[petsc-users] Recommended processors according to problem size for good scaling
Karl Rupp rupp at iue.tuwien.ac.at
Sun Oct 25 04:21:46 CDT 2015
I assume you have read
  http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
As a rule of thumb, 50k cells is a reasonable lower limit. It really
depends a lot on your interconnect, the dimensionality of your problem
(2d vs. 3d, ratio of 'surface' to 'volume' of the cell batch), etc.
Also, most likely your speed-up will level off after about 4 threads per
socket, as then the memory channels become saturated.
In either case, it's best to run your own tiny scaling study to get
actual numbers. -log_summary is really handy for that purpose :-)
Best regards,
Karli
On 10/25/2015 10:08 AM, TAY wee-beng wrote:
> Hi,
> Is there a recommended no. of unknowns for each processor for good
> scaling? Supposed I have 1 million unknowns (cells), how many processors
> should I use?
> I remember reading that 50k unknowns per procs is a good choice. Is that
> true?
> -- Thank you. Yours sincerely, TAY wee-beng
