[petsc-users] HDF5 vec output with DMPlex
Adrian Croucher a.croucher at auckland.ac.nz
Thu Oct 15 22:51:30 CDT 2015
hi,
I am wanting to output time-stepped simulation results to an HDF5 file,
from a PETSc Vec created on a DMPlex using DMCreateGlobalVector().
I tried doing it the way it's done in
src/vec/vec/examples/tutorials/ex19.c, using PetscViewerHDF5Open(),
PetscViewerHDF5PushGroup() and PetscViewerHDF5SetTimestep(), but the
resulting HDF5 file only ever seems to have results for the last time
step in it.
It works OK for a Vec created simply using VecCreate(), as in the ex19
example. Is there any reason it shouldn't work with DMPlex?
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
