[petsc-users] Diagnosing Poisson Solver Behavior
K. N. Ramachandran knram06 at gmail.com
Mon Oct 12 21:11:59 CDT 2015
Hello Matt,
Actually I felt the boundary conditions were having a role to play and set
all the boundary conditions to Dirichlet. In this case, convergence was
almost immediate with the Hypre preconditioner, taking 17 seconds with 3
iterations. The MG method took about the same time though.
So I reverted to the Dirichlet, Neumann mix of BCs and Hypre starts to
diverge. Please find attached the output for the Hypre run using Dirichlet
and Neumann for a 21^3 grid (rows), with a max of 7 nonzeros per row.
Details of the options used before running are in the file. The solver used
in all cases is bcgs.
Also attached is the MG output for 101^3 grid
1) Dirichlet and Neumann
2) Dirichlet only
where it seems to take about the same time.
I was thinking if the Null space has something to do with this? From the
PETSc docs, I understand that the Null space should be removed/attached
when solving singular systems. My domain will have at least two Dirichlet
conditions, so it is not singular. But since the Neumann conditions seem to
affect the convergence with Hypre, perhaps they have a role to play in
terms of the null space?
On Mon, Oct 12, 2015 at 3:52 PM, K. N. Ramachandran <knram06 at gmail.com>
wrote:
> Hello Matt,
> Thanks for your reply. I am actually retrying against the latest PETSc and
> will revert once I get the information.
> On Mon, Oct 12, 2015 at 9:39 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sat, Oct 10, 2015 at 7:56 PM, K. N. Ramachandran <knram06 at gmail.com>
>> wrote:
>>> Sorry, some more questions.
>>> 3) Also, for Dirichlet bc, I specify the value through Identity rows,
>>> i.e. A_ii = 1 and the rhs value would correspond to the Dirichlet
>>> condition. I am specifying it this way for my convenience. I am aware that
>>> MatZerosRowColumns might help here, but would keeping it this way be
>>> detrimental?
>> That is fine. However you would want to scale these entries to be
>> approximately the same size as the other diagonal entries.
>>> 4) Can I expect symmetric matrices to perform better, i.e. if I
>>> eliminate Dirichlet rows? But I would still be left with Neumann boundary
>>> conditions, where I use the second order formulation. If I used the first
>>> order formulation and made it symmetric, would that be an advantage? I
>>> tried the latter, but I didn't see the condition number change much.
>> Will not matter for MG.
>>     Matt
> Regards,
> K.N.Ramachandran
> Ph: 814-441-4279
Thanking You,
K.N.Ramachandran
Ph: 814-441-4279
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151012/f31c01ee/attachment-0001.html>
Number of lines read was 629.
  0 KSP preconditioned resid norm 2.746422809456e+13 true resid norm 2.565000000000e+04 ||r(i)||/||b|| 9.047619047619e-01
  0 KSP Residual norm 2.74642e+13
  1 KSP preconditioned resid norm 3.068441506053e+12 true resid norm 2.565000365319e+04 ||r(i)||/||b|| 9.047620336223e-01
  1 KSP Residual norm 3.06844e+12
  2 KSP preconditioned resid norm 5.231248714904e+11 true resid norm 2.564996677545e+04 ||r(i)||/||b|| 9.047607328202e-01
  2 KSP Residual norm 5.23125e+11
  3 KSP preconditioned resid norm 8.886333686081e+09 true resid norm 2.564999949878e+04 ||r(i)||/||b|| 9.047618870822e-01
  3 KSP Residual norm 8.88633e+09
  4 KSP preconditioned resid norm 8.839069909584e+09 true resid norm 2.564999939254e+04 ||r(i)||/||b|| 9.047618833347e-01
  4 KSP Residual norm 8.83907e+09
  5 KSP preconditioned resid norm 9.614961589585e+09 true resid norm 2.565178081416e+04 ||r(i)||/||b|| 9.048247200763e-01
  5 KSP Residual norm 9.61496e+09
  6 KSP preconditioned resid norm 8.741604166481e+09 true resid norm 2.565178072277e+04 ||r(i)||/||b|| 9.048247168526e-01
  6 KSP Residual norm 8.7416e+09
  7 KSP preconditioned resid norm 8.235731151411e+09 true resid norm 2.565178075232e+04 ||r(i)||/||b|| 9.048247178947e-01
  7 KSP Residual norm 8.23573e+09
  8 KSP preconditioned resid norm 1.621290699141e+10 true resid norm 2.575853377098e+04 ||r(i)||/||b|| 9.085902564719e-01
  8 KSP Residual norm 1.62129e+10
  9 KSP preconditioned resid norm 1.620223144519e+10 true resid norm 2.575845320875e+04 ||r(i)||/||b|| 9.085874147706e-01
  9 KSP Residual norm 1.62022e+10
 10 KSP preconditioned resid norm 1.547486240008e+10 true resid norm 2.575771305043e+04 ||r(i)||/||b|| 9.085613068934e-01
 10 KSP Residual norm 1.54749e+10
 11 KSP preconditioned resid norm 7.715548867365e+09 true resid norm 2.565552991809e+04 ||r(i)||/||b|| 9.049569636010e-01
 11 KSP Residual norm 7.71555e+09
 12 KSP preconditioned resid norm 3.889844790546e+09 true resid norm 2.565945115206e+04 ||r(i)||/||b|| 9.050952787324e-01
 12 KSP Residual norm 3.88984e+09
 13 KSP preconditioned resid norm 2.073570348298e+09 true resid norm 2.565946414127e+04 ||r(i)||/||b|| 9.050957369054e-01
 13 KSP Residual norm 2.07357e+09
 14 KSP preconditioned resid norm 2.071889747823e+09 true resid norm 2.565946415085e+04 ||r(i)||/||b|| 9.050957372435e-01
 14 KSP Residual norm 2.07189e+09
 15 KSP preconditioned resid norm 2.073916663913e+09 true resid norm 2.565948414693e+04 ||r(i)||/||b|| 9.050964425726e-01
 15 KSP Residual norm 2.07392e+09
 16 KSP preconditioned resid norm 3.589156239198e+08 true resid norm 2.565390234822e+04 ||r(i)||/||b|| 9.048995537292e-01
 16 KSP Residual norm 3.58916e+08
 17 KSP preconditioned resid norm 1.282067102091e+08 true resid norm 2.565925054713e+04 ||r(i)||/||b|| 9.050882027206e-01
 17 KSP Residual norm 1.28207e+08
 18 KSP preconditioned resid norm 1.273021891519e+08 true resid norm 2.565925054752e+04 ||r(i)||/||b|| 9.050882027344e-01
 18 KSP Residual norm 1.27302e+08
 19 KSP preconditioned resid norm 1.268287715098e+08 true resid norm 2.565926001252e+04 ||r(i)||/||b|| 9.050885365969e-01
 19 KSP Residual norm 1.26829e+08
 20 KSP preconditioned resid norm 2.345828930128e+08 true resid norm 2.566026335819e+04 ||r(i)||/||b|| 9.051239279783e-01
 20 KSP Residual norm 2.34583e+08
 21 KSP preconditioned resid norm 1.630341247775e+08 true resid norm 2.565856686030e+04 ||r(i)||/||b|| 9.050640867831e-01
 21 KSP Residual norm 1.63034e+08
 22 KSP preconditioned resid norm 1.523032674511e+08 true resid norm 2.565866052028e+04 ||r(i)||/||b|| 9.050673904862e-01
 22 KSP Residual norm 1.52303e+08
 23 KSP preconditioned resid norm 7.511400932854e+08 true resid norm 2.566425258525e+04 ||r(i)||/||b|| 9.052646414550e-01
 23 KSP Residual norm 7.5114e+08
 24 KSP preconditioned resid norm 7.487411421877e+08 true resid norm 2.566425257593e+04 ||r(i)||/||b|| 9.052646411264e-01
 24 KSP Residual norm 7.48741e+08
 25 KSP preconditioned resid norm 7.517590916570e+08 true resid norm 2.566428660733e+04 ||r(i)||/||b|| 9.052658415283e-01
 25 KSP Residual norm 7.51759e+08
 26 KSP preconditioned resid norm 6.712414388866e+08 true resid norm 2.566385823745e+04 ||r(i)||/||b|| 9.052507314796e-01
 26 KSP Residual norm 6.71241e+08
 27 KSP preconditioned resid norm 6.711948000736e+08 true resid norm 2.566385821489e+04 ||r(i)||/||b|| 9.052507306840e-01
 27 KSP Residual norm 6.71195e+08
 28 KSP preconditioned resid norm 6.777281637926e+08 true resid norm 2.566406931696e+04 ||r(i)||/||b|| 9.052581769649e-01
 28 KSP Residual norm 6.77728e+08
 29 KSP preconditioned resid norm 6.816151312784e+08 true resid norm 2.566419142142e+04 ||r(i)||/||b|| 9.052624840008e-01
 29 KSP Residual norm 6.81615e+08
 30 KSP preconditioned resid norm 3.453970716323e+08 true resid norm 2.565596719002e+04 ||r(i)||/||b|| 9.049723876550e-01
 30 KSP Residual norm 3.45397e+08
 31 KSP preconditioned resid norm 3.440067141747e+08 true resid norm 2.565595358060e+04 ||r(i)||/||b|| 9.049719076050e-01
 31 KSP Residual norm 3.44007e+08
 32 KSP preconditioned resid norm 3.440043333335e+08 true resid norm 2.565595350230e+04 ||r(i)||/||b|| 9.049719048430e-01
 32 KSP Residual norm 3.44004e+08
 33 KSP preconditioned resid norm 3.440062912059e+08 true resid norm 2.565595341062e+04 ||r(i)||/||b|| 9.049719016093e-01
 33 KSP Residual norm 3.44006e+08
 34 KSP preconditioned resid norm 1.056990033279e+08 true resid norm 2.565262526962e+04 ||r(i)||/||b|| 9.048545068650e-01
 34 KSP Residual norm 1.05699e+08
 35 KSP preconditioned resid norm 8.874726811494e+07 true resid norm 2.565262526272e+04 ||r(i)||/||b|| 9.048545066215e-01
 35 KSP Residual norm 8.87473e+07
 36 KSP preconditioned resid norm 8.853824300744e+07 true resid norm 2.565263428333e+04 ||r(i)||/||b|| 9.048548248087e-01
 36 KSP Residual norm 8.85382e+07
 37 KSP preconditioned resid norm 8.847029828263e+07 true resid norm 2.565263461124e+04 ||r(i)||/||b|| 9.048548363752e-01
 37 KSP Residual norm 8.84703e+07
 38 KSP preconditioned resid norm 8.827921818416e+07 true resid norm 2.565263507031e+04 ||r(i)||/||b|| 9.048548525683e-01
 38 KSP Residual norm 8.82792e+07
 39 KSP preconditioned resid norm 8.810895958886e+07 true resid norm 2.565263192471e+04 ||r(i)||/||b|| 9.048547416125e-01
 39 KSP Residual norm 8.8109e+07
 40 KSP preconditioned resid norm 8.810893250183e+07 true resid norm 2.565263192472e+04 ||r(i)||/||b|| 9.048547416125e-01
 40 KSP Residual norm 8.81089e+07
 41 KSP preconditioned resid norm 2.832676882984e+08 true resid norm 2.587947231892e+04 ||r(i)||/||b|| 9.128561664522e-01
 41 KSP Residual norm 2.83268e+08
 42 KSP preconditioned resid norm 5.094464612028e+08 true resid norm 2.632571610237e+04 ||r(i)||/||b|| 9.285966879144e-01
 42 KSP Residual norm 5.09446e+08
 43 KSP preconditioned resid norm 5.094272471154e+08 true resid norm 2.632571759868e+04 ||r(i)||/||b|| 9.285967406940e-01
 43 KSP Residual norm 5.09427e+08
 44 KSP preconditioned resid norm 5.094932045774e+08 true resid norm 2.632581903783e+04 ||r(i)||/||b|| 9.286003187947e-01
 44 KSP Residual norm 5.09493e+08
 45 KSP preconditioned resid norm 5.094147162461e+08 true resid norm 2.632570228114e+04 ||r(i)||/||b|| 9.285962003929e-01
 45 KSP Residual norm 5.09415e+08
 46 KSP preconditioned resid norm 5.392886146895e+08 true resid norm 2.637071253446e+04 ||r(i)||/||b|| 9.301838636494e-01
 46 KSP Residual norm 5.39289e+08
 47 KSP preconditioned resid norm 5.394119316675e+08 true resid norm 2.637090361414e+04 ||r(i)||/||b|| 9.301906036734e-01
 47 KSP Residual norm 5.39412e+08
 48 KSP preconditioned resid norm 6.619138323982e+08 true resid norm 2.656818352376e+04 ||r(i)||/||b|| 9.371493306440e-01
 48 KSP Residual norm 6.61914e+08
 49 KSP preconditioned resid norm 5.750298780298e+08 true resid norm 2.642560433787e+04 ||r(i)||/||b|| 9.321200824644e-01
 49 KSP Residual norm 5.7503e+08
 50 KSP preconditioned resid norm 5.904316293874e+08 true resid norm 2.645018122477e+04 ||r(i)||/||b|| 9.329869920555e-01
 50 KSP Residual norm 5.90432e+08
 51 KSP preconditioned resid norm 5.908766007712e+08 true resid norm 2.645090453708e+04 ||r(i)||/||b|| 9.330125057172e-01
 51 KSP Residual norm 5.90877e+08
 52 KSP preconditioned resid norm 5.473325996306e+09 true resid norm 4.605238258213e+04 ||r(i)||/||b|| 1.624422666036e+00
 52 KSP Residual norm 5.47333e+09
 53 KSP preconditioned resid norm 5.545262905105e+09 true resid norm 4.644344293813e+04 ||r(i)||/||b|| 1.638216682121e+00
 53 KSP Residual norm 5.54526e+09
 54 KSP preconditioned resid norm 6.985912203753e+09 true resid norm 5.465866950046e+04 ||r(i)||/||b|| 1.927995396842e+00
 54 KSP Residual norm 6.98591e+09
 55 KSP preconditioned resid norm 7.028372253151e+09 true resid norm 5.491163709071e+04 ||r(i)||/||b|| 1.936918415898e+00
 55 KSP Residual norm 7.02837e+09
 56 KSP preconditioned resid norm 6.956696069159e+09 true resid norm 5.449230060223e+04 ||r(i)||/||b|| 1.922127005370e+00
 56 KSP Residual norm 6.9567e+09
 57 KSP preconditioned resid norm 6.956620270168e+09 true resid norm 5.449227495259e+04 ||r(i)||/||b|| 1.922126100620e+00
 57 KSP Residual norm 6.95662e+09
 58 KSP preconditioned resid norm 7.557947501531e+09 true resid norm 5.790682041701e+04 ||r(i)||/||b|| 2.042568621411e+00
 58 KSP Residual norm 7.55795e+09
 59 KSP preconditioned resid norm 7.557887191771e+09 true resid norm 5.790684802653e+04 ||r(i)||/||b|| 2.042569595292e+00
 59 KSP Residual norm 7.55789e+09
 60 KSP preconditioned resid norm 5.922018057101e+09 true resid norm 4.877211157711e+04 ||r(i)||/||b|| 1.720356669386e+00
 60 KSP Residual norm 5.92202e+09
 61 KSP preconditioned resid norm 5.921901618668e+09 true resid norm 4.877143775666e+04 ||r(i)||/||b|| 1.720332901470e+00
 61 KSP Residual norm 5.9219e+09
 62 KSP preconditioned resid norm 6.206899718077e+09 true resid norm 5.048143067017e+04 ||r(i)||/||b|| 1.780650111823e+00
 62 KSP Residual norm 6.2069e+09
 63 KSP preconditioned resid norm 5.915710507609e+09 true resid norm 4.875654343996e+04 ||r(i)||/||b|| 1.719807528746e+00
 63 KSP Residual norm 5.91571e+09
 64 KSP preconditioned resid norm 5.874812416368e+09 true resid norm 4.851577496082e+04 ||r(i)||/||b|| 1.711314813433e+00
 64 KSP Residual norm 5.87481e+09
 65 KSP preconditioned resid norm 4.282677980829e+09 true resid norm 1.263517579531e+05 ||r(i)||/||b|| 4.456852132386e+00
 65 KSP Residual norm 4.28268e+09
 66 KSP preconditioned resid norm 3.399082369795e+09 true resid norm 1.263514198377e+05 ||r(i)||/||b|| 4.456840205915e+00
 66 KSP Residual norm 3.39908e+09
 67 KSP preconditioned resid norm 3.398843450548e+09 true resid norm 1.263512159099e+05 ||r(i)||/||b|| 4.456833012693e+00
 67 KSP Residual norm 3.39884e+09
 68 KSP preconditioned resid norm 3.340863917040e+09 true resid norm 1.251554785170e+05 ||r(i)||/||b|| 4.414655326879e+00
 68 KSP Residual norm 3.34086e+09
 69 KSP preconditioned resid norm 3.341010231124e+09 true resid norm 1.251596104734e+05 ||r(i)||/||b|| 4.414801074901e+00
 69 KSP Residual norm 3.34101e+09
 70 KSP preconditioned resid norm 3.413554710700e+09 true resid norm 1.267351623618e+05 ||r(i)||/||b|| 4.470376097419e+00
 70 KSP Residual norm 3.41355e+09
 71 KSP preconditioned resid norm 3.406550397907e+09 true resid norm 1.267481752469e+05 ||r(i)||/||b|| 4.470835105711e+00
 71 KSP Residual norm 3.40655e+09
 72 KSP preconditioned resid norm 3.405180126984e+09 true resid norm 1.267482110372e+05 ||r(i)||/||b|| 4.470836368155e+00
 72 KSP Residual norm 3.40518e+09
 73 KSP preconditioned resid norm 3.202517222100e+09 true resid norm 1.227605456906e+05 ||r(i)||/||b|| 4.330177978503e+00
 73 KSP Residual norm 3.20252e+09
 74 KSP preconditioned resid norm 3.200035599801e+09 true resid norm 1.227599047136e+05 ||r(i)||/||b|| 4.330155369088e+00
 74 KSP Residual norm 3.20004e+09
 75 KSP preconditioned resid norm 5.800869198419e+09 true resid norm 1.750241638496e+05 ||r(i)||/||b|| 6.173691846546e+00
 75 KSP Residual norm 5.80087e+09
 76 KSP preconditioned resid norm 5.786449097800e+09 true resid norm 1.750126667441e+05 ||r(i)||/||b|| 6.173286304907e+00
 76 KSP Residual norm 5.78645e+09
 77 KSP preconditioned resid norm 4.835224177932e+09 true resid norm 1.562224322500e+05 ||r(i)||/||b|| 5.510491437389e+00
 77 KSP Residual norm 4.83522e+09
 78 KSP preconditioned resid norm 4.835168801321e+09 true resid norm 1.562233476102e+05 ||r(i)||/||b|| 5.510523725226e+00
