>>> 14        DMPlexGetStratumIS(dm, "Face Sets", 1, &bcPointIs[0]);
>>> 15        DMPlexCreateSection(dm, dim, numFields, numComp, numDof,
>>> numBc, bcField,
>>> 16                                                NULL, bcPointIs, NULL,
>>> &section);
>>> 17        ISDestroy(&bcPointIs[0]);
>>> 18        PetscSectionSetFieldName(section, 0, "u");
>>> 19        PetscSectionSetFieldName(section, 1, "v");
>>> 20        PetscSectionSetFieldName(section, 2, "a");
>>> 21        PetscSectionSetFieldName(section, 3, "e");
>>> 22        DMSetDefaultSection(dm, section);
>>> 23        return dm;
>>> Michael Afanasiev
>>> Ph.D. Candidate
>>> ETH Zürich
>>> CH 8092 Zürich
>>> On Oct 22, 2015, at 2:32 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Oct 21, 2015 at 3:07 PM, Dave May <dave.may at erdw.ethz.ch> wrote:
>>>> Hey Mike,
>>>> On 21 October 2015 at 18:01, Afanasiev Michael <
>>>>> Hey Dave,
>>>>> So I’ve got a couple of days where there’s nothing pressing to work
>>>>> on… was thinking of ripping out the parallel routines (ugly) in my wave
>>>>> propagation code and replacing them with Petsc DM routines. I can read in
>>>>> my exodusii mesh with DMPLEX, and partition it with chaco, which gives me a
>>>>> nicely partitioned DM. This takes me like 5 lines of code.  That’s amazing.
>>>>> But here I’m stuck, and am having a whale of a time with the
>>>>> documentation. All I *think* I need is a way to modify the
>>>>> exodus-created DM, and add to it the degrees of freedom that are introduced
>>>>> by my quadrature rule. This would be really neat. I can just treat each
>>>>> sub-domain as its own mesh, with its own global numbering. Then whenever
>>>>> necessary I can scatter stuff the the *real* global degrees of
>>>>> freedom with something like VecLocToGlob. Most of the things I like about
>>>>> the code could stay the same (element-wise, matrix-free nature), just these
>>>>> parallel broadcasts would be infinitely nicer.
>>>> First off - I don't use DMPLEX.
>>> Dave is refreshingly candid about his shortcomings ;)
>>> But I just can’t figure out how to set this up. The main problem really
>>>>> boils down to: what’s the best way to add my quadrature points to an
>>>>> already-created DM, which was constructed with an exodus file? I guess I
>>>>> could do this after the file is read, but before the partitioning. In this
>>>>> case though, what’s stopping the partitioner from cutting an element in
>>>>> half? It seems like it would be a lot cleaner to do this post-partitioning.
>>>> Presumably what is read from exodus is just the vertices of the hexes,
>>>> and what you want to do is define the function space (given by your GLL
>>>> locations) on top of element geometry read in. Is that what you are asking
>>>> about?
>>> So Dave is right. We read in topology and geometry from ExodusII. Then
>>> you define a function space on top. How
>>> exactly are you discretizing? In order to create vectors, do local to
>>> global, etc. Petsc really only need to know the
>>> amount of data associated with each mesh piece. You can define this with
>>> PetscSection. If you give me an idea
>>> what you want I can help you write the code easily I think.
>>>   Thanks,
>>>      Matt
>>>> Any hints here?
>>>> Actually I have no experience with this object.
>>>> I would just send an email to
>>>>   petsc-users at mcs.anl.gov
>>>> asking for help.
>>>> The developer of DMPLEX (Matt Knepley) will definitely answer within in
>>>> 1 day.
>>>> Cheers,
>>>>   Dave
>>>>> Best,
>>>>> Mike.
>>>>> Michael Afanasiev
>>>>> Ph.D. Candidate
>>>>> ETH Zürich
>>>>> CH 8092 Zürich
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151026/cf16c6e4/attachment-0001.html>
