[petsc-users] Points in a ball
Tue Oct 20 08:57:22 CDT 2015
On Tue, Oct 20, 2015 at 2:53 AM, Francesco Caimmi <
francesco.caimmi at polimi.it> wrote:
> Dear all,
> for an application I have in mind I have a domain divided in cells (more
> or less) and for each cell centroid, say ci, I need to know which cell
> centroids are inside a spherical neighbourhood of radius r centred at ci.
> Were the centroids placed on regular grid, a typical value for the ratio
> of r over the grid spacing would be something like 3 or 4.
> However, since the discrete domain is actually not structured, I am using
> a DMPlex object to manage the domain.
> It is not very clear to me *if* and *how* I can tell the DMPlex to add
> ghost points for all the points in such a spherical neighbourhood. If I
> were using DMDA object I think I could just set the stencil width, but I
> wasn't able to figure out a corresponding option/procedure for DMPlex (if
> it exists).
> Any hint would be really really appreciated.
The function that defines grid overlap is here:
https://bitbucket.org/petsc/petsc/src/fc309a34c451569cb3041ed38231443f9c022d73/src/dm/impls/plex/plexdistribute.c?at=master&fileviewer=file-view-default#plexdistribute.c-546
It calls a routine to define this overlap topologically
https://bitbucket.org/petsc/petsc/src/fc309a34c451569cb3041ed38231443f9c022d73/src/dm/impls/plex/plexdistribute.c?at=master&fileviewer=file-view-default#plexdistribute.c-612
You would have to modify this function to use a geometric criterion
https://bitbucket.org/petsc/petsc/src/fc309a34c451569cb3041ed38231443f9c022d73/src/dm/impls/plex/plexpartition.c?at=master&fileviewer=file-view-default#plexpartition.c-1470
If you do this, I can put it in as an option.
    Matt
> Best Regards,
> Francesco Caimmi
> Laboratorio di Ingegneria dei Polimeri
> http://www.chem.polimi.it/polyenglab/
> Politecnico di Milano - Dipartimento di Chimica,
> Materiali e Ingegneria Chimica “Giulio Natta”
> P.zza Leonardo da Vinci, 32
> I-20133 Milano
> Tel. +39.02.2399.4711
> Fax +39.02.7063.8173
> Skype: fmglcaimmi (please arrange meetings by e-mail)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151020/1a625fd2/attachment.html>