 78 KSP Residual norm 4.83517e+09
 79 KSP preconditioned resid norm 6.347543402233e+09 true resid norm 7.481908590977e+04 ||r(i)||/||b|| 2.639121196112e+00
 79 KSP Residual norm 6.34754e+09
 80 KSP preconditioned resid norm 6.326865493321e+09 true resid norm 7.443283156609e+04 ||r(i)||/||b|| 2.625496704271e+00
 80 KSP Residual norm 6.32687e+09
 81 KSP preconditioned resid norm 1.955070438438e+09 true resid norm 3.296317972666e+04 ||r(i)||/||b|| 1.162722388948e+00
 81 KSP Residual norm 1.95507e+09
 82 KSP preconditioned resid norm 1.879007613781e+09 true resid norm 3.391312036621e+04 ||r(i)||/||b|| 1.196229995281e+00
 82 KSP Residual norm 1.87901e+09
 83 KSP preconditioned resid norm 1.878584017023e+09 true resid norm 3.390547232026e+04 ||r(i)||/||b|| 1.195960222937e+00
 83 KSP Residual norm 1.87858e+09
 84 KSP preconditioned resid norm 1.878625570135e+09 true resid norm 3.390494811375e+04 ||r(i)||/||b|| 1.195941732407e+00
 84 KSP Residual norm 1.87863e+09
 85 KSP preconditioned resid norm 1.878150970552e+09 true resid norm 3.392253157839e+04 ||r(i)||/||b|| 1.196561960437e+00
 85 KSP Residual norm 1.87815e+09
 86 KSP preconditioned resid norm 1.872131248738e+09 true resid norm 3.398501170486e+04 ||r(i)||/||b|| 1.198765844968e+00
 86 KSP Residual norm 1.87213e+09
 87 KSP preconditioned resid norm 1.862562589043e+09 true resid norm 3.410432855752e+04 ||r(i)||/||b|| 1.202974552293e+00
 87 KSP Residual norm 1.86256e+09
 88 KSP preconditioned resid norm 1.861801920798e+09 true resid norm 3.411436806464e+04 ||r(i)||/||b|| 1.203328679529e+00
 88 KSP Residual norm 1.8618e+09
 89 KSP preconditioned resid norm 1.861732815998e+09 true resid norm 3.411450834870e+04 ||r(i)||/||b|| 1.203333627820e+00
 89 KSP Residual norm 1.86173e+09
 90 KSP preconditioned resid norm 1.861829113157e+09 true resid norm 3.417586491910e+04 ||r(i)||/||b|| 1.205497880744e+00
 90 KSP Residual norm 1.86183e+09
 91 KSP preconditioned resid norm 1.856883125610e+09 true resid norm 3.417498104263e+04 ||r(i)||/||b|| 1.205466703444e+00
 91 KSP Residual norm 1.85688e+09
 92 KSP preconditioned resid norm 1.847065929125e+09 true resid norm 3.428971796667e+04 ||r(i)||/||b|| 1.209513861258e+00
 92 KSP Residual norm 1.84707e+09
 93 KSP preconditioned resid norm 1.848791512225e+09 true resid norm 3.426284189227e+04 ||r(i)||/||b|| 1.208565851579e+00
 93 KSP Residual norm 1.84879e+09
 94 KSP preconditioned resid norm 1.827844234443e+09 true resid norm 3.453841929543e+04 ||r(i)||/||b|| 1.218286394901e+00
 94 KSP Residual norm 1.82784e+09
 95 KSP preconditioned resid norm 1.827774709429e+09 true resid norm 3.453841962987e+04 ||r(i)||/||b|| 1.218286406697e+00
 95 KSP Residual norm 1.82777e+09
 96 KSP preconditioned resid norm 6.414487075650e+09 true resid norm 7.391240064152e+04 ||r(i)||/||b|| 2.607139352435e+00
 96 KSP Residual norm 6.41449e+09
 97 KSP preconditioned resid norm 6.415045121560e+09 true resid norm 7.392268206099e+04 ||r(i)||/||b|| 2.607502012733e+00
 97 KSP Residual norm 6.41505e+09
 98 KSP preconditioned resid norm 6.401511248492e+09 true resid norm 7.367799137929e+04 ||r(i)||/||b|| 2.598870948123e+00
 98 KSP Residual norm 6.40151e+09
 99 KSP preconditioned resid norm 5.823452922482e+09 true resid norm 6.324752016902e+04 ||r(i)||/||b|| 2.230953092382e+00
 99 KSP Residual norm 5.82345e+09
100 KSP preconditioned resid norm 1.200549311182e+10 true resid norm 1.817187164268e+05 ||r(i)||/||b|| 6.409831267258e+00
100 KSP Residual norm 1.20055e+10
101 KSP preconditioned resid norm 1.199021567525e+10 true resid norm 1.816659732185e+05 ||r(i)||/||b|| 6.407970836632e+00
101 KSP Residual norm 1.19902e+10
102 KSP preconditioned resid norm 1.599940019890e+10 true resid norm 2.601826735101e+05 ||r(i)||/||b|| 9.177519347800e+00
102 KSP Residual norm 1.59994e+10
103 KSP preconditioned resid norm 1.596880097390e+10 true resid norm 2.595841214331e+05 ||r(i)||/||b|| 9.156406399755e+00
103 KSP Residual norm 1.59688e+10
104 KSP preconditioned resid norm 5.367460315778e+09 true resid norm 5.575620393927e+04 ||r(i)||/||b|| 1.966709133660e+00
104 KSP Residual norm 5.36746e+09
105 KSP preconditioned resid norm 5.367159894930e+09 true resid norm 5.575117378768e+04 ||r(i)||/||b|| 1.966531703269e+00
105 KSP Residual norm 5.36716e+09
106 KSP preconditioned resid norm 5.320615022748e+09 true resid norm 6.100403691365e+04 ||r(i)||/||b|| 2.151817880552e+00
106 KSP Residual norm 5.32062e+09
107 KSP preconditioned resid norm 5.295090674561e+09 true resid norm 6.100343132478e+04 ||r(i)||/||b|| 2.151796519393e+00
107 KSP Residual norm 5.29509e+09
108 KSP preconditioned resid norm 5.300575025668e+09 true resid norm 6.112708327182e+04 ||r(i)||/||b|| 2.156158140099e+00
108 KSP Residual norm 5.30058e+09
109 KSP preconditioned resid norm 5.300311309732e+09 true resid norm 6.112184454233e+04 ||r(i)||/||b|| 2.155973352463e+00
109 KSP Residual norm 5.30031e+09
110 KSP preconditioned resid norm 4.707463773424e+09 true resid norm 4.961969919811e+04 ||r(i)||/||b|| 1.750253939968e+00
110 KSP Residual norm 4.70746e+09
111 KSP preconditioned resid norm 4.707435553722e+09 true resid norm 4.961917481621e+04 ||r(i)||/||b|| 1.750235443252e+00
111 KSP Residual norm 4.70744e+09
112 KSP preconditioned resid norm 4.581779174905e+09 true resid norm 8.243536773251e+04 ||r(i)||/||b|| 2.907773112258e+00
112 KSP Residual norm 4.58178e+09
113 KSP preconditioned resid norm 4.460704312961e+09 true resid norm 8.243667172369e+04 ||r(i)||/||b|| 2.907819108420e+00
113 KSP Residual norm 4.4607e+09
114 KSP preconditioned resid norm 4.444429099697e+09 true resid norm 8.185303111185e+04 ||r(i)||/||b|| 2.887232137984e+00
114 KSP Residual norm 4.44443e+09
115 KSP preconditioned resid norm 4.444180637628e+09 true resid norm 8.184349413475e+04 ||r(i)||/||b|| 2.886895736675e+00
115 KSP Residual norm 4.44418e+09
116 KSP preconditioned resid norm 4.442501512234e+09 true resid norm 8.176511122736e+04 ||r(i)||/||b|| 2.884130907491e+00
116 KSP Residual norm 4.4425e+09
117 KSP preconditioned resid norm 4.442500992893e+09 true resid norm 8.176511099161e+04 ||r(i)||/||b|| 2.884130899175e+00
117 KSP Residual norm 4.4425e+09
118 KSP preconditioned resid norm 4.438588508271e+09 true resid norm 8.171332777261e+04 ||r(i)||/||b|| 2.882304330604e+00
118 KSP Residual norm 4.43859e+09
119 KSP preconditioned resid norm 4.438401655459e+09 true resid norm 8.171332773633e+04 ||r(i)||/||b|| 2.882304329324e+00
119 KSP Residual norm 4.4384e+09
120 KSP preconditioned resid norm 1.317525363949e+08 true resid norm 2.692106697168e+04 ||r(i)||/||b|| 9.495967185778e-01
120 KSP Residual norm 1.31753e+08
121 KSP preconditioned resid norm 1.308800784727e+08 true resid norm 2.692692818159e+04 ||r(i)||/||b|| 9.498034631954e-01
121 KSP Residual norm 1.3088e+08
122 KSP preconditioned resid norm 7.603842291444e+07 true resid norm 2.779457205567e+04 ||r(i)||/||b|| 9.804081853851e-01
122 KSP Residual norm 7.60384e+07
123 KSP preconditioned resid norm 7.786999714125e+07 true resid norm 2.783487508098e+04 ||r(i)||/||b|| 9.818298088528e-01
123 KSP Residual norm 7.787e+07
124 KSP preconditioned resid norm 7.588747018640e+07 true resid norm 2.779571139502e+04 ||r(i)||/||b|| 9.804483737220e-01
124 KSP Residual norm 7.58875e+07
125 KSP preconditioned resid norm 7.883172110161e+07 true resid norm 2.785164157962e+04 ||r(i)||/||b|| 9.824212197397e-01
125 KSP Residual norm 7.88317e+07
126 KSP preconditioned resid norm 7.895619286249e+07 true resid norm 2.785394896305e+04 ||r(i)||/||b|| 9.825026089261e-01
126 KSP Residual norm 7.89562e+07
127 KSP preconditioned resid norm 1.419982565818e+08 true resid norm 2.685170592763e+04 ||r(i)||/||b|| 9.471501209040e-01
127 KSP Residual norm 1.41998e+08
128 KSP preconditioned resid norm 1.571365751637e+08 true resid norm 2.675030023884e+04 ||r(i)||/||b|| 9.435732006644e-01
128 KSP Residual norm 1.57137e+08
129 KSP preconditioned resid norm 1.547396298924e+08 true resid norm 2.674946866281e+04 ||r(i)||/||b|| 9.435438681766e-01
129 KSP Residual norm 1.5474e+08
130 KSP preconditioned resid norm 1.550040600360e+08 true resid norm 2.674789513753e+04 ||r(i)||/||b|| 9.434883646394e-01
130 KSP Residual norm 1.55004e+08
131 KSP preconditioned resid norm 1.473917053093e+08 true resid norm 2.679211609491e+04 ||r(i)||/||b|| 9.450481867694e-01
131 KSP Residual norm 1.47392e+08
132 KSP preconditioned resid norm 1.447376699776e+08 true resid norm 2.680792549358e+04 ||r(i)||/||b|| 9.456058375161e-01
132 KSP Residual norm 1.44738e+08
133 KSP preconditioned resid norm 9.392057756041e+07 true resid norm 2.717200095632e+04 ||r(i)||/||b|| 9.584480055138e-01
133 KSP Residual norm 9.39206e+07
134 KSP preconditioned resid norm 9.365125751222e+07 true resid norm 2.717452342546e+04 ||r(i)||/||b|| 9.585369814978e-01
134 KSP Residual norm 9.36513e+07
135 KSP preconditioned resid norm 9.357656851783e+07 true resid norm 2.717504278405e+04 ||r(i)||/||b|| 9.585553010248e-01
135 KSP Residual norm 9.35766e+07
136 KSP preconditioned resid norm 9.432911703112e+07 true resid norm 2.716745072225e+04 ||r(i)||/||b|| 9.582875034304e-01
136 KSP Residual norm 9.43291e+07
137 KSP preconditioned resid norm 9.208617884080e+07 true resid norm 2.718929189750e+04 ||r(i)||/||b|| 9.590579152557e-01
137 KSP Residual norm 9.20862e+07
138 KSP preconditioned resid norm 9.203707831663e+07 true resid norm 2.718905167187e+04 ||r(i)||/||b|| 9.590494416886e-01
138 KSP Residual norm 9.20371e+07
139 KSP preconditioned resid norm 9.337458782546e+07 true resid norm 2.717493537915e+04 ||r(i)||/||b|| 9.585515124920e-01
139 KSP Residual norm 9.33746e+07
140 KSP preconditioned resid norm 6.901974077152e+08 true resid norm 2.623579156570e+04 ||r(i)||/||b|| 9.254247465856e-01
140 KSP Residual norm 6.90197e+08
141 KSP preconditioned resid norm 1.975679753339e+08 true resid norm 2.646433994022e+04 ||r(i)||/||b|| 9.334864176446e-01
141 KSP Residual norm 1.97568e+08
142 KSP preconditioned resid norm 1.954417782803e+08 true resid norm 2.647439384680e+04 ||r(i)||/||b|| 9.338410527972e-01
142 KSP Residual norm 1.95442e+08
143 KSP preconditioned resid norm 1.960399893844e+08 true resid norm 2.647133991553e+04 ||r(i)||/||b|| 9.337333303539e-01
143 KSP Residual norm 1.9604e+08
144 KSP preconditioned resid norm 1.955670584333e+08 true resid norm 2.647325367781e+04 ||r(i)||/||b|| 9.338008351960e-01
144 KSP Residual norm 1.95567e+08
145 KSP preconditioned resid norm 1.950109040317e+08 true resid norm 2.647531183614e+04 ||r(i)||/||b|| 9.338734333736e-01
145 KSP Residual norm 1.95011e+08
146 KSP preconditioned resid norm 2.044593716817e+08 true resid norm 2.642909995124e+04 ||r(i)||/||b|| 9.322433845234e-01
146 KSP Residual norm 2.04459e+08
147 KSP preconditioned resid norm 2.029589861814e+08 true resid norm 2.643596010230e+04 ||r(i)||/||b|| 9.324853651604e-01
147 KSP Residual norm 2.02959e+08
148 KSP preconditioned resid norm 2.021068171567e+08 true resid norm 2.644005464457e+04 ||r(i)||/||b|| 9.326297934594e-01
148 KSP Residual norm 2.02107e+08
149 KSP preconditioned resid norm 3.913475546831e+08 true resid norm 2.585852316907e+04 ||r(i)||/||b|| 9.121172193676e-01
149 KSP Residual norm 3.91348e+08
150 KSP preconditioned resid norm 2.936596720006e+08 true resid norm 2.610384627244e+04 ||r(i)||/||b|| 9.207705916204e-01
150 KSP Residual norm 2.9366e+08
151 KSP preconditioned resid norm 2.388405097790e+08 true resid norm 2.610383006923e+04 ||r(i)||/||b|| 9.207700200785e-01
151 KSP Residual norm 2.38841e+08
152 KSP preconditioned resid norm 2.388371833554e+08 true resid norm 2.610383007076e+04 ||r(i)||/||b|| 9.207700201326e-01
152 KSP Residual norm 2.38837e+08
153 KSP preconditioned resid norm 2.338099680317e+08 true resid norm 2.611532371119e+04 ||r(i)||/||b|| 9.211754395483e-01
153 KSP Residual norm 2.3381e+08
154 KSP preconditioned resid norm 2.309318034524e+08 true resid norm 2.611532410104e+04 ||r(i)||/||b|| 9.211754532994e-01
154 KSP Residual norm 2.30932e+08
155 KSP preconditioned resid norm 2.321145313197e+08 true resid norm 2.611063178072e+04 ||r(i)||/||b|| 9.210099393553e-01
155 KSP Residual norm 2.32115e+08
156 KSP preconditioned resid norm 2.321145291804e+08 true resid norm 2.611063178074e+04 ||r(i)||/||b|| 9.210099393557e-01
156 KSP Residual norm 2.32115e+08
157 KSP preconditioned resid norm 2.320433411319e+08 true resid norm 2.611077036572e+04 ||r(i)||/||b|| 9.210148277151e-01
157 KSP Residual norm 2.32043e+08
158 KSP preconditioned resid norm 2.320433270295e+08 true resid norm 2.611077036371e+04 ||r(i)||/||b|| 9.210148276441e-01
158 KSP Residual norm 2.32043e+08
159 KSP preconditioned resid norm 1.978911170688e+08 true resid norm 2.618266522378e+04 ||r(i)||/||b|| 9.235508015441e-01
159 KSP Residual norm 1.97891e+08
160 KSP preconditioned resid norm 1.978533948713e+08 true resid norm 2.618266545810e+04 ||r(i)||/||b|| 9.235508098096e-01
160 KSP Residual norm 1.97853e+08
161 KSP preconditioned resid norm 2.038236960653e+08 true resid norm 2.616971533406e+04 ||r(i)||/||b|| 9.230940153108e-01
161 KSP Residual norm 2.03824e+08
162 KSP preconditioned resid norm 2.030406249754e+08 true resid norm 2.616971498086e+04 ||r(i)||/||b|| 9.230940028521e-01
162 KSP Residual norm 2.03041e+08
163 KSP preconditioned resid norm 2.022418418224e+08 true resid norm 2.616964828616e+04 ||r(i)||/||b|| 9.230916503055e-01
163 KSP Residual norm 2.02242e+08
164 KSP preconditioned resid norm 2.022395853195e+08 true resid norm 2.616965000510e+04 ||r(i)||/||b|| 9.230917109381e-01
164 KSP Residual norm 2.0224e+08
165 KSP preconditioned resid norm 2.038571322569e+08 true resid norm 2.616457641497e+04 ||r(i)||/||b|| 9.229127483236e-01
165 KSP Residual norm 2.03857e+08
166 KSP preconditioned resid norm 2.037514413417e+08 true resid norm 2.616457640363e+04 ||r(i)||/||b|| 9.229127479233e-01
166 KSP Residual norm 2.03751e+08
167 KSP preconditioned resid norm 2.053085730433e+08 true resid norm 2.615946980360e+04 ||r(i)||/||b|| 9.227326209381e-01
167 KSP Residual norm 2.05309e+08
168 KSP preconditioned resid norm 2.053032672180e+08 true resid norm 2.615946978529e+04 ||r(i)||/||b|| 9.227326202924e-01
168 KSP Residual norm 2.05303e+08
169 KSP preconditioned resid norm 1.828123515158e+08 true resid norm 2.623703546424e+04 ||r(i)||/||b|| 9.254686230771e-01
169 KSP Residual norm 1.82812e+08
170 KSP preconditioned resid norm 1.828098122925e+08 true resid norm 2.623704378628e+04 ||r(i)||/||b|| 9.254689166236e-01
170 KSP Residual norm 1.8281e+08
171 KSP preconditioned resid norm 1.834673936846e+08 true resid norm 2.623437488930e+04 ||r(i)||/||b|| 9.253747756368e-01
171 KSP Residual norm 1.83467e+08
172 KSP preconditioned resid norm 1.916771577850e+08 true resid norm 2.620533558988e+04 ||r(i)||/||b|| 9.243504617242e-01
172 KSP Residual norm 1.91677e+08
173 KSP preconditioned resid norm 1.686641180349e+08 true resid norm 2.628665878348e+04 ||r(i)||/||b|| 9.272190047084e-01
173 KSP Residual norm 1.68664e+08
174 KSP preconditioned resid norm 1.709601402020e+08 true resid norm 2.627821316745e+04 ||r(i)||/||b|| 9.269210993811e-01
174 KSP Residual norm 1.7096e+08
