[petsc-users] MatPtAP for involving MPIDENSE and MPIAIJ matrices
Bikash Kanungo bikash at umich.edu
Wed Oct 21 11:29:37 CDT 2015
Thanks a ton, Hong. You guys are amazing! I'll report any bug or
performance issue if I find any.
On Oct 21, 2015 11:43 AM, "Hong" <hzhang at mcs.anl.gov> wrote:
> Bikash,
> I implemented MatTransposeMatMult_MPIDense_MPIDense()
> in the branch hzhang/mattransmatmult_dense.
> Once it passes our nightly tests, I'll merge it to petsc master branch.
> See petsc/src/mat/examples/tests/ex104.c, in which I added a simple
> example doing
> B = P^T * A * P, where P is an MPIDENSE matrix and A is an MPIAIJ matrix.
> Let us know if you see any bug or performance issues.
> Hong
> On Fri, Oct 16, 2015 at 10:25 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Hong <hzhang at mcs.anl.gov> writes:
>> > Jed:
>> >> > I plan to implement MatTransposeMatMult_MPIDense_MPIDense via
>> >> > 1. add MatTransposeMatMult_elemental_elemental()
>> >> > 2. C_dense = P_dense^T * B_dense
>> >> >     via MatConvert_dense_elemental() and MatConvert_elemental_dense()
>> >> The above involves a ton of data movement and MPIDense is a logical
>> >> distribution for matrices with a modest number of columns.  I think I
>> >> would just do the local GEMM and then MPI_Reduce_scatter it.
>> > This would work.
>> > However, I recall that you did a smart ordering which allows
>> > MatConvert_mpidense_elemental() uses same physical matrix storage for
>> petsc
>> > and elemental,
>> Same storage for vectors.  This is your code, but I think you'll find
>> that it moves the matrix entries around.  (Note that Elemental [MC,MR]
>> is a 2D distribution while MPIDense is 1D.)  Also, I think it would be
>> better if this particular operation did not depend on Elemental.
>> You could write a conversion to Elemental [VC,*], which would then match
>> the MPIDense distribution and thus not need to move any matrix entries.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151021/24b0404f/attachment.html>