175 KSP preconditioned resid norm 7.846116202614e+07 true resid norm 2.642395683327e+04 ||r(i)||/||b|| 9.320619694275e-01
175 KSP Residual norm 7.84612e+07
176 KSP preconditioned resid norm 5.522839992102e+07 true resid norm 2.642395687169e+04 ||r(i)||/||b|| 9.320619707828e-01
176 KSP Residual norm 5.52284e+07
177 KSP preconditioned resid norm 5.194245628852e+07 true resid norm 2.642320086058e+04 ||r(i)||/||b|| 9.320353037241e-01
177 KSP Residual norm 5.19425e+07
178 KSP preconditioned resid norm 5.194058661224e+07 true resid norm 2.642319769115e+04 ||r(i)||/||b|| 9.320351919277e-01
178 KSP Residual norm 5.19406e+07
179 KSP preconditioned resid norm 5.204188143404e+07 true resid norm 2.642431651695e+04 ||r(i)||/||b|| 9.320746566825e-01
179 KSP Residual norm 5.20419e+07
180 KSP preconditioned resid norm 5.204080009408e+07 true resid norm 2.642431651631e+04 ||r(i)||/||b|| 9.320746566601e-01
180 KSP Residual norm 5.20408e+07
181 KSP preconditioned resid norm 5.204864539664e+07 true resid norm 2.642449262498e+04 ||r(i)||/||b|| 9.320808686060e-01
181 KSP Residual norm 5.20486e+07
182 KSP preconditioned resid norm 5.204844807607e+07 true resid norm 2.642449262510e+04 ||r(i)||/||b|| 9.320808686102e-01
182 KSP Residual norm 5.20484e+07
183 KSP preconditioned resid norm 3.493548636434e+07 true resid norm 2.571292620106e+04 ||r(i)||/||b|| 9.069815238469e-01
183 KSP Residual norm 3.49355e+07
184 KSP preconditioned resid norm 4.110412050847e+07 true resid norm 2.573035498554e+04 ||r(i)||/||b|| 9.075962957862e-01
184 KSP Residual norm 4.11041e+07
185 KSP preconditioned resid norm 4.110493904669e+07 true resid norm 2.573035852944e+04 ||r(i)||/||b|| 9.075964207915e-01
185 KSP Residual norm 4.11049e+07
186 KSP preconditioned resid norm 4.665669250590e+07 true resid norm 2.575925122542e+04 ||r(i)||/||b|| 9.086155635068e-01
186 KSP Residual norm 4.66567e+07
187 KSP preconditioned resid norm 4.665810410629e+07 true resid norm 2.575925994183e+04 ||r(i)||/||b|| 9.086158709641e-01
187 KSP Residual norm 4.66581e+07
188 KSP preconditioned resid norm 4.666263340378e+07 true resid norm 2.575928786768e+04 ||r(i)||/||b|| 9.086168560029e-01
188 KSP Residual norm 4.66626e+07
189 KSP preconditioned resid norm 4.626669770877e+07 true resid norm 2.575678257532e+04 ||r(i)||/||b|| 9.085284859019e-01
189 KSP Residual norm 4.62667e+07
190 KSP preconditioned resid norm 4.620748644461e+07 true resid norm 2.575646291068e+04 ||r(i)||/||b|| 9.085172102534e-01
190 KSP Residual norm 4.62075e+07
191 KSP preconditioned resid norm 4.632759772995e+07 true resid norm 2.575717683196e+04 ||r(i)||/||b|| 9.085423926619e-01
191 KSP Residual norm 4.63276e+07
192 KSP preconditioned resid norm 4.631864478318e+07 true resid norm 2.575712422051e+04 ||r(i)||/||b|| 9.085405368787e-01
192 KSP Residual norm 4.63186e+07
193 KSP preconditioned resid norm 4.632152855513e+07 true resid norm 2.575713994644e+04 ||r(i)||/||b|| 9.085410915852e-01
193 KSP Residual norm 4.63215e+07
194 KSP preconditioned resid norm 4.632228862988e+07 true resid norm 2.575714466753e+04 ||r(i)||/||b|| 9.085412581140e-01
194 KSP Residual norm 4.63223e+07
195 KSP preconditioned resid norm 4.632227766263e+07 true resid norm 2.575714466849e+04 ||r(i)||/||b|| 9.085412581477e-01
195 KSP Residual norm 4.63223e+07
196 KSP preconditioned resid norm 4.631487133291e+07 true resid norm 2.575703630753e+04 ||r(i)||/||b|| 9.085374358916e-01
196 KSP Residual norm 4.63149e+07
197 KSP preconditioned resid norm 4.631488029126e+07 true resid norm 2.575704583406e+04 ||r(i)||/||b|| 9.085377719244e-01
197 KSP Residual norm 4.63149e+07
198 KSP preconditioned resid norm 4.632566198860e+07 true resid norm 2.575699519567e+04 ||r(i)||/||b|| 9.085359857378e-01
198 KSP Residual norm 4.63257e+07
199 KSP preconditioned resid norm 4.632226688620e+07 true resid norm 2.575699473520e+04 ||r(i)||/||b|| 9.085359694956e-01
199 KSP Residual norm 4.63223e+07
200 KSP preconditioned resid norm 4.632225655099e+07 true resid norm 2.575699469705e+04 ||r(i)||/||b|| 9.085359681500e-01
200 KSP Residual norm 4.63223e+07
201 KSP preconditioned resid norm 4.633086727249e+07 true resid norm 2.575702312484e+04 ||r(i)||/||b|| 9.085369708940e-01
201 KSP Residual norm 4.63309e+07
202 KSP preconditioned resid norm 4.630387372316e+07 true resid norm 2.575692877878e+04 ||r(i)||/||b|| 9.085336429905e-01
202 KSP Residual norm 4.63039e+07
203 KSP preconditioned resid norm 4.613960410187e+07 true resid norm 2.575635581328e+04 ||r(i)||/||b|| 9.085134325674e-01
203 KSP Residual norm 4.61396e+07
204 KSP preconditioned resid norm 4.611641031108e+07 true resid norm 2.575627327847e+04 ||r(i)||/||b|| 9.085105212864e-01
204 KSP Residual norm 4.61164e+07
205 KSP preconditioned resid norm 4.611624745847e+07 true resid norm 2.575627303518e+04 ||r(i)||/||b|| 9.085105127049e-01
205 KSP Residual norm 4.61162e+07
206 KSP preconditioned resid norm 4.522026679241e+07 true resid norm 2.574084144820e+04 ||r(i)||/||b|| 9.079661886489e-01
206 KSP Residual norm 4.52203e+07
207 KSP preconditioned resid norm 4.440654191250e+07 true resid norm 2.574083736616e+04 ||r(i)||/||b|| 9.079660446617e-01
207 KSP Residual norm 4.44065e+07
208 KSP preconditioned resid norm 4.435532670230e+07 true resid norm 2.574084204541e+04 ||r(i)||/||b|| 9.079662097145e-01
208 KSP Residual norm 4.43553e+07
209 KSP preconditioned resid norm 4.435529161412e+07 true resid norm 2.574084205091e+04 ||r(i)||/||b|| 9.079662099086e-01
209 KSP Residual norm 4.43553e+07
210 KSP preconditioned resid norm 5.008864960243e+07 true resid norm 2.570344416601e+04 ||r(i)||/||b|| 9.066470605296e-01
210 KSP Residual norm 5.00886e+07
211 KSP preconditioned resid norm 5.008665719311e+07 true resid norm 2.570345353484e+04 ||r(i)||/||b|| 9.066473909995e-01
211 KSP Residual norm 5.00867e+07
212 KSP preconditioned resid norm 4.873328531855e+07 true resid norm 2.571033463076e+04 ||r(i)||/||b|| 9.068901104325e-01
212 KSP Residual norm 4.87333e+07
213 KSP preconditioned resid norm 4.872391062208e+07 true resid norm 2.571033841344e+04 ||r(i)||/||b|| 9.068902438603e-01
213 KSP Residual norm 4.87239e+07
214 KSP preconditioned resid norm 1.285333990139e+07 true resid norm 2.633261896477e+04 ||r(i)||/||b|| 9.288401751240e-01
214 KSP Residual norm 1.28533e+07
215 KSP preconditioned resid norm 1.375301658571e+07 true resid norm 2.630366478461e+04 ||r(i)||/||b|| 9.278188636548e-01
215 KSP Residual norm 1.3753e+07
216 KSP preconditioned resid norm 6.463279915453e+07 true resid norm 2.570172838821e+04 ||r(i)||/||b|| 9.065865392666e-01
216 KSP Residual norm 6.46328e+07
217 KSP preconditioned resid norm 6.462779374862e+07 true resid norm 2.570170607518e+04 ||r(i)||/||b|| 9.065857522108e-01
217 KSP Residual norm 6.46278e+07
218 KSP preconditioned resid norm 6.291711309111e+07 true resid norm 2.569509155679e+04 ||r(i)||/||b|| 9.063524358656e-01
218 KSP Residual norm 6.29171e+07
219 KSP preconditioned resid norm 6.285783026106e+07 true resid norm 2.569506812611e+04 ||r(i)||/||b|| 9.063516093866e-01
219 KSP Residual norm 6.28578e+07
220 KSP preconditioned resid norm 6.303127974998e+07 true resid norm 2.569568787704e+04 ||r(i)||/||b|| 9.063734700895e-01
220 KSP Residual norm 6.30313e+07
221 KSP preconditioned resid norm 6.297318826605e+07 true resid norm 2.569549448922e+04 ||r(i)||/||b|| 9.063666486496e-01
221 KSP Residual norm 6.29732e+07
222 KSP preconditioned resid norm 6.260949091108e+07 true resid norm 2.569428853522e+04 ||r(i)||/||b|| 9.063241105899e-01
222 KSP Residual norm 6.26095e+07
223 KSP preconditioned resid norm 6.261557064067e+07 true resid norm 2.569432546223e+04 ||r(i)||/||b|| 9.063254131296e-01
223 KSP Residual norm 6.26156e+07
224 KSP preconditioned resid norm 5.951473226337e+06 true resid norm 2.667511060136e+04 ||r(i)||/||b|| 9.409210088664e-01
224 KSP Residual norm 5.95147e+06
225 KSP preconditioned resid norm 5.951452921487e+06 true resid norm 2.667498289716e+04 ||r(i)||/||b|| 9.409165043091e-01
225 KSP Residual norm 5.95145e+06
226 KSP preconditioned resid norm 5.951436438422e+06 true resid norm 2.667473247750e+04 ||r(i)||/||b|| 9.409076711640e-01
226 KSP Residual norm 5.95144e+06
227 KSP preconditioned resid norm 5.951443951506e+06 true resid norm 2.667474724075e+04 ||r(i)||/||b|| 9.409081919136e-01
227 KSP Residual norm 5.95144e+06
228 KSP preconditioned resid norm 5.951380888414e+06 true resid norm 2.667461051769e+04 ||r(i)||/||b|| 9.409033692306e-01
228 KSP Residual norm 5.95138e+06
229 KSP preconditioned resid norm 5.952408132430e+06 true resid norm 2.667643831927e+04 ||r(i)||/||b|| 9.409678419496e-01
229 KSP Residual norm 5.95241e+06
230 KSP preconditioned resid norm 5.953624680884e+06 true resid norm 2.667802076716e+04 ||r(i)||/||b|| 9.410236602173e-01
230 KSP Residual norm 5.95362e+06
231 KSP preconditioned resid norm 5.954824237410e+06 true resid norm 2.667928505223e+04 ||r(i)||/||b|| 9.410682558107e-01
231 KSP Residual norm 5.95482e+06
232 KSP preconditioned resid norm 5.952281807267e+06 true resid norm 2.667627989768e+04 ||r(i)||/||b|| 9.409622538866e-01
232 KSP Residual norm 5.95228e+06
233 KSP preconditioned resid norm 5.960861208790e+06 true resid norm 2.666047881324e+04 ||r(i)||/||b|| 9.404048964107e-01
233 KSP Residual norm 5.96086e+06
234 KSP preconditioned resid norm 5.956181940673e+06 true resid norm 2.666366484470e+04 ||r(i)||/||b|| 9.405172784728e-01
234 KSP Residual norm 5.95618e+06
235 KSP preconditioned resid norm 5.954538882390e+06 true resid norm 2.666564387831e+04 ||r(i)||/||b|| 9.405870856547e-01
235 KSP Residual norm 5.95454e+06
236 KSP preconditioned resid norm 5.954547537849e+06 true resid norm 2.666562361166e+04 ||r(i)||/||b|| 9.405863707816e-01
236 KSP Residual norm 5.95455e+06
237 KSP preconditioned resid norm 5.953797604275e+06 true resid norm 2.666685112942e+04 ||r(i)||/||b|| 9.406296694681e-01
237 KSP Residual norm 5.9538e+06
238 KSP preconditioned resid norm 5.954425350666e+06 true resid norm 2.666571870149e+04 ||r(i)||/||b|| 9.405897249204e-01
238 KSP Residual norm 5.95443e+06
239 KSP preconditioned resid norm 5.955718319708e+06 true resid norm 2.666397343198e+04 ||r(i)||/||b|| 9.405281633856e-01
239 KSP Residual norm 5.95572e+06
240 KSP preconditioned resid norm 5.954436274133e+06 true resid norm 2.666543763666e+04 ||r(i)||/||b|| 9.405798108168e-01
240 KSP Residual norm 5.95444e+06
241 KSP preconditioned resid norm 5.954724290986e+06 true resid norm 2.666512479036e+04 ||r(i)||/||b|| 9.405687756742e-01
241 KSP Residual norm 5.95472e+06
242 KSP preconditioned resid norm 5.954892822775e+06 true resid norm 2.666497154237e+04 ||r(i)||/||b|| 9.405633701011e-01
242 KSP Residual norm 5.95489e+06
243 KSP preconditioned resid norm 5.955127697992e+06 true resid norm 2.666482901545e+04 ||r(i)||/||b|| 9.405583426967e-01
243 KSP Residual norm 5.95513e+06
244 KSP preconditioned resid norm 5.955115610210e+06 true resid norm 2.666483414335e+04 ||r(i)||/||b|| 9.405585235748e-01
244 KSP Residual norm 5.95512e+06
245 KSP preconditioned resid norm 5.954981617954e+06 true resid norm 2.666486482168e+04 ||r(i)||/||b|| 9.405596057030e-01
245 KSP Residual norm 5.95498e+06
246 KSP preconditioned resid norm 5.955009279295e+06 true resid norm 2.666486597277e+04 ||r(i)||/||b|| 9.405596463057e-01
246 KSP Residual norm 5.95501e+06
247 KSP preconditioned resid norm 5.955037520489e+06 true resid norm 2.666486789677e+04 ||r(i)||/||b|| 9.405597141717e-01
247 KSP Residual norm 5.95504e+06
248 KSP preconditioned resid norm 5.955036670997e+06 true resid norm 2.666486859340e+04 ||r(i)||/||b|| 9.405597387444e-01
248 KSP Residual norm 5.95504e+06
249 KSP preconditioned resid norm 5.954620763678e+06 true resid norm 2.666525495155e+04 ||r(i)||/||b|| 9.405733668976e-01
249 KSP Residual norm 5.95462e+06
250 KSP preconditioned resid norm 5.955265027524e+06 true resid norm 2.666465617073e+04 ||r(i)||/||b|| 9.405522458810e-01
250 KSP Residual norm 5.95527e+06
251 KSP preconditioned resid norm 5.953687790205e+06 true resid norm 2.666656383150e+04 ||r(i)||/||b|| 9.406195355026e-01
251 KSP Residual norm 5.95369e+06
252 KSP preconditioned resid norm 5.953643908144e+06 true resid norm 2.666661477855e+04 ||r(i)||/||b|| 9.406213325767e-01
252 KSP Residual norm 5.95364e+06
253 KSP preconditioned resid norm 5.957968961882e+06 true resid norm 2.666267474144e+04 ||r(i)||/||b|| 9.404823541953e-01
253 KSP Residual norm 5.95797e+06
254 KSP preconditioned resid norm 5.967273485925e+06 true resid norm 2.665739200142e+04 ||r(i)||/||b|| 9.402960141594e-01
254 KSP Residual norm 5.96727e+06
255 KSP preconditioned resid norm 5.968317576988e+06 true resid norm 2.665691903179e+04 ||r(i)||/||b|| 9.402793309275e-01
255 KSP Residual norm 5.96832e+06
256 KSP preconditioned resid norm 5.966055859533e+06 true resid norm 2.665796386003e+04 ||r(i)||/||b|| 9.403161855390e-01
256 KSP Residual norm 5.96606e+06
257 KSP preconditioned resid norm 5.952086969114e+06 true resid norm 2.666902557238e+04 ||r(i)||/||b|| 9.407063693962e-01
257 KSP Residual norm 5.95209e+06
258 KSP preconditioned resid norm 5.955066442083e+06 true resid norm 2.667906281435e+04 ||r(i)||/||b|| 9.410604167318e-01
258 KSP Residual norm 5.95507e+06
259 KSP preconditioned resid norm 5.952126835134e+06 true resid norm 2.666833747433e+04 ||r(i)||/||b|| 9.406820978600e-01
259 KSP Residual norm 5.95213e+06
260 KSP preconditioned resid norm 5.952141519067e+06 true resid norm 2.666830175508e+04 ||r(i)||/||b|| 9.406808379219e-01
260 KSP Residual norm 5.95214e+06
261 KSP preconditioned resid norm 5.952673555778e+06 true resid norm 2.666732663998e+04 ||r(i)||/||b|| 9.406464423273e-01
261 KSP Residual norm 5.95267e+06
262 KSP preconditioned resid norm 5.952461287632e+06 true resid norm 2.666758592323e+04 ||r(i)||/||b|| 9.406555881210e-01
262 KSP Residual norm 5.95246e+06
263 KSP preconditioned resid norm 5.952476013743e+06 true resid norm 2.666756669234e+04 ||r(i)||/||b|| 9.406549097827e-01
263 KSP Residual norm 5.95248e+06
264 KSP preconditioned resid norm 6.012511087576e+06 true resid norm 2.670228582800e+04 ||r(i)||/||b|| 9.418795706526e-01
264 KSP Residual norm 6.01251e+06
265 KSP preconditioned resid norm 5.952693706888e+06 true resid norm 2.666759108019e+04 ||r(i)||/||b|| 9.406557700245e-01
265 KSP Residual norm 5.95269e+06
266 KSP preconditioned resid norm 5.952793800274e+06 true resid norm 2.666747297033e+04 ||r(i)||/||b|| 9.406516038917e-01
266 KSP Residual norm 5.95279e+06
267 KSP preconditioned resid norm 5.953160266475e+06 true resid norm 2.666704190510e+04 ||r(i)||/||b|| 9.406363987689e-01
267 KSP Residual norm 5.95316e+06
268 KSP preconditioned resid norm 5.952817182579e+06 true resid norm 2.666757659066e+04 ||r(i)||/||b|| 9.406552589297e-01
268 KSP Residual norm 5.95282e+06
269 KSP preconditioned resid norm 5.952829056250e+06 true resid norm 2.666756727152e+04 ||r(i)||/||b|| 9.406549302124e-01
269 KSP Residual norm 5.95283e+06
270 KSP preconditioned resid norm 5.952993865769e+06 true resid norm 2.666742456291e+04 ||r(i)||/||b|| 9.406498963990e-01
270 KSP Residual norm 5.95299e+06
271 KSP preconditioned resid norm 5.952743614295e+06 true resid norm 2.666765842124e+04 ||r(i)||/||b|| 9.406581453701e-01
271 KSP Residual norm 5.95274e+06
272 KSP preconditioned resid norm 5.954012172749e+06 true resid norm 2.666654603506e+04 ||r(i)||/||b|| 9.406189077622e-01
272 KSP Residual norm 5.95401e+06
273 KSP preconditioned resid norm 5.992303612445e+06 true resid norm 2.669997738981e+04 ||r(i)||/||b|| 9.417981442614e-01
273 KSP Residual norm 5.9923e+06
274 KSP preconditioned resid norm 6.001038839709e+06 true resid norm 2.670238837979e+04 ||r(i)||/||b|| 9.418831879996e-01
274 KSP Residual norm 6.00104e+06
275 KSP preconditioned resid norm 8.864701512063e+06 true resid norm 2.691280962987e+04 ||r(i)||/||b|| 9.493054543163e-01
275 KSP Residual norm 8.8647e+06
276 KSP preconditioned resid norm 6.837184933510e+06 true resid norm 2.656250168656e+04 ||r(i)||/||b|| 9.369489131062e-01
276 KSP Residual norm 6.83718e+06
277 KSP preconditioned resid norm 2.012493473966e+07 true resid norm 2.743622005883e+04 ||r(i)||/||b|| 9.677679033098e-01
277 KSP Residual norm 2.01249e+07
278 KSP preconditioned resid norm 2.220353164993e+07 true resid norm 2.753421762421e+04 ||r(i)||/||b|| 9.712246075558e-01
278 KSP Residual norm 2.22035e+07
279 KSP preconditioned resid norm 5.965928653692e+06 true resid norm 2.669063560619e+04 ||r(i)||/||b|| 9.414686280842e-01
279 KSP Residual norm 5.96593e+06
280 KSP preconditioned resid norm 5.958031121970e+06 true resid norm 2.666372707266e+04 ||r(i)||/||b|| 9.405194734625e-01
280 KSP Residual norm 5.95803e+06
281 KSP preconditioned resid norm 9.347845981984e+06 true resid norm 2.693713593549e+04 ||r(i)||/||b|| 9.501635250615e-01
281 KSP Residual norm 9.34785e+06
282 KSP preconditioned resid norm 9.434290706765e+06 true resid norm 2.694142914095e+04 ||r(i)||/||b|| 9.503149608802e-01
282 KSP Residual norm 9.43429e+06
283 KSP preconditioned resid norm 9.444985258628e+06 true resid norm 2.694195811744e+04 ||r(i)||/||b|| 9.503336196630e-01
283 KSP Residual norm 9.44499e+06
284 KSP preconditioned resid norm 8.902004262959e+06 true resid norm 2.691469745841e+04 ||r(i)||/||b|| 9.493720443883e-01
284 KSP Residual norm 8.902e+06
285 KSP preconditioned resid norm 9.190592344455e+06 true resid norm 2.692929705960e+04 ||r(i)||/||b|| 9.498870215026e-01
285 KSP Residual norm 9.19059e+06
286 KSP preconditioned resid norm 6.516380355017e+06 true resid norm 2.676843818641e+04 ||r(i)||/||b|| 9.442129871751e-01
286 KSP Residual norm 6.51638e+06
287 KSP preconditioned resid norm 6.626119704895e+06 true resid norm 2.677771617775e+04 ||r(i)||/||b|| 9.445402531833e-01
287 KSP Residual norm 6.62612e+06
288 KSP preconditioned resid norm 6.452387585878e+06 true resid norm 2.676267557617e+04 ||r(i)||/||b|| 9.440097204998e-01
288 KSP Residual norm 6.45239e+06
289 KSP preconditioned resid norm 6.210111022107e+06 true resid norm 2.673720628869e+04 ||r(i)||/||b|| 9.431113329345e-01
289 KSP Residual norm 6.21011e+06
290 KSP preconditioned resid norm 1.625917943102e+07 true resid norm 2.725770495958e+04 ||r(i)||/||b|| 9.614710744120e-01
290 KSP Residual norm 1.62592e+07
291 KSP preconditioned resid norm 1.130001123670e+07 true resid norm 2.637115751978e+04 ||r(i)||/||b|| 9.301995597805e-01
291 KSP Residual norm 1.13e+07
292 KSP preconditioned resid norm 6.815561788034e+06 true resid norm 2.679242945846e+04 ||r(i)||/||b|| 9.450592401575e-01
292 KSP Residual norm 6.81556e+06
293 KSP preconditioned resid norm 6.532669400752e+06 true resid norm 2.676985263634e+04 ||r(i)||/||b|| 9.442628795888e-01
293 KSP Residual norm 6.53267e+06
294 KSP preconditioned resid norm 6.048470192747e+06 true resid norm 2.671301519507e+04 ||r(i)||/||b|| 9.422580315721e-01
294 KSP Residual norm 6.04847e+06
295 KSP preconditioned resid norm 6.072339843866e+06 true resid norm 2.671738980538e+04 ||r(i)||/||b|| 9.424123388142e-01
295 KSP Residual norm 6.07234e+06
296 KSP preconditioned resid norm 6.116777518701e+06 true resid norm 2.672458449878e+04 ||r(i)||/||b|| 9.426661198865e-01
296 KSP Residual norm 6.11678e+06
297 KSP preconditioned resid norm 3.364141322146e+07 true resid norm 2.810600636459e+04 ||r(i)||/||b|| 9.913935225606e-01
297 KSP Residual norm 3.36414e+07
298 KSP preconditioned resid norm 5.948890530157e+06 true resid norm 2.667441749736e+04 ||r(i)||/||b|| 9.408965607533e-01
298 KSP Residual norm 5.94889e+06
299 KSP preconditioned resid norm 5.951518748847e+06 true resid norm 2.668119731354e+04 ||r(i)||/||b|| 9.411357077088e-01
299 KSP Residual norm 5.95152e+06
300 KSP preconditioned resid norm 1.044927296976e+07 true resid norm 2.640074675427e+04 ||r(i)||/||b|| 9.312432717557e-01
300 KSP Residual norm 1.04493e+07
301 KSP preconditioned resid norm 1.056430681083e+07 true resid norm 2.639663904991e+04 ||r(i)||/||b|| 9.310983791857e-01
301 KSP Residual norm 1.05643e+07
302 KSP preconditioned resid norm 1.004111410662e+07 true resid norm 2.641559875415e+04 ||r(i)||/||b|| 9.317671518219e-01
302 KSP Residual norm 1.00411e+07
303 KSP preconditioned resid norm 5.956968881367e+06 true resid norm 2.666434231230e+04 ||r(i)||/||b|| 9.405411750370e-01
303 KSP Residual norm 5.95697e+06
304 KSP preconditioned resid norm 6.138256681452e+06 true resid norm 2.672771306926e+04 ||r(i)||/||b|| 9.427764751063e-01
304 KSP Residual norm 6.13826e+06
305 KSP preconditioned resid norm 5.954241714167e+06 true resid norm 2.668390888394e+04 ||r(i)||/||b|| 9.412313539307e-01
305 KSP Residual norm 5.95424e+06
306 KSP preconditioned resid norm 6.010159270590e+06 true resid norm 2.664581405688e+04 ||r(i)||/||b|| 9.398876210538e-01
306 KSP Residual norm 6.01016e+06
307 KSP preconditioned resid norm 5.956518225731e+06 true resid norm 2.668555037080e+04 ||r(i)||/||b|| 9.412892547018e-01
307 KSP Residual norm 5.95652e+06
308 KSP preconditioned resid norm 6.159309785014e+06 true resid norm 2.673064838351e+04 ||r(i)||/||b|| 9.428800135276e-01
308 KSP Residual norm 6.15931e+06
309 KSP preconditioned resid norm 1.194967720748e+07 true resid norm 2.706085956022e+04 ||r(i)||/||b|| 9.545276740819e-01
309 KSP Residual norm 1.19497e+07
310 KSP preconditioned resid norm 1.336145584855e+07 true resid norm 2.712563259064e+04 ||r(i)||/||b|| 9.568124370597e-01
310 KSP Residual norm 1.33615e+07
311 KSP preconditioned resid norm 8.964691191590e+06 true resid norm 2.691806481035e+04 ||r(i)||/||b|| 9.494908222347e-01
311 KSP Residual norm 8.96469e+06
312 KSP preconditioned resid norm 8.736376917576e+06 true resid norm 2.690635239853e+04 ||r(i)||/||b|| 9.490776860152e-01
312 KSP Residual norm 8.73638e+06
313 KSP preconditioned resid norm 1.069242992348e+07 true resid norm 2.700227746742e+04 ||r(i)||/||b|| 9.524612863286e-01
313 KSP Residual norm 1.06924e+07
314 KSP preconditioned resid norm 9.023469334642e+06 true resid norm 2.692105099290e+04 ||r(i)||/||b|| 9.495961549523e-01
314 KSP Residual norm 9.02347e+06
315 KSP preconditioned resid norm 7.648645489992e+06 true resid norm 2.684675795438e+04 ||r(i)||/||b|| 9.469755892199e-01
315 KSP Residual norm 7.64865e+06
316 KSP preconditioned resid norm 7.317627423305e+06 true resid norm 2.682661073347e+04 ||r(i)||/||b|| 9.462649288703e-01
316 KSP Residual norm 7.31763e+06
317 KSP preconditioned resid norm 6.192705956930e+06 true resid norm 2.661676761094e+04 ||r(i)||/||b|| 9.388630550596e-01
317 KSP Residual norm 6.19271e+06
318 KSP preconditioned resid norm 9.176999099012e+06 true resid norm 2.644874439384e+04 ||r(i)||/||b|| 9.329363101884e-01
318 KSP Residual norm 9.177e+06
319 KSP preconditioned resid norm 5.949267576414e+06 true resid norm 2.667205809462e+04 ||r(i)||/||b|| 9.408133366709e-01
319 KSP Residual norm 5.94927e+06
320 KSP preconditioned resid norm 5.960257875352e+06 true resid norm 2.668791677393e+04 ||r(i)||/||b|| 9.413727257120e-01
320 KSP Residual norm 5.96026e+06
321 KSP preconditioned resid norm 6.017228573506e+06 true resid norm 2.664418369792e+04 ||r(i)||/||b|| 9.398301128014e-01
321 KSP Residual norm 6.01723e+06
322 KSP preconditioned resid norm 5.975714381365e+06 true resid norm 2.665564605683e+04 ||r(i)||/||b|| 9.402344288124e-01
322 KSP Residual norm 5.97571e+06
323 KSP preconditioned resid norm 6.068465133376e+06 true resid norm 2.671671260134e+04 ||r(i)||/||b|| 9.423884515465e-01
323 KSP Residual norm 6.06847e+06
324 KSP preconditioned resid norm 6.076606616885e+06 true resid norm 2.671812883072e+04 ||r(i)||/||b|| 9.424384067273e-01
324 KSP Residual norm 6.07661e+06
325 KSP preconditioned resid norm 6.045965191463e+06 true resid norm 2.671251770386e+04 ||r(i)||/||b|| 9.422404833814e-01
325 KSP Residual norm 6.04597e+06
326 KSP preconditioned resid norm 6.103168657457e+06 true resid norm 2.672249404203e+04 ||r(i)||/||b|| 9.425923824349e-01
326 KSP Residual norm 6.10317e+06
327 KSP preconditioned resid norm 6.407529905136e+06 true resid norm 2.675856096747e+04 ||r(i)||/||b|| 9.438645843905e-01
327 KSP Residual norm 6.40753e+06
328 KSP preconditioned resid norm 6.415532719976e+06 true resid norm 2.675932855985e+04 ||r(i)||/||b|| 9.438916599593e-01
328 KSP Residual norm 6.41553e+06
329 KSP preconditioned resid norm 7.248185051371e+06 true resid norm 2.682233611942e+04 ||r(i)||/||b|| 9.461141488332e-01
329 KSP Residual norm 7.24819e+06
330 KSP preconditioned resid norm 6.059876109036e+06 true resid norm 2.671517058161e+04 ||r(i)||/||b|| 9.423340593161e-01
330 KSP Residual norm 6.05988e+06
331 KSP preconditioned resid norm 6.136391329972e+06 true resid norm 2.672751195572e+04 ||r(i)||/||b|| 9.427693811541e-01
331 KSP Residual norm 6.13639e+06
332 KSP preconditioned resid norm 6.118047286073e+06 true resid norm 2.672481461828e+04 ||r(i)||/||b|| 9.426742369764e-01
332 KSP Residual norm 6.11805e+06
333 KSP preconditioned resid norm 6.101072366720e+06 true resid norm 2.672219610437e+04 ||r(i)||/||b|| 9.425818731700e-01
333 KSP Residual norm 6.10107e+06
334 KSP preconditioned resid norm 5.973355326508e+06 true resid norm 2.669388593460e+04 ||r(i)||/||b|| 9.415832781164e-01
334 KSP Residual norm 5.97336e+06
335 KSP preconditioned resid norm 5.977018243292e+06 true resid norm 2.669523195786e+04 ||r(i)||/||b|| 9.416307568909e-01
335 KSP Residual norm 5.97702e+06
336 KSP preconditioned resid norm 6.023483038848e+06 true resid norm 2.664271168322e+04 ||r(i)||/||b|| 9.397781898843e-01
336 KSP Residual norm 6.02348e+06
337 KSP preconditioned resid norm 5.948640374266e+06 true resid norm 2.667679485995e+04 ||r(i)||/||b|| 9.409804183402e-01
337 KSP Residual norm 5.94864e+06
338 KSP preconditioned resid norm 5.963777397633e+06 true resid norm 2.668981879637e+04 ||r(i)||/||b|| 9.414398164506e-01
338 KSP Residual norm 5.96378e+06
339 KSP preconditioned resid norm 6.029601820345e+06 true resid norm 2.670923687534e+04 ||r(i)||/||b|| 9.421247575077e-01
339 KSP Residual norm 6.0296e+06
340 KSP preconditioned resid norm 6.004680660719e+06 true resid norm 2.670343680259e+04 ||r(i)||/||b|| 9.419201694036e-01
340 KSP Residual norm 6.00468e+06
341 KSP preconditioned resid norm 6.017010571083e+06 true resid norm 2.670643792295e+04 ||r(i)||/||b|| 9.420260290281e-01
341 KSP Residual norm 6.01701e+06
342 KSP preconditioned resid norm 6.150883985772e+06 true resid norm 2.672959784238e+04 ||r(i)||/||b|| 9.428429574030e-01
342 KSP Residual norm 6.15088e+06
343 KSP preconditioned resid norm 6.021905215561e+06 true resid norm 2.670754920299e+04 ||r(i)||/||b|| 9.420652276186e-01
343 KSP Residual norm 6.02191e+06
344 KSP preconditioned resid norm 5.952861183777e+06 true resid norm 2.668278211691e+04 ||r(i)||/||b|| 9.411916090620e-01
344 KSP Residual norm 5.95286e+06
345 KSP preconditioned resid norm 6.106338548056e+06 true resid norm 2.672296766614e+04 ||r(i)||/||b|| 9.426090887526e-01
345 KSP Residual norm 6.10634e+06
346 KSP preconditioned resid norm 6.105492496792e+06 true resid norm 2.672283652613e+04 ||r(i)||/||b|| 9.426044630029e-01
346 KSP Residual norm 6.10549e+06
347 KSP preconditioned resid norm 6.085358538112e+06 true resid norm 2.671951882044e+04 ||r(i)||/||b|| 9.424874363472e-01
347 KSP Residual norm 6.08536e+06
348 KSP preconditioned resid norm 6.085943222038e+06 true resid norm 2.671961863242e+04 ||r(i)||/||b|| 9.424909570517e-01
348 KSP Residual norm 6.08594e+06
349 KSP preconditioned resid norm 6.092130919547e+06 true resid norm 2.672064456099e+04 ||r(i)||/||b|| 9.425271450086e-01
349 KSP Residual norm 6.09213e+06
350 KSP preconditioned resid norm 6.104606007013e+06 true resid norm 2.672264975742e+04 ||r(i)||/||b|| 9.425978750413e-01
350 KSP Residual norm 6.10461e+06
351 KSP preconditioned resid norm 6.108639544613e+06 true resid norm 2.672327741800e+04 ||r(i)||/||b|| 9.426200147444e-01
351 KSP Residual norm 6.10864e+06
352 KSP preconditioned resid norm 6.085018979329e+06 true resid norm 2.671950171148e+04 ||r(i)||/||b|| 9.424868328565e-01
352 KSP Residual norm 6.08502e+06
353 KSP preconditioned resid norm 6.101028132550e+06 true resid norm 2.672210491830e+04 ||r(i)||/||b|| 9.425786567303e-01
353 KSP Residual norm 6.10103e+06
354 KSP preconditioned resid norm 6.099765000056e+06 true resid norm 2.672190651832e+04 ||r(i)||/||b|| 9.425716584946e-01
354 KSP Residual norm 6.09977e+06
355 KSP preconditioned resid norm 6.170677159819e+06 true resid norm 2.673208202732e+04 ||r(i)||/||b|| 9.429305829742e-01
355 KSP Residual norm 6.17068e+06
356 KSP preconditioned resid norm 6.232971193231e+06 true resid norm 2.673983718918e+04 ||r(i)||/||b|| 9.432041336570e-01
356 KSP Residual norm 6.23297e+06
357 KSP preconditioned resid norm 6.153050902055e+06 true resid norm 2.672957050094e+04 ||r(i)||/||b|| 9.428419929784e-01
357 KSP Residual norm 6.15305e+06
358 KSP preconditioned resid norm 6.152441267711e+06 true resid norm 2.672949013517e+04 ||r(i)||/||b|| 9.428391582070e-01
358 KSP Residual norm 6.15244e+06
359 KSP preconditioned resid norm 6.158132650376e+06 true resid norm 2.673022700816e+04 ||r(i)||/||b|| 9.428651501995e-01
359 KSP Residual norm 6.15813e+06
360 KSP preconditioned resid norm 6.157183384449e+06 true resid norm 2.673010013641e+04 ||r(i)||/||b|| 9.428606750056e-01
360 KSP Residual norm 6.15718e+06
361 KSP preconditioned resid norm 6.157416773931e+06 true resid norm 2.673013303514e+04 ||r(i)||/||b|| 9.428618354546e-01
361 KSP Residual norm 6.15742e+06
362 KSP preconditioned resid norm 6.162295931170e+06 true resid norm 2.673098446477e+04 ||r(i)||/||b|| 9.428918682460e-01
362 KSP Residual norm 6.1623e+06
363 KSP preconditioned resid norm 6.162169979866e+06 true resid norm 2.673097792379e+04 ||r(i)||/||b|| 9.428916375234e-01
363 KSP Residual norm 6.16217e+06
364 KSP preconditioned resid norm 6.162182881845e+06 true resid norm 2.673097940205e+04 ||r(i)||/||b|| 9.428916896665e-01
364 KSP Residual norm 6.16218e+06
365 KSP preconditioned resid norm 6.162529906891e+06 true resid norm 2.673102643865e+04 ||r(i)||/||b|| 9.428933488061e-01
365 KSP Residual norm 6.16253e+06
366 KSP preconditioned resid norm 6.176179388176e+06 true resid norm 2.673285332274e+04 ||r(i)||/||b|| 9.429577891617e-01
366 KSP Residual norm 6.17618e+06
367 KSP preconditioned resid norm 6.179708231435e+06 true resid norm 2.673326995504e+04 ||r(i)||/||b|| 9.429724851867e-01
367 KSP Residual norm 6.17971e+06
368 KSP preconditioned resid norm 6.180460605632e+06 true resid norm 2.673336143910e+04 ||r(i)||/||b|| 9.429757121377e-01
368 KSP Residual norm 6.18046e+06
369 KSP preconditioned resid norm 3.990429967198e+07 true resid norm 2.836032319013e+04 ||r(i)||/||b|| 1.000364133691e+00
369 KSP Residual norm 3.99043e+07
370 KSP preconditioned resid norm 6.188023267733e+06 true resid norm 2.673424210235e+04 ||r(i)||/||b|| 9.430067760972e-01
370 KSP Residual norm 6.18802e+06
371 KSP preconditioned resid norm 6.174162483987e+06 true resid norm 2.673256620393e+04 ||r(i)||/||b|| 9.429476615142e-01
371 KSP Residual norm 6.17416e+06
372 KSP preconditioned resid norm 6.745485893120e+06 true resid norm 2.678395908023e+04 ||r(i)||/||b|| 9.447604613839e-01
372 KSP Residual norm 6.74549e+06
373 KSP preconditioned resid norm 6.723191749363e+06 true resid norm 2.678232940896e+04 ||r(i)||/||b|| 9.447029773885e-01
373 KSP Residual norm 6.72319e+06
374 KSP preconditioned resid norm 6.459654470197e+06 true resid norm 2.676137199795e+04 ||r(i)||/||b|| 9.439637389048e-01
374 KSP Residual norm 6.45965e+06
375 KSP preconditioned resid norm 6.438944635358e+06 true resid norm 2.675955927385e+04 ||r(i)||/||b|| 9.438997980194e-01
375 KSP Residual norm 6.43894e+06
376 KSP preconditioned resid norm 1.644524650187e+07 true resid norm 2.724141842109e+04 ||r(i)||/||b|| 9.608965933365e-01
376 KSP Residual norm 1.64452e+07
377 KSP preconditioned resid norm 6.233771932173e+06 true resid norm 2.673945213827e+04 ||r(i)||/||b|| 9.431905516146e-01
377 KSP Residual norm 6.23377e+06
378 KSP preconditioned resid norm 6.139347294498e+06 true resid norm 2.672809538720e+04 ||r(i)||/||b|| 9.427899607477e-01
378 KSP Residual norm 6.13935e+06
379 KSP preconditioned resid norm 6.126283910384e+06 true resid norm 2.672635255979e+04 ||r(i)||/||b|| 9.427284853542e-01
379 KSP Residual norm 6.12628e+06
380 KSP preconditioned resid norm 6.144087308685e+06 true resid norm 2.672871127174e+04 ||r(i)||/||b|| 9.428116850701e-01
380 KSP Residual norm 6.14409e+06
381 KSP preconditioned resid norm 6.162121380642e+06 true resid norm 2.673102806989e+04 ||r(i)||/||b|| 9.428934063452e-01
381 KSP Residual norm 6.16212e+06
382 KSP preconditioned resid norm 6.158572929408e+06 true resid norm 2.673058448026e+04 ||r(i)||/||b|| 9.428777594447e-01
382 KSP Residual norm 6.15857e+06
383 KSP preconditioned resid norm 6.156595492465e+06 true resid norm 2.673033133593e+04 ||r(i)||/||b|| 9.428688301915e-01
383 KSP Residual norm 6.1566e+06
384 KSP preconditioned resid norm 6.301780916700e+06 true resid norm 2.674681049680e+04 ||r(i)||/||b|| 9.434501057071e-01
384 KSP Residual norm 6.30178e+06
385 KSP preconditioned resid norm 6.043288762072e+06 true resid norm 2.671361085048e+04 ||r(i)||/||b|| 9.422790423451e-01
385 KSP Residual norm 6.04329e+06
386 KSP preconditioned resid norm 6.042773373963e+06 true resid norm 2.671352169258e+04 ||r(i)||/||b|| 9.422758974456e-01
386 KSP Residual norm 6.04277e+06
387 KSP preconditioned resid norm 6.043271156395e+06 true resid norm 2.671361118941e+04 ||r(i)||/||b|| 9.422790543003e-01
387 KSP Residual norm 6.04327e+06
388 KSP preconditioned resid norm 6.195046113929e+06 true resid norm 2.673529946324e+04 ||r(i)||/||b|| 9.430440727773e-01
388 KSP Residual norm 6.19505e+06
389 KSP preconditioned resid norm 6.245467132962e+06 true resid norm 2.674106717309e+04 ||r(i)||/||b|| 9.432475193329e-01
389 KSP Residual norm 6.24547e+06
390 KSP preconditioned resid norm 6.157744861629e+06 true resid norm 2.673100181401e+04 ||r(i)||/||b|| 9.428924802118e-01
390 KSP Residual norm 6.15774e+06
391 KSP preconditioned resid norm 6.157825546529e+06 true resid norm 2.673102670870e+04 ||r(i)||/||b|| 9.428933583315e-01
391 KSP Residual norm 6.15783e+06
392 KSP preconditioned resid norm 6.162710568295e+06 true resid norm 2.673162180574e+04 ||r(i)||/||b|| 9.429143494087e-01
392 KSP Residual norm 6.16271e+06
393 KSP preconditioned resid norm 6.163289339885e+06 true resid norm 2.673169402058e+04 ||r(i)||/||b|| 9.429168966695e-01
393 KSP Residual norm 6.16329e+06
394 KSP preconditioned resid norm 6.275036548124e+06 true resid norm 2.674441045036e+04 ||r(i)||/||b|| 9.433654479845e-01
394 KSP Residual norm 6.27504e+06
395 KSP preconditioned resid norm 6.060232206207e+06 true resid norm 2.673618896793e+04 ||r(i)||/||b|| 9.430754486043e-01
395 KSP Residual norm 6.06023e+06
396 KSP preconditioned resid norm 5.886959913877e+06 true resid norm 2.673618896584e+04 ||r(i)||/||b|| 9.430754485306e-01
396 KSP Residual norm 5.88696e+06
397 KSP preconditioned resid norm 5.882454384223e+06 true resid norm 2.673605351925e+04 ||r(i)||/||b|| 9.430706708728e-01
397 KSP Residual norm 5.88245e+06
398 KSP preconditioned resid norm 5.866351182740e+06 true resid norm 2.673545538251e+04 ||r(i)||/||b|| 9.430495725755e-01
398 KSP Residual norm 5.86635e+06
399 KSP preconditioned resid norm 5.866994121511e+06 true resid norm 2.673576697924e+04 ||r(i)||/||b|| 9.430605636416e-01
399 KSP Residual norm 5.86699e+06
400 KSP preconditioned resid norm 5.865996585067e+06 true resid norm 2.673484474655e+04 ||r(i)||/||b|| 9.430280333879e-01
400 KSP Residual norm 5.866e+06
401 KSP preconditioned resid norm 5.862902513516e+06 true resid norm 2.673408093666e+04 ||r(i)||/||b|| 9.430010912403e-01
401 KSP Residual norm 5.8629e+06
402 KSP preconditioned resid norm 5.862852756009e+06 true resid norm 2.673409825349e+04 ||r(i)||/||b|| 9.430017020632e-01
402 KSP Residual norm 5.86285e+06
403 KSP preconditioned resid norm 5.865913216249e+06 true resid norm 2.673494667501e+04 ||r(i)||/||b|| 9.430316287481e-01
403 KSP Residual norm 5.86591e+06
404 KSP preconditioned resid norm 5.868232992976e+06 true resid norm 2.673479640020e+04 ||r(i)||/||b|| 9.430263280493e-01
404 KSP Residual norm 5.86823e+06
405 KSP preconditioned resid norm 5.868161684410e+06 true resid norm 2.673477300762e+04 ||r(i)||/||b|| 9.430255029142e-01
405 KSP Residual norm 5.86816e+06
406 KSP preconditioned resid norm 5.872447589118e+06 true resid norm 2.673596385423e+04 ||r(i)||/||b|| 9.430675080856e-01
406 KSP Residual norm 5.87245e+06
407 KSP preconditioned resid norm 5.869411778615e+06 true resid norm 2.673543733742e+04 ||r(i)||/||b|| 9.430489360641e-01
407 KSP Residual norm 5.86941e+06
408 KSP preconditioned resid norm 5.869375278981e+06 true resid norm 2.673543478003e+04 ||r(i)||/||b|| 9.430488458564e-01
408 KSP Residual norm 5.86938e+06
409 KSP preconditioned resid norm 5.870084978448e+06 true resid norm 2.673557480366e+04 ||r(i)||/||b|| 9.430537849615e-01
409 KSP Residual norm 5.87008e+06
410 KSP preconditioned resid norm 5.870852177283e+06 true resid norm 2.673579080032e+04 ||r(i)||/||b|| 9.430614038912e-01
410 KSP Residual norm 5.87085e+06
411 KSP preconditioned resid norm 5.871152607221e+06 true resid norm 2.673584922973e+04 ||r(i)||/||b|| 9.430634648934e-01
411 KSP Residual norm 5.87115e+06
412 KSP preconditioned resid norm 5.872092409618e+06 true resid norm 2.673603313134e+04 ||r(i)||/||b|| 9.430699517226e-01
412 KSP Residual norm 5.87209e+06
413 KSP preconditioned resid norm 5.870304292003e+06 true resid norm 2.673570437114e+04 ||r(i)||/||b|| 9.430583552429e-01
413 KSP Residual norm 5.8703e+06
414 KSP preconditioned resid norm 5.870313225844e+06 true resid norm 2.673572816302e+04 ||r(i)||/||b|| 9.430591944627e-01
414 KSP Residual norm 5.87031e+06
415 KSP preconditioned resid norm 5.870319043942e+06 true resid norm 2.673573415500e+04 ||r(i)||/||b|| 9.430594058201e-01
415 KSP Residual norm 5.87032e+06
416 KSP preconditioned resid norm 5.870722861882e+06 true resid norm 2.673616290295e+04 ||r(i)||/||b|| 9.430745292048e-01
416 KSP Residual norm 5.87072e+06
417 KSP preconditioned resid norm 5.870712110655e+06 true resid norm 2.673628777644e+04 ||r(i)||/||b|| 9.430789339133e-01
417 KSP Residual norm 5.87071e+06
418 KSP preconditioned resid norm 5.870710521847e+06 true resid norm 2.673629029179e+04 ||r(i)||/||b|| 9.430790226380e-01
418 KSP Residual norm 5.87071e+06
419 KSP preconditioned resid norm 5.870613304447e+06 true resid norm 2.673631527168e+04 ||r(i)||/||b|| 9.430799037628e-01
419 KSP Residual norm 5.87061e+06
420 KSP preconditioned resid norm 5.872614386167e+06 true resid norm 2.673622946174e+04 ||r(i)||/||b|| 9.430768769573e-01
420 KSP Residual norm 5.87261e+06
421 KSP preconditioned resid norm 5.872539494282e+06 true resid norm 2.673623001125e+04 ||r(i)||/||b|| 9.430768963405e-01
421 KSP Residual norm 5.87254e+06
422 KSP preconditioned resid norm 5.872550209733e+06 true resid norm 2.673622851161e+04 ||r(i)||/||b|| 9.430768434432e-01
422 KSP Residual norm 5.87255e+06
423 KSP preconditioned resid norm 5.874750656566e+06 true resid norm 2.673591517716e+04 ||r(i)||/||b|| 9.430657910816e-01
423 KSP Residual norm 5.87475e+06
424 KSP preconditioned resid norm 5.874967373367e+06 true resid norm 2.673588401701e+04 ||r(i)||/||b|| 9.430646919582e-01
424 KSP Residual norm 5.87497e+06
425 KSP preconditioned resid norm 5.911629538031e+06 true resid norm 2.673063363534e+04 ||r(i)||/||b|| 9.428794933102e-01
425 KSP Residual norm 5.91163e+06
426 KSP preconditioned resid norm 5.948281044839e+06 true resid norm 2.672543806441e+04 ||r(i)||/||b|| 9.426962280214e-01
426 KSP Residual norm 5.94828e+06
427 KSP preconditioned resid norm 5.910068655757e+06 true resid norm 2.673086553849e+04 ||r(i)||/||b|| 9.428876733152e-01
427 KSP Residual norm 5.91007e+06
428 KSP preconditioned resid norm 5.914064632057e+06 true resid norm 2.673029505437e+04 ||r(i)||/||b|| 9.428675504187e-01
428 KSP Residual norm 5.91406e+06
429 KSP preconditioned resid norm 5.927350852902e+06 true resid norm 2.672837375799e+04 ||r(i)||/||b|| 9.427997798232e-01
429 KSP Residual norm 5.92735e+06
430 KSP preconditioned resid norm 5.928399314681e+06 true resid norm 2.672822118816e+04 ||r(i)||/||b|| 9.427943981713e-01
430 KSP Residual norm 5.9284e+06
431 KSP preconditioned resid norm 5.919866502126e+06 true resid norm 2.672945841744e+04 ||r(i)||/||b|| 9.428380394160e-01
431 KSP Residual norm 5.91987e+06
432 KSP preconditioned resid norm 5.849919401647e+06 true resid norm 2.673972528732e+04 ||r(i)||/||b|| 9.432001865014e-01
432 KSP Residual norm 5.84992e+06
433 KSP preconditioned resid norm 5.886835954180e+06 true resid norm 2.673427575418e+04 ||r(i)||/||b|| 9.430079631104e-01
433 KSP Residual norm 5.88684e+06
434 KSP preconditioned resid norm 5.420593468173e+06 true resid norm 2.680844351757e+04 ||r(i)||/||b|| 9.456241099673e-01
434 KSP Residual norm 5.42059e+06
435 KSP preconditioned resid norm 6.040695319549e+06 true resid norm 2.671221565991e+04 ||r(i)||/||b|| 9.422298292739e-01
435 KSP Residual norm 6.0407e+06
436 KSP preconditioned resid norm 5.962578763028e+06 true resid norm 2.672329339848e+04 ||r(i)||/||b|| 9.426205784295e-01
436 KSP Residual norm 5.96258e+06
437 KSP preconditioned resid norm 5.928683402351e+06 true resid norm 2.672818818263e+04 ||r(i)||/||b|| 9.427932339553e-01
437 KSP Residual norm 5.92868e+06
438 KSP preconditioned resid norm 5.947807075642e+06 true resid norm 2.672542049841e+04 ||r(i)||/||b|| 9.426956084095e-01
438 KSP Residual norm 5.94781e+06
439 KSP preconditioned resid norm 5.973371195166e+06 true resid norm 2.672174327283e+04 ||r(i)||/||b|| 9.425659002762e-01
439 KSP Residual norm 5.97337e+06
440 KSP preconditioned resid norm 5.921543788702e+06 true resid norm 2.672922848178e+04 ||r(i)||/||b|| 9.428299288106e-01
440 KSP Residual norm 5.92154e+06
441 KSP preconditioned resid norm 5.887372979855e+06 true resid norm 2.673416865240e+04 ||r(i)||/||b|| 9.430041852697e-01
441 KSP Residual norm 5.88737e+06
442 KSP preconditioned resid norm 5.885220882800e+06 true resid norm 2.673448852179e+04 ||r(i)||/||b|| 9.430154681408e-01
442 KSP Residual norm 5.88522e+06
443 KSP preconditioned resid norm 5.887695484610e+06 true resid norm 2.673412478186e+04 ||r(i)||/||b|| 9.430026378082e-01
443 KSP Residual norm 5.8877e+06
444 KSP preconditioned resid norm 5.914882063326e+06 true resid norm 2.673014150251e+04 ||r(i)||/||b|| 9.428621341275e-01
444 KSP Residual norm 5.91488e+06
445 KSP preconditioned resid norm 5.917861145830e+06 true resid norm 2.672970900293e+04 ||r(i)||/||b|| 9.428468784104e-01
445 KSP Residual norm 5.91786e+06
446 KSP preconditioned resid norm 5.876638144030e+06 true resid norm 2.673574656826e+04 ||r(i)||/||b|| 9.430598436777e-01
446 KSP Residual norm 5.87664e+06
447 KSP preconditioned resid norm 5.897899345913e+06 true resid norm 2.673262596706e+04 ||r(i)||/||b|| 9.429497695611e-01
447 KSP Residual norm 5.8979e+06
448 KSP preconditioned resid norm 5.864754809823e+06 true resid norm 2.673749545145e+04 ||r(i)||/||b|| 9.431215326792e-01
448 KSP Residual norm 5.86475e+06
449 KSP preconditioned resid norm 6.046049235198e+06 true resid norm 2.671145984820e+04 ||r(i)||/||b|| 9.422031692486e-01
449 KSP Residual norm 6.04605e+06
450 KSP preconditioned resid norm 5.831499222021e+06 true resid norm 2.674246554899e+04 ||r(i)||/||b|| 9.432968447616e-01
450 KSP Residual norm 5.8315e+06
451 KSP preconditioned resid norm 5.821752090917e+06 true resid norm 2.674392170063e+04 ||r(i)||/||b|| 9.433482081352e-01
451 KSP Residual norm 5.82175e+06
452 KSP preconditioned resid norm 5.619904638176e+06 true resid norm 2.677517566648e+04 ||r(i)||/||b|| 9.444506407931e-01
452 KSP Residual norm 5.6199e+06
453 KSP preconditioned resid norm 5.659430027936e+06 true resid norm 2.676888436656e+04 ||r(i)||/||b|| 9.442287254519e-01
453 KSP Residual norm 5.65943e+06
454 KSP preconditioned resid norm 5.090840094209e+06 true resid norm 2.687035380244e+04 ||r(i)||/||b|| 9.478078942661e-01
454 KSP Residual norm 5.09084e+06
455 KSP preconditioned resid norm 5.059438412116e+06 true resid norm 2.687685701225e+04 ||r(i)||/||b|| 9.480372843828e-01
455 KSP Residual norm 5.05944e+06
456 KSP preconditioned resid norm 4.354075731287e+06 true resid norm 2.710550680461e+04 ||r(i)||/||b|| 9.561025327903e-01
456 KSP Residual norm 4.35408e+06
457 KSP preconditioned resid norm 4.332147364834e+06 true resid norm 2.712309210809e+04 ||r(i)||/||b|| 9.567228256822e-01
457 KSP Residual norm 4.33215e+06
458 KSP preconditioned resid norm 1.252283757306e+07 true resid norm 2.923278795156e+04 ||r(i)||/||b|| 1.031138904817e+00
458 KSP Residual norm 1.25228e+07
459 KSP preconditioned resid norm 5.330263954308e+07 true resid norm 4.172881583021e+04 ||r(i)||/||b|| 1.471915902300e+00
459 KSP Residual norm 5.33026e+07
460 KSP preconditioned resid norm 3.426586316442e+07 true resid norm 2.741216468015e+04 ||r(i)||/||b|| 9.669193890706e-01
460 KSP Residual norm 3.42659e+07
461 KSP preconditioned resid norm 3.081884008909e+07 true resid norm 2.696083881750e+04 ||r(i)||/||b|| 9.509996055555e-01
461 KSP Residual norm 3.08188e+07
462 KSP preconditioned resid norm 4.726753587093e+07 true resid norm 3.954735358786e+04 ||r(i)||/||b|| 1.394968380524e+00
462 KSP Residual norm 4.72675e+07
463 KSP preconditioned resid norm 4.727002625087e+07 true resid norm 3.954903049287e+04 ||r(i)||/||b|| 1.395027530613e+00
463 KSP Residual norm 4.727e+07
464 KSP preconditioned resid norm 1.115241415121e+08 true resid norm 5.174746662674e+04 ||r(i)||/||b|| 1.825307464788e+00
464 KSP Residual norm 1.11524e+08
465 KSP preconditioned resid norm 1.106657129072e+08 true resid norm 5.139986237805e+04 ||r(i)||/||b|| 1.813046291995e+00
465 KSP Residual norm 1.10666e+08
466 KSP preconditioned resid norm 2.036616378433e+07 true resid norm 2.617109195465e+04 ||r(i)||/||b|| 9.231425733561e-01
466 KSP Residual norm 2.03662e+07
467 KSP preconditioned resid norm 2.431743441682e+07 true resid norm 2.636313424720e+04 ||r(i)||/||b|| 9.299165519296e-01
467 KSP Residual norm 2.43174e+07
468 KSP preconditioned resid norm 1.293223038219e+08 true resid norm 7.308863326511e+04 ||r(i)||/||b|| 2.578082302120e+00
468 KSP Residual norm 1.29322e+08
469 KSP preconditioned resid norm 1.306505584193e+08 true resid norm 7.367141718136e+04 ||r(i)||/||b|| 2.598639054016e+00
469 KSP Residual norm 1.30651e+08
470 KSP preconditioned resid norm 6.017859579428e+07 true resid norm 4.429976110464e+04 ||r(i)||/||b|| 1.562601802633e+00
470 KSP Residual norm 6.01786e+07
471 KSP preconditioned resid norm 6.020643494613e+07 true resid norm 4.431035081579e+04 ||r(i)||/||b|| 1.562975337418e+00
471 KSP Residual norm 6.02064e+07
472 KSP preconditioned resid norm 1.648190636840e+07 true resid norm 3.015795127640e+04 ||r(i)||/||b|| 1.063772531796e+00
472 KSP Residual norm 1.64819e+07
473 KSP preconditioned resid norm 1.678654654542e+07 true resid norm 3.023222623119e+04 ||r(i)||/||b|| 1.066392459654e+00
473 KSP Residual norm 1.67865e+07
474 KSP preconditioned resid norm 2.990585661773e+07 true resid norm 3.382931975141e+04 ||r(i)||/||b|| 1.193274065305e+00
474 KSP Residual norm 2.99059e+07
475 KSP preconditioned resid norm 2.794642572076e+07 true resid norm 3.324605421179e+04 ||r(i)||/||b|| 1.172700324931e+00
475 KSP Residual norm 2.79464e+07
476 KSP preconditioned resid norm 3.220771804545e+07 true resid norm 3.453294177537e+04 ||r(i)||/||b|| 1.218093184316e+00
476 KSP Residual norm 3.22077e+07
477 KSP preconditioned resid norm 3.226637187575e+07 true resid norm 3.455111842912e+04 ||r(i)||/||b|| 1.218734336124e+00
477 KSP Residual norm 3.22664e+07
478 KSP preconditioned resid norm 4.568794069470e+07 true resid norm 3.899614019644e+04 ||r(i)||/||b|| 1.375525227388e+00
478 KSP Residual norm 4.56879e+07
479 KSP preconditioned resid norm 4.597439118136e+07 true resid norm 3.909648230444e+04 ||r(i)||/||b|| 1.379064631550e+00
479 KSP Residual norm 4.59744e+07
480 KSP preconditioned resid norm 4.531242206955e+07 true resid norm 3.886495166911e+04 ||r(i)||/||b|| 1.370897766106e+00
480 KSP Residual norm 4.53124e+07
481 KSP preconditioned resid norm 4.597886084014e+07 true resid norm 3.909815559480e+04 ||r(i)||/||b|| 1.379123654137e+00
481 KSP Residual norm 4.59789e+07
482 KSP preconditioned resid norm 4.583299079565e+07 true resid norm 3.904702091007e+04 ||r(i)||/||b|| 1.377319961554e+00
482 KSP Residual norm 4.5833e+07
483 KSP preconditioned resid norm 4.744922463061e+07 true resid norm 3.961651731898e+04 ||r(i)||/||b|| 1.397408018306e+00
483 KSP Residual norm 4.74492e+07
484 KSP preconditioned resid norm 4.810709096378e+07 true resid norm 3.985011621074e+04 ||r(i)||/||b|| 1.405647838121e+00
484 KSP Residual norm 4.81071e+07
485 KSP preconditioned resid norm 2.720424239504e+07 true resid norm 3.302915485504e+04 ||r(i)||/||b|| 1.165049553970e+00
485 KSP Residual norm 2.72042e+07
486 KSP preconditioned resid norm 2.217433585684e+07 true resid norm 3.161834184189e+04 ||r(i)||/||b|| 1.115285426522e+00
486 KSP Residual norm 2.21743e+07
487 KSP preconditioned resid norm 2.624897393387e+07 true resid norm 2.650454492327e+04 ||r(i)||/||b|| 9.349045828313e-01
487 KSP Residual norm 2.6249e+07
488 KSP preconditioned resid norm 2.887097128217e+07 true resid norm 2.674576102580e+04 ||r(i)||/||b|| 9.434130873300e-01
488 KSP Residual norm 2.8871e+07
489 KSP preconditioned resid norm 1.473389763804e+07 true resid norm 2.974048308785e+04 ||r(i)||/||b|| 1.049047022499e+00
489 KSP Residual norm 1.47339e+07
490 KSP preconditioned resid norm 2.012896977572e+07 true resid norm 3.107627361113e+04 ||r(i)||/||b|| 1.096164854008e+00
490 KSP Residual norm 2.0129e+07
491 KSP preconditioned resid norm 4.082640569840e+07 true resid norm 2.850706801897e+04 ||r(i)||/||b|| 1.005540318129e+00
491 KSP Residual norm 4.08264e+07
492 KSP preconditioned resid norm 6.554163268985e+07 true resid norm 4.636032750297e+04 ||r(i)||/||b|| 1.635284920740e+00
492 KSP Residual norm 6.55416e+07
493 KSP preconditioned resid norm 3.849244987216e+08 true resid norm 1.749495763051e+05 ||r(i)||/||b|| 6.171060892596e+00
493 KSP Residual norm 3.84924e+08
494 KSP preconditioned resid norm 3.386629995338e+08 true resid norm 1.535181905433e+05 ||r(i)||/||b|| 5.415103722866e+00
494 KSP Residual norm 3.38663e+08
495 KSP preconditioned resid norm 8.086332641230e+08 true resid norm 3.879274952755e+05 ||r(i)||/||b|| 1.368350953353e+01
495 KSP Residual norm 8.08633e+08
496 KSP preconditioned resid norm 3.877702250967e+08 true resid norm 1.913505876741e+05 ||r(i)||/||b|| 6.749579812136e+00
496 KSP Residual norm 3.8777e+08
497 KSP preconditioned resid norm 3.701470147674e+08 true resid norm 1.680941988281e+05 ||r(i)||/||b|| 5.929248635913e+00
497 KSP Residual norm 3.70147e+08
498 KSP preconditioned resid norm 4.636258873424e+08 true resid norm 2.115366133631e+05 ||r(i)||/||b|| 7.461608936970e+00
498 KSP Residual norm 4.63626e+08
499 KSP preconditioned resid norm 8.234093186304e+07 true resid norm 5.307149600231e+04 ||r(i)||/||b|| 1.872010440998e+00
499 KSP Residual norm 8.23409e+07
500 KSP preconditioned resid norm 6.441236333647e+07 true resid norm 3.449592541526e+04 ||r(i)||/||b|| 1.216787492602e+00
500 KSP Residual norm 6.44124e+07
501 KSP preconditioned resid norm 1.392807652779e+08 true resid norm 6.333982561045e+04 ||r(i)||/||b|| 2.234209016242e+00
501 KSP Residual norm 1.39281e+08
502 KSP preconditioned resid norm 2.698937429089e+09 true resid norm 1.274306574171e+06 ||r(i)||/||b|| 4.494908550869e+01
502 KSP Residual norm 2.69894e+09
503 KSP preconditioned resid norm 2.048382897103e+09 true resid norm 9.538585553353e+05 ||r(i)||/||b|| 3.364580442100e+01
503 KSP Residual norm 2.04838e+09
504 KSP preconditioned resid norm 2.058664760080e+09 true resid norm 9.586818953937e+05 ||r(i)||/||b|| 3.381593987279e+01
504 KSP Residual norm 2.05866e+09
505 KSP preconditioned resid norm 5.534694162960e+09 true resid norm 2.604761121022e+06 ||r(i)||/||b|| 9.187869915420e+01
505 KSP Residual norm 5.53469e+09
506 KSP preconditioned resid norm 5.426384764347e+09 true resid norm 2.553942578487e+06 ||r(i)||/||b|| 9.008615797131e+01
506 KSP Residual norm 5.42638e+09
507 KSP preconditioned resid norm 7.894951650351e+08 true resid norm 3.789619412597e+05 ||r(i)||/||b|| 1.336726424197e+01
507 KSP Residual norm 7.89495e+08
508 KSP preconditioned resid norm 8.013576136793e+08 true resid norm 3.845152298676e+05 ||r(i)||/||b|| 1.356314743801e+01
508 KSP Residual norm 8.01358e+08
509 KSP preconditioned resid norm 3.260202552312e+09 true resid norm 1.522375685622e+06 ||r(i)||/||b|| 5.369931871681e+01
509 KSP Residual norm 3.2602e+09
510 KSP preconditioned resid norm 3.441702865892e+09 true resid norm 1.607529645431e+06 ||r(i)||/||b|| 5.670298572950e+01
510 KSP Residual norm 3.4417e+09
511 KSP preconditioned resid norm 6.580055878775e+09 true resid norm 3.080021790848e+06 ||r(i)||/||b|| 1.086427439452e+02
511 KSP Residual norm 6.58006e+09
512 KSP preconditioned resid norm 7.237093000147e+09 true resid norm 3.388309904924e+06 ||r(i)||/||b|| 1.195171042301e+02
512 KSP Residual norm 7.23709e+09
513 KSP preconditioned resid norm 1.391360509505e+09 true resid norm 6.457709485268e+05 ||r(i)||/||b|| 2.277851670289e+01
513 KSP Residual norm 1.39136e+09
514 KSP preconditioned resid norm 1.090652424906e+09 true resid norm 5.048172245720e+05 ||r(i)||/||b|| 1.780660404134e+01
514 KSP Residual norm 1.09065e+09
515 KSP preconditioned resid norm 1.559753442542e+09 true resid norm 7.399559857659e+05 ||r(i)||/||b|| 2.610074023866e+01
515 KSP Residual norm 1.55975e+09
516 KSP preconditioned resid norm 3.613425354107e+08 true resid norm 1.640154414100e+05 ||r(i)||/||b|| 5.785377122046e+00
516 KSP Residual norm 3.61343e+08
517 KSP preconditioned resid norm 6.435082514763e+08 true resid norm 2.954852966539e+05 ||r(i)||/||b|| 1.042276178673e+01
517 KSP Residual norm 6.43508e+08
518 KSP preconditioned resid norm 9.059161989933e+09 true resid norm 4.258444164145e+06 ||r(i)||/||b|| 1.502096706930e+02
518 KSP Residual norm 9.05916e+09
519 KSP preconditioned resid norm 7.736894009760e+09 true resid norm 3.638020139393e+06 ||r(i)||/||b|| 1.283252253754e+02
519 KSP Residual norm 7.73689e+09
520 KSP preconditioned resid norm 2.972208716440e+09 true resid norm 1.387272556206e+06 ||r(i)||/||b|| 4.893377623303e+01
520 KSP Residual norm 2.97221e+09
521 KSP preconditioned resid norm 3.157436604231e+09 true resid norm 1.474171980196e+06 ||r(i)||/||b|| 5.199901164713e+01
521 KSP Residual norm 3.15744e+09
522 KSP preconditioned resid norm 4.837209443760e+09 true resid norm 2.262284647511e+06 ||r(i)||/||b|| 7.979840026494e+01
522 KSP Residual norm 4.83721e+09
523 KSP preconditioned resid norm 5.479313026769e+09 true resid norm 2.563558678782e+06 ||r(i)||/||b|| 9.042535022158e+01
523 KSP Residual norm 5.47931e+09
524 KSP preconditioned resid norm 5.187907042841e+09 true resid norm 2.426829243870e+06 ||r(i)||/||b|| 8.560244246455e+01
524 KSP Residual norm 5.18791e+09
525 KSP preconditioned resid norm 5.232858994678e+09 true resid norm 2.447919943576e+06 ||r(i)||/||b|| 8.634638248946e+01
525 KSP Residual norm 5.23286e+09
526 KSP preconditioned resid norm 5.321560227271e+09 true resid norm 2.489540541444e+06 ||r(i)||/||b|| 8.781448117969e+01
526 KSP Residual norm 5.32156e+09
527 KSP preconditioned resid norm 5.483163075138e+09 true resid norm 2.565372093266e+06 ||r(i)||/||b|| 9.048931545911e+01
527 KSP Residual norm 5.48316e+09
528 KSP preconditioned resid norm 5.260197590801e+09 true resid norm 2.460749594656e+06 ||r(i)||/||b|| 8.679892750110e+01
528 KSP Residual norm 5.2602e+09
529 KSP preconditioned resid norm 5.269970551915e+09 true resid norm 2.465330380892e+06 ||r(i)||/||b|| 8.696050726249e+01
529 KSP Residual norm 5.26997e+09
530 KSP preconditioned resid norm 5.271283260202e+09 true resid norm 2.465946175103e+06 ||r(i)||/||b|| 8.698222839869e+01
530 KSP Residual norm 5.27128e+09
531 KSP preconditioned resid norm 5.222434288611e+09 true resid norm 2.443026724154e+06 ||r(i)||/||b|| 8.617378215709e+01
531 KSP Residual norm 5.22243e+09
532 KSP preconditioned resid norm 5.371199205748e+09 true resid norm 2.512827502335e+06 ||r(i)||/||b|| 8.863589073491e+01
532 KSP Residual norm 5.3712e+09
533 KSP preconditioned resid norm 5.779732758359e+09 true resid norm 2.704505819818e+06 ||r(i)||/||b|| 9.539703068142e+01
533 KSP Residual norm 5.77973e+09
534 KSP preconditioned resid norm 5.778811964051e+09 true resid norm 2.704074419189e+06 ||r(i)||/||b|| 9.538181372801e+01
534 KSP Residual norm 5.77881e+09
535 KSP preconditioned resid norm 5.985007831013e+09 true resid norm 2.800823362961e+06 ||r(i)||/||b|| 9.879447488400e+01
535 KSP Residual norm 5.98501e+09
536 KSP preconditioned resid norm 5.635276464513e+09 true resid norm 2.636726114866e+06 ||r(i)||/||b|| 9.300621216460e+01
536 KSP Residual norm 5.63528e+09
537 KSP preconditioned resid norm 3.471027330483e+09 true resid norm 1.621273123200e+06 ||r(i)||/||b|| 5.718776448679e+01
537 KSP Residual norm 3.47103e+09
538 KSP preconditioned resid norm 3.345964648464e+09 true resid norm 1.562598326233e+06 ||r(i)||/||b|| 5.511810674544e+01
538 KSP Residual norm 3.34596e+09
539 KSP preconditioned resid norm 3.677254003360e+09 true resid norm 1.718027010859e+06 ||r(i)||/||b|| 6.060060003029e+01
539 KSP Residual norm 3.67725e+09
540 KSP preconditioned resid norm 3.612498275204e+09 true resid norm 1.687644896510e+06 ||r(i)||/||b|| 5.952892051182e+01
540 KSP Residual norm 3.6125e+09
541 KSP preconditioned resid norm 3.504125433539e+09 true resid norm 1.636799973378e+06 ||r(i)||/||b|| 5.773544879639e+01
541 KSP Residual norm 3.50413e+09
542 KSP preconditioned resid norm 3.743210500103e+09 true resid norm 1.748971809565e+06 ||r(i)||/||b|| 6.169212732152e+01
542 KSP Residual norm 3.74321e+09
543 KSP preconditioned resid norm 3.410957948831e+09 true resid norm 1.593081149856e+06 ||r(i)||/||b|| 5.619333861926e+01
543 KSP Residual norm 3.41096e+09
544 KSP preconditioned resid norm 3.411652140993e+09 true resid norm 1.593407053399e+06 ||r(i)||/||b|| 5.620483433507e+01
544 KSP Residual norm 3.41165e+09
545 KSP preconditioned resid norm 8.402437936396e+08 true resid norm 3.875095416312e+05 ||r(i)||/||b|| 1.366876690057e+01
545 KSP Residual norm 8.40244e+08
546 KSP preconditioned resid norm 1.078009044619e+09 true resid norm 4.988791680064e+05 ||r(i)||/||b|| 1.759714878330e+01
546 KSP Residual norm 1.07801e+09
547 KSP preconditioned resid norm 1.329195937405e+10 true resid norm 6.229264087396e+06 ||r(i)||/||b|| 2.197271283032e+02
547 KSP Residual norm 1.3292e+10
548 KSP preconditioned resid norm 1.271109607840e+10 true resid norm 5.971877262550e+06 ||r(i)||/||b|| 2.106482279559e+02
548 KSP Residual norm 1.27111e+10
549 KSP preconditioned resid norm 4.352821212827e+09 true resid norm 2.034987196610e+06 ||r(i)||/||b|| 7.178085349596e+01
549 KSP Residual norm 4.35282e+09
550 KSP preconditioned resid norm 4.523714137688e+09 true resid norm 2.115167794848e+06 ||r(i)||/||b|| 7.460909329271e+01
550 KSP Residual norm 4.52371e+09
551 KSP preconditioned resid norm 6.258929719479e+08 true resid norm 2.872449451975e+05 ||r(i)||/||b|| 1.013209683236e+01
551 KSP Residual norm 6.25893e+08
552 KSP preconditioned resid norm 9.050704917967e+08 true resid norm 4.178724793739e+05 ||r(i)||/||b|| 1.473976999555e+01
552 KSP Residual norm 9.0507e+08
553 KSP preconditioned resid norm 1.257937276433e+09 true resid norm 5.984477952388e+05 ||r(i)||/||b|| 2.110926967332e+01
553 KSP Residual norm 1.25794e+09
554 KSP preconditioned resid norm 5.759657659036e+09 true resid norm 2.695073526986e+06 ||r(i)||/||b|| 9.506432193953e+01
554 KSP Residual norm 5.75966e+09
555 KSP preconditioned resid norm 2.941817101359e+09 true resid norm 1.373004741053e+06 ||r(i)||/||b|| 4.843050232992e+01
555 KSP Residual norm 2.94182e+09
556 KSP preconditioned resid norm 4.416137615440e+09 true resid norm 2.064710048852e+06 ||r(i)||/||b|| 7.282927861910e+01
556 KSP Residual norm 4.41614e+09
557 KSP preconditioned resid norm 4.875454526944e+09 true resid norm 2.280215972031e+06 ||r(i)||/||b|| 8.043089848435e+01
557 KSP Residual norm 4.87545e+09
558 KSP preconditioned resid norm 6.621026478002e+09 true resid norm 3.099241977930e+06 ||r(i)||/||b|| 1.093207046889e+02
558 KSP Residual norm 6.62103e+09
559 KSP preconditioned resid norm 1.010174436666e+10 true resid norm 4.732447823323e+06 ||r(i)||/||b|| 1.669293764840e+02
559 KSP Residual norm 1.01017e+10
560 KSP preconditioned resid norm 4.119820460107e+09 true resid norm 1.925644112913e+06 ||r(i)||/||b|| 6.792395460012e+01
560 KSP Residual norm 4.11982e+09
561 KSP preconditioned resid norm 4.132408041792e+09 true resid norm 1.931550063039e+06 ||r(i)||/||b|| 6.813227735586e+01
561 KSP Residual norm 4.13241e+09
562 KSP preconditioned resid norm 1.680803660677e+09 true resid norm 7.814806720868e+05 ||r(i)||/||b|| 2.756545580553e+01
562 KSP Residual norm 1.6808e+09
563 KSP preconditioned resid norm 1.618876050993e+09 true resid norm 7.524392792784e+05 ||r(i)||/||b|| 2.654106805215e+01
563 KSP Residual norm 1.61888e+09
564 KSP preconditioned resid norm 3.534234544482e+09 true resid norm 1.650964997302e+06 ||r(i)||/||b|| 5.823509690659e+01
564 KSP Residual norm 3.53423e+09
565 KSP preconditioned resid norm 3.541628605087e+09 true resid norm 1.654434390218e+06 ||r(i)||/||b|| 5.835747408177e+01
565 KSP Residual norm 3.54163e+09
566 KSP preconditioned resid norm 2.872588851518e+09 true resid norm 1.340541692644e+06 ||r(i)||/||b|| 4.728542125728e+01
566 KSP Residual norm 2.87259e+09
567 KSP preconditioned resid norm 2.901441355312e+09 true resid norm 1.354077783274e+06 ||r(i)||/||b|| 4.776288477156e+01
567 KSP Residual norm 2.90144e+09
568 KSP preconditioned resid norm 1.390864852589e+09 true resid norm 6.455390794249e+05 ||r(i)||/||b|| 2.277033789859e+01
568 KSP Residual norm 1.39086e+09
569 KSP preconditioned resid norm 1.348330473517e+09 true resid norm 6.255983068763e+05 ||r(i)||/||b|| 2.206695967818e+01
569 KSP Residual norm 1.34833e+09
570 KSP preconditioned resid norm 1.301999659102e+09 true resid norm 6.038783359575e+05 ||r(i)||/||b|| 2.130082313783e+01
570 KSP Residual norm 1.302e+09
571 KSP preconditioned resid norm 1.576916673224e+09 true resid norm 7.327782529348e+05 ||r(i)||/||b|| 2.584755742274e+01
571 KSP Residual norm 1.57692e+09
572 KSP preconditioned resid norm 1.313020443781e+09 true resid norm 6.090445238700e+05 ||r(i)||/||b|| 2.148305198836e+01
572 KSP Residual norm 1.31302e+09
573 KSP preconditioned resid norm 1.351594836754e+09 true resid norm 6.271301800096e+05 ||r(i)||/||b|| 2.212099400387e+01
573 KSP Residual norm 1.35159e+09
574 KSP preconditioned resid norm 1.344752288108e+09 true resid norm 6.239222779806e+05 ||r(i)||/||b|| 2.200784049314e+01
574 KSP Residual norm 1.34475e+09
575 KSP preconditioned resid norm 3.035602811150e+10 true resid norm 1.423612303742e+07 ||r(i)||/||b|| 5.021560154291e+02
575 KSP Residual norm 3.0356e+10
576 KSP preconditioned resid norm 1.378571700159e+10 true resid norm 6.460992934568e+06 ||r(i)||/||b|| 2.279009853463e+02
576 KSP Residual norm 1.37857e+10
577 KSP preconditioned resid norm 9.080063716650e+09 true resid norm 4.268279509638e+06 ||r(i)||/||b|| 1.505565964599e+02
577 KSP Residual norm 9.08006e+09
578 KSP preconditioned resid norm 1.803605799739e+10 true resid norm 8.470716537288e+06 ||r(i)||/||b|| 2.987907067826e+02
578 KSP Residual norm 1.80361e+10
579 KSP preconditioned resid norm 1.822987649743e+10 true resid norm 8.561662011548e+06 ||r(i)||/||b|| 3.019986600193e+02
579 KSP Residual norm 1.82299e+10
580 KSP preconditioned resid norm 8.745530772803e+08 true resid norm 4.187788157201e+05 ||r(i)||/||b|| 1.477173953157e+01
580 KSP Residual norm 8.74553e+08
581 KSP preconditioned resid norm 9.712023024459e+08 true resid norm 4.640497968378e+05 ||r(i)||/||b|| 1.636859953573e+01
581 KSP Residual norm 9.71202e+08
582 KSP preconditioned resid norm 5.936533329743e+09 true resid norm 2.793299676843e+06 ||r(i)||/||b|| 9.852908913028e+01
582 KSP Residual norm 5.93653e+09
583 KSP preconditioned resid norm 5.669506252006e+09 true resid norm 2.668017260388e+06 ||r(i)||/||b|| 9.410995627472e+01
583 KSP Residual norm 5.66951e+09
584 KSP preconditioned resid norm 5.889175183760e+09 true resid norm 2.771086510478e+06 ||r(i)||/||b|| 9.774555592514e+01
584 KSP Residual norm 5.88918e+09
585 KSP preconditioned resid norm 2.234226929620e+10 true resid norm 1.049120587455e+07 ||r(i)||/||b|| 3.700601719419e+02
585 KSP Residual norm 2.23423e+10
586 KSP preconditioned resid norm 2.006596838170e+09 true resid norm 9.495182044295e+05 ||r(i)||/||b|| 3.349270562361e+01
586 KSP Residual norm 2.0066e+09
587 KSP preconditioned resid norm 2.166607085629e+08 true resid norm 1.123338527548e+05 ||r(i)||/||b|| 3.962393395231e+00
587 KSP Residual norm 2.16661e+08
588 KSP preconditioned resid norm 2.568245189078e+09 true resid norm 1.213025616509e+06 ||r(i)||/||b|| 4.278749970049e+01
588 KSP Residual norm 2.56825e+09
589 KSP preconditioned resid norm 2.642305233460e+09 true resid norm 1.247768569849e+06 ||r(i)||/||b|| 4.401300070013e+01
589 KSP Residual norm 2.64231e+09
590 KSP preconditioned resid norm 8.707832682505e+09 true resid norm 4.093623674581e+06 ||r(i)||/||b|| 1.443958968106e+02
590 KSP Residual norm 8.70783e+09
591 KSP preconditioned resid norm 8.631006014000e+09 true resid norm 4.057554618108e+06 ||r(i)||/||b|| 1.431236196863e+02
591 KSP Residual norm 8.63101e+09
592 KSP preconditioned resid norm 8.624486395790e+09 true resid norm 4.054495558330e+06 ||r(i)||/||b|| 1.430157163432e+02
592 KSP Residual norm 8.62449e+09
593 KSP preconditioned resid norm 4.004531107957e+09 true resid norm 1.871528680658e+06 ||r(i)||/||b|| 6.601512101087e+01
593 KSP Residual norm 4.00453e+09
594 KSP preconditioned resid norm 3.973908626931e+09 true resid norm 1.857162197672e+06 ||r(i)||/||b|| 6.550836676093e+01
594 KSP Residual norm 3.97391e+09
595 KSP preconditioned resid norm 2.479182468996e+09 true resid norm 1.171186582854e+06 ||r(i)||/||b|| 4.131169604423e+01
595 KSP Residual norm 2.47918e+09
596 KSP preconditioned resid norm 2.717901477814e+09 true resid norm 1.283173789509e+06 ||r(i)||/||b|| 4.526186206379e+01
596 KSP Residual norm 2.7179e+09
597 KSP preconditioned resid norm 2.788802060454e+09 true resid norm 1.301208677550e+06 ||r(i)||/||b|| 4.589801331747e+01
597 KSP Residual norm 2.7888e+09
598 KSP preconditioned resid norm 1.899757041458e+10 true resid norm 8.906523807098e+06 ||r(i)||/||b|| 3.141630972521e+02
598 KSP Residual norm 1.89976e+10
599 KSP preconditioned resid norm 6.391932268100e+10 true resid norm 3.000014757986e+07 ||r(i)||/||b|| 1.058206263840e+03
599 KSP Residual norm 6.39193e+10
600 KSP preconditioned resid norm 2.126602497342e+11 true resid norm 9.979332763513e+07 ||r(i)||/||b|| 3.520046830163e+03
600 KSP Residual norm 2.1266e+11
601 KSP preconditioned resid norm 1.389826377513e+11 true resid norm 6.522189343371e+07 ||r(i)||/||b|| 2.300595888314e+03
601 KSP Residual norm 1.38983e+11
602 KSP preconditioned resid norm 3.130803748803e+10 true resid norm 1.468275247873e+07 ||r(i)||/||b|| 5.179101403431e+02
602 KSP Residual norm 3.1308e+10
603 KSP preconditioned resid norm 1.468849729238e+11 true resid norm 6.891407055349e+07 ||r(i)||/||b|| 2.430831412822e+03
603 KSP Residual norm 1.46885e+11
604 KSP preconditioned resid norm 3.786805213360e+11 true resid norm 1.776777712037e+08 ||r(i)||/||b|| 6.267293516887e+03
604 KSP Residual norm 3.78681e+11
605 KSP preconditioned resid norm 6.406846599292e+10 true resid norm 3.007343496095e+07 ||r(i)||/||b|| 1.060791356647e+03
605 KSP Residual norm 6.40685e+10
606 KSP preconditioned resid norm 6.412061862863e+10 true resid norm 3.009803564720e+07 ||r(i)||/||b|| 1.061659105722e+03
606 KSP Residual norm 6.41206e+10
607 KSP preconditioned resid norm 1.027315508480e+11 true resid norm 4.819613278430e+07 ||r(i)||/||b|| 1.700039957118e+03
607 KSP Residual norm 1.02732e+11
608 KSP preconditioned resid norm 1.041168254611e+11 true resid norm 4.884614085303e+07 ||r(i)||/||b|| 1.722967931324e+03
608 KSP Residual norm 1.04117e+11
609 KSP preconditioned resid norm 2.015350238956e+11 true resid norm 9.455585873981e+07 ||r(i)||/||b|| 3.335303659253e+03
609 KSP Residual norm 2.01535e+11
610 KSP preconditioned resid norm 2.025936632560e+11 true resid norm 9.505262809988e+07 ||r(i)||/||b|| 3.352826388003e+03
610 KSP Residual norm 2.02594e+11
611 KSP preconditioned resid norm 2.389238751714e+11 true resid norm 1.120993902007e+08 ||r(i)||/||b|| 3.954123111136e+03
611 KSP Residual norm 2.38924e+11
612 KSP preconditioned resid norm 2.090143906283e+13 true resid norm 9.807318971822e+09 ||r(i)||/||b|| 3.459371771366e+05
612 KSP Residual norm 2.09014e+13
613 KSP preconditioned resid norm 6.660277916237e+10 true resid norm 3.125401796874e+07 ||r(i)||/||b|| 1.102434496252e+03
613 KSP Residual norm 6.66028e+10
614 KSP preconditioned resid norm 2.689509339169e+12 true resid norm 1.261953110023e+09 ||r(i)||/||b|| 4.451333721423e+04
614 KSP Residual norm 2.68951e+12
615 KSP preconditioned resid norm 3.566249043550e+12 true resid norm 1.673344767935e+09 ||r(i)||/||b|| 5.902450680548e+04
615 KSP Residual norm 3.56625e+12
616 KSP preconditioned resid norm 5.701969015285e+12 true resid norm 2.675463681414e+09 ||r(i)||/||b|| 9.437261662837e+04
616 KSP Residual norm 5.70197e+12
617 KSP preconditioned resid norm 5.684152456409e+12 true resid norm 2.667104810678e+09 ||r(i)||/||b|| 9.407777109977e+04
617 KSP Residual norm 5.68415e+12
618 KSP preconditioned resid norm 4.799690188440e+12 true resid norm 2.252093686126e+09 ||r(i)||/||b|| 7.943893072756e+04
618 KSP Residual norm 4.79969e+12
619 KSP preconditioned resid norm 4.456285102277e+12 true resid norm 2.090967253175e+09 ||r(i)||/||b|| 7.375545866580e+04
619 KSP Residual norm 4.45629e+12
620 KSP preconditioned resid norm 3.612710385324e+12 true resid norm 1.695147730074e+09 ||r(i)||/||b|| 5.979357072570e+04
620 KSP Residual norm 3.61271e+12
621 KSP preconditioned resid norm 3.569097583385e+12 true resid norm 1.674683412493e+09 ||r(i)||/||b|| 5.907172530838e+04
621 KSP Residual norm 3.5691e+12
622 KSP preconditioned resid norm 6.852397549533e+12 true resid norm 3.215270734877e+09 ||r(i)||/||b|| 1.134134298016e+05
622 KSP Residual norm 6.8524e+12
623 KSP preconditioned resid norm 9.786811954989e+12 true resid norm 4.592158864976e+09 ||r(i)||/||b|| 1.619809123448e+05
623 KSP Residual norm 9.78681e+12
624 KSP preconditioned resid norm 1.786511420356e+12 true resid norm 8.382773150656e+08 ||r(i)||/||b|| 2.956886472895e+04
624 KSP Residual norm 1.78651e+12
625 KSP preconditioned resid norm 1.353469650693e+11 true resid norm 6.351398316650e+07 ||r(i)||/||b|| 2.240352139912e+03
625 KSP Residual norm 1.35347e+11
626 KSP preconditioned resid norm 1.614568993214e+13 true resid norm 7.575927648219e+09 ||r(i)||/||b|| 2.672284884733e+05
626 KSP Residual norm 1.61457e+13
627 KSP preconditioned resid norm 9.427769024718e+13 true resid norm 4.423735292175e+10 ||r(i)||/||b|| 1.560400455794e+06
627 KSP Residual norm 9.42777e+13
628 KSP preconditioned resid norm 1.408841064859e+13 true resid norm 6.610675956973e+09 ||r(i)||/||b|| 2.331808097698e+05
628 KSP Residual norm 1.40884e+13
629 KSP preconditioned resid norm 1.325568643299e+13 true resid norm 6.219942299464e+09 ||r(i)||/||b|| 2.193983174414e+05
629 KSP Residual norm 1.32557e+13
630 KSP preconditioned resid norm 6.751324718244e+14 true resid norm 3.167846617313e+11 ||r(i)||/||b|| 1.117406214220e+07
630 KSP Residual norm 6.75132e+14
631 KSP preconditioned resid norm 8.773027358359e+14 true resid norm 4.116469814677e+11 ||r(i)||/||b|| 1.452017571314e+07
631 KSP Residual norm 8.77303e+14
632 KSP preconditioned resid norm 1.749776678543e+14 true resid norm 8.210295300280e+10 ||r(i)||/||b|| 2.896047724967e+06
632 KSP Residual norm 1.74978e+14
633 KSP preconditioned resid norm 1.912746627652e+15 true resid norm 8.975060621240e+11 ||r(i)||/||b|| 3.165806215605e+07
633 KSP Residual norm 1.91275e+15
634 KSP preconditioned resid norm 3.215318591555e+14 true resid norm 1.508688418674e+11 ||r(i)||/||b|| 5.321652270455e+06
634 KSP Residual norm 3.21532e+14
635 KSP preconditioned resid norm 2.968948647718e+14 true resid norm 1.393086235816e+11 ||r(i)||/||b|| 4.913884429686e+06
635 KSP Residual norm 2.96895e+14
636 KSP preconditioned resid norm 4.101923333653e+14 true resid norm 1.924699473117e+11 ||r(i)||/||b|| 6.789063397239e+06
636 KSP Residual norm 4.10192e+14
637 KSP preconditioned resid norm 1.997583748488e+13 true resid norm 9.375436856608e+09 ||r(i)||/||b|| 3.307032400920e+05
637 KSP Residual norm 1.99758e+13
638 KSP preconditioned resid norm 1.158879067561e+16 true resid norm 5.437637409580e+12 ||r(i)||/||b|| 1.918037886977e+08
638 KSP Residual norm 1.15888e+16
639 KSP preconditioned resid norm 8.554993143100e+15 true resid norm 4.014135646375e+12 ||r(i)||/||b|| 1.415920862919e+08
639 KSP Residual norm 8.55499e+15
640 KSP preconditioned resid norm 7.603266202419e+14 true resid norm 3.567658068106e+11 ||r(i)||/||b|| 1.258433180990e+07
640 KSP Residual norm 7.60327e+14
641 KSP preconditioned resid norm 1.218457098690e+15 true resid norm 5.717349042883e+11 ||r(i)||/||b|| 2.016701602428e+07
641 KSP Residual norm 1.21846e+15
642 KSP preconditioned resid norm 2.100593811892e+15 true resid norm 9.856541630757e+11 ||r(i)||/||b|| 3.476734261290e+07
642 KSP Residual norm 2.10059e+15
643 KSP preconditioned resid norm 3.819735262072e+16 true resid norm 1.792333282474e+13 ||r(i)||/||b|| 6.322163253876e+08
643 KSP Residual norm 3.81974e+16
644 KSP preconditioned resid norm 3.759692271758e+17 true resid norm 1.764154044728e+14 ||r(i)||/||b|| 6.222765589869e+09
644 KSP Residual norm 3.75969e+17
Linear solve did not converge due to DIVERGED_DTOL iterations 644
KSP Object: 1 MPI processes
  type: bcgs
  maximum iterations=10000
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: hypre
    HYPRE BoomerAMG preconditioning
    HYPRE BoomerAMG: Cycle type V
    HYPRE BoomerAMG: Maximum number of levels 25
    HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
    HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
    HYPRE BoomerAMG: Threshold for strong coupling 0.25
    HYPRE BoomerAMG: Interpolation truncation factor 0
    HYPRE BoomerAMG: Interpolation: max elements per row 0
    HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
    HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
    HYPRE BoomerAMG: Maximum row sums 0.9
    HYPRE BoomerAMG: Sweeps down         1
    HYPRE BoomerAMG: Sweeps up           1
    HYPRE BoomerAMG: Sweeps on coarse    1
    HYPRE BoomerAMG: Relax down          SOR/Jacobi
    HYPRE BoomerAMG: Relax up            SOR/Jacobi
    HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
    HYPRE BoomerAMG: Relax weight  (all)      1
    HYPRE BoomerAMG: Outer relax weight (all) 1
    HYPRE BoomerAMG: Using CF-relaxation
    HYPRE BoomerAMG: Measure type        local
    HYPRE BoomerAMG: Coarsen type        Falgout
    HYPRE BoomerAMG: Interpolation type  classical
  linear system matrix = precond matrix:
  Mat Object:   1 MPI processes
    type: seqaij
    rows=9261, cols=9261
    total: nonzeros=53607, allocated nonzeros=0
    total number of mallocs used during MatSetValues calls =0
      has attached near null space
      not using I-node routines
-- Ramachandran --
Ran with -pc_type hypre -pc_hypre_boomeramg_relax_type_all SOR/Jacobi -ksp_monitor_true_residual -ksp_converged_reason -ksp_view
Dirichlet and Neumann conditions. Full Dirichlet converged in 3 iterations.
Calculating Electric Field.....done
Timing Info
     Solve 2.00000000e+00
 TimeSteps 0.00000000e+00
Poisson TimeSteps 0.00000000e+00
Number of lines read was 629.
  0 KSP preconditioned resid norm 1.540359898985e+05 true resid norm 1.336500000000e+05 ||r(i)||/||b|| 9.801980198020e-01
  0 KSP Residual norm 154036
  1 KSP preconditioned resid norm 3.037580792249e+04 true resid norm 1.230353657616e+04 ||r(i)||/||b|| 9.023495838768e-02
  1 KSP Residual norm 30375.8
  2 KSP preconditioned resid norm 1.431593445319e+04 true resid norm 5.747942627371e+03 ||r(i)||/||b|| 4.215579484687e-02
  2 KSP Residual norm 14315.9
  3 KSP preconditioned resid norm 8.780397692453e+03 true resid norm 2.925899916695e+03 ||r(i)||/||b|| 2.145874526362e-02
  3 KSP Residual norm 8780.4
  4 KSP preconditioned resid norm 6.032536676927e+03 true resid norm 2.087929190866e+03 ||r(i)||/||b|| 1.531301203422e-02
  4 KSP Residual norm 6032.54
  5 KSP preconditioned resid norm 4.428872582246e+03 true resid norm 1.395551190031e+03 ||r(i)||/||b|| 1.023506556678e-02
  5 KSP Residual norm 4428.87
  6 KSP preconditioned resid norm 3.389849551684e+03 true resid norm 1.110863580907e+03 ||r(i)||/||b|| 8.147147641413e-03
  6 KSP Residual norm 3389.85
  7 KSP preconditioned resid norm 2.671367553815e+03 true resid norm 8.204302056768e+02 ||r(i)||/||b|| 6.017089883951e-03
  7 KSP Residual norm 2671.37
  8 KSP preconditioned resid norm 2.148484718840e+03 true resid norm 6.837478708714e+02 ||r(i)||/||b|| 5.014652518309e-03
  8 KSP Residual norm 2148.48
  9 KSP preconditioned resid norm 1.754406364449e+03 true resid norm 5.309456048213e+02 ||r(i)||/||b|| 3.893990501073e-03
  9 KSP Residual norm 1754.41
 10 KSP preconditioned resid norm 1.448204946467e+03 true resid norm 4.528537657529e+02 ||r(i)||/||b|| 3.321259741495e-03
 10 KSP Residual norm 1448.2
 11 KSP preconditioned resid norm 1.205130040738e+03 true resid norm 3.613967059714e+02 ||r(i)||/||b|| 2.650507561213e-03
 11 KSP Residual norm 1205.13
 12 KSP preconditioned resid norm 1.008439047979e+03 true resid norm 3.118052248080e+02 ||r(i)||/||b|| 2.286800328625e-03
 12 KSP Residual norm 1008.44
 13 KSP preconditioned resid norm 8.473262200569e+02 true resid norm 2.525352420624e+02 ||r(i)||/||b|| 1.852110319490e-03
 13 KSP Residual norm 847.326
 14 KSP preconditioned resid norm 7.140693667767e+02 true resid norm 2.190350685949e+02 ||r(i)||/||b|| 1.606417811477e-03
 14 KSP Residual norm 714.069
 15 KSP preconditioned resid norm 6.033399186408e+02 true resid norm 1.789989840810e+02 ||r(i)||/||b|| 1.312790495643e-03
 15 KSP Residual norm 603.34
 16 KSP preconditioned resid norm 5.110035051480e+02 true resid norm 1.558072184780e+02 ||r(i)||/||b|| 1.142700538893e-03
 16 KSP Residual norm 511.004
 17 KSP preconditioned resid norm 4.338624290250e+02 true resid norm 1.282619796561e+02 ||r(i)||/||b|| 9.406819190032e-04
 17 KSP Residual norm 433.862
 18 KSP preconditioned resid norm 3.691700007838e+02 true resid norm 1.120008750407e+02 ||r(i)||/||b|| 8.214218924874e-04
 18 KSP Residual norm 369.17
 19 KSP preconditioned resid norm 3.146566239746e+02 true resid norm 9.274071234852e+01 ||r(i)||/||b|| 6.801665738799e-04
 19 KSP Residual norm 314.657
 20 KSP preconditioned resid norm 2.685107408726e+02 true resid norm 8.114285285810e+01 ||r(i)||/||b|| 5.951070983359e-04
 20 KSP Residual norm 268.511
 21 KSP preconditioned resid norm 2.292316391640e+02 true resid norm 6.743621765417e+01 ||r(i)||/||b|| 4.945817209693e-04
 21 KSP Residual norm 229.232
 22 KSP preconditioned resid norm 1.955080412755e+02 true resid norm 5.902702158239e+01 ||r(i)||/||b|| 4.329081157491e-04
 22 KSP Residual norm 195.508
 23 KSP preconditioned resid norm 1.661358980302e+02 true resid norm 4.893016734462e+01 ||r(i)||/||b|| 3.588571129052e-04
 23 KSP Residual norm 166.136
 24 KSP preconditioned resid norm 1.400334850437e+02 true resid norm 4.248822227459e+01 ||r(i)||/||b|| 3.116114578261e-04
 24 KSP Residual norm 140.033
 25 KSP preconditioned resid norm 1.163318134976e+02 true resid norm 3.442152556522e+01 ||r(i)||/||b|| 2.524497657882e-04
 25 KSP Residual norm 116.332
 26 KSP preconditioned resid norm 9.450622464265e+01 true resid norm 2.890197582903e+01 ||r(i)||/||b|| 2.119690196482e-04
 26 KSP Residual norm 94.5062
 27 KSP preconditioned resid norm 7.434686035562e+01 true resid norm 2.209463071066e+01 ||r(i)||/||b|| 1.620434962278e-04
 27 KSP Residual norm 74.3469
 28 KSP preconditioned resid norm 5.597944006410e+01 true resid norm 1.718058588584e+01 ||r(i)||/||b|| 1.260035635192e-04
 28 KSP Residual norm 55.9794
 29 KSP preconditioned resid norm 3.962006611039e+01 true resid norm 1.177119536249e+01 ||r(i)||/||b|| 8.633073239820e-05
 29 KSP Residual norm 39.6201
 30 KSP preconditioned resid norm 2.557015835542e+01 true resid norm 7.796897230909e+00 ||r(i)||/||b|| 5.718296465646e-05
 30 KSP Residual norm 25.5702
 31 KSP preconditioned resid norm 1.412797909469e+01 true resid norm 4.167690769824e+00 ||r(i)||/||b|| 3.056612225760e-05
 31 KSP Residual norm 14.128
 32 KSP preconditioned resid norm 6.123262077691e+00 true resid norm 1.859729204031e+00 ||r(i)||/||b|| 1.363937810070e-05
 32 KSP Residual norm 6.12326
 33 KSP preconditioned resid norm 2.570847989582e+00 true resid norm 8.145410612592e-01 ||r(i)||/||b|| 5.973898505751e-06
 33 KSP Residual norm 2.57085
 34 KSP preconditioned resid norm 1.695870150544e+00 true resid norm 6.562825967774e-01 ||r(i)||/||b|| 4.813220365071e-06
 34 KSP Residual norm 1.69587
 35 KSP preconditioned resid norm 1.329958833488e+00 true resid norm 4.059950884053e-01 ||r(i)||/||b|| 2.977595074480e-06
 35 KSP Residual norm 1.32996
 36 KSP preconditioned resid norm 9.747655138349e-01 true resid norm 3.465586076774e-01 ||r(i)||/||b|| 2.541683958030e-06
 36 KSP Residual norm 0.974766
 37 KSP preconditioned resid norm 7.490324984936e-01 true resid norm 2.480074017552e-01 ||r(i)||/||b|| 1.818902836488e-06
 37 KSP Residual norm 0.749032
 38 KSP preconditioned resid norm 4.943435684205e-01 true resid norm 1.470347806241e-01 ||r(i)||/||b|| 1.078362894199e-06
 38 KSP Residual norm 0.494344
 39 KSP preconditioned resid norm 3.084788637285e-01 true resid norm 1.626408346511e-01 ||r(i)||/||b|| 1.192818735981e-06
 39 KSP Residual norm 0.308479
 40 KSP preconditioned resid norm 2.606142931640e-02 true resid norm 7.663053412700e-03 ||r(i)||/||b|| 5.620134516098e-08
 40 KSP Residual norm 0.0260614
 41 KSP preconditioned resid norm 4.654756581390e-01 true resid norm 2.690546086115e-01 ||r(i)||/||b|| 1.973264456263e-06
 41 KSP Residual norm 0.465476
 42 KSP preconditioned resid norm 4.983426095489e-02 true resid norm 2.356674411751e-02 ||r(i)||/||b|| 1.728400742025e-07
 42 KSP Residual norm 0.0498343
 43 KSP preconditioned resid norm 2.506106421374e-02 true resid norm 7.194416846674e-03 ||r(i)||/||b|| 5.276433330894e-08
 43 KSP Residual norm 0.0250611
 44 KSP preconditioned resid norm 6.791580828568e-03 true resid norm 5.051841909812e-03 ||r(i)||/||b|| 3.705054572653e-08
 44 KSP Residual norm 0.00679158
 45 KSP preconditioned resid norm 7.135736697854e-03 true resid norm 2.074481391256e-03 ||r(i)||/||b|| 1.521438497437e-08
 45 KSP Residual norm 0.00713574
 46 KSP preconditioned resid norm 4.020631323929e-03 true resid norm 1.355065535193e-03 ||r(i)||/||b|| 9.938141072192e-09
 46 KSP Residual norm 0.00402063
 47 KSP preconditioned resid norm 2.057039990439e-03 true resid norm 1.371727147000e-03 ||r(i)||/||b|| 1.006033844518e-08
 47 KSP Residual norm 0.00205704
 48 KSP preconditioned resid norm 1.353446629420e-03 true resid norm 3.851655898770e-04 ||r(i)||/||b|| 2.824830142112e-09
 48 KSP Residual norm 0.00135345
 49 KSP preconditioned resid norm 2.553647882477e-04 true resid norm 1.863188574285e-04 ||r(i)||/||b|| 1.366474935303e-09
 49 KSP Residual norm 0.000255365
 50 KSP preconditioned resid norm 1.612173268317e-04 true resid norm 4.653561708770e-05 ||r(i)||/||b|| 3.412953215087e-10
 50 KSP Residual norm 0.000161217
 51 KSP preconditioned resid norm 1.137051022483e-04 true resid norm 3.292772361909e-05 ||r(i)||/||b|| 2.414941226189e-10
 51 KSP Residual norm 0.000113705
 52 KSP preconditioned resid norm 7.277578106383e-05 true resid norm 2.271587299792e-05 ||r(i)||/||b|| 1.665997286243e-10
 52 KSP Residual norm 7.27758e-05
 53 KSP preconditioned resid norm 6.105615488606e-05 true resid norm 2.478243215255e-05 ||r(i)||/||b|| 1.817560113865e-10
 53 KSP Residual norm 6.10562e-05
 54 KSP preconditioned resid norm 6.167791539833e-05 true resid norm 1.874624940809e-05 ||r(i)||/||b|| 1.374862442837e-10
 54 KSP Residual norm 6.16779e-05
 55 KSP preconditioned resid norm 5.608616574890e-05 true resid norm 1.689919986660e-05 ||r(i)||/||b|| 1.239398596744e-10
 55 KSP Residual norm 5.60862e-05
 56 KSP preconditioned resid norm 2.920504130814e-05 true resid norm 2.040313998501e-05 ||r(i)||/||b|| 1.496379903558e-10
 56 KSP Residual norm 2.9205e-05
 57 KSP preconditioned resid norm 2.072538301751e-05 true resid norm 5.908651320822e-06 ||r(i)||/||b|| 4.333444313034e-11
 57 KSP Residual norm 2.07254e-05
 58 KSP preconditioned resid norm 1.827939839330e-05 true resid norm 5.466508729321e-06 ||r(i)||/||b|| 4.009173985567e-11
 58 KSP Residual norm 1.82794e-05
Linear solve converged due to CONVERGED_RTOL iterations 58
  type: bcgs
  type: mg
    MG: type is MULTIPLICATIVE, levels=1 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_levels_0_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0959872, max = 1.05586
        Chebyshev: eigenvalues estimated using gmres with translations  [0 0.1; 0 1.1]
        KSP Object:        (mg_levels_0_esteig_)         1 MPI processes
          type: gmres
            GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
            GMRES: happy breakdown tolerance 1e-30
          maximum iterations=10, initial guess is zero
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
          using NONE norm type for convergence test
      maximum iterations=1, initial guess is zero
    PC Object:    (mg_levels_0_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
        type: seqaij
        rows=1030301, cols=1030301
        total: nonzeros=6.8521e+06, allocated nonzeros=0
    type: seqaij
-- Ramachandran --
Ran with -pc_type mg -pc_mg_galerkin -ksp_monitor_true_residual -ksp_converged_reason -ksp_view
Timing Info
     Solve 3.30000000e+01
  0 KSP preconditioned resid norm 1.584346428381e+05 true resid norm 1.336500000000e+05 ||r(i)||/||b|| 9.801980198020e-01
  0 KSP Residual norm 158435
  1 KSP preconditioned resid norm 3.329718554911e+04 true resid norm 1.314423605069e+04 ||r(i)||/||b|| 9.640070444218e-02
  1 KSP Residual norm 33297.2
  2 KSP preconditioned resid norm 1.648141546540e+04 true resid norm 6.460322005614e+03 ||r(i)||/||b|| 4.738043275111e-02
  2 KSP Residual norm 16481.4
  3 KSP preconditioned resid norm 1.061572613965e+04 true resid norm 3.490828142800e+03 ||r(i)||/||b|| 2.560196657719e-02
  3 KSP Residual norm 10615.7
  4 KSP preconditioned resid norm 7.663980481149e+03 true resid norm 2.600584917522e+03 ||r(i)||/||b|| 1.907286334816e-02
  4 KSP Residual norm 7663.98
  5 KSP preconditioned resid norm 5.922848799208e+03 true resid norm 1.847479847878e+03 ||r(i)||/||b|| 1.354954050515e-02
  5 KSP Residual norm 5922.85
  6 KSP preconditioned resid norm 4.780746481930e+03 true resid norm 1.540624138254e+03 ||r(i)||/||b|| 1.129904025122e-02
  6 KSP Residual norm 4780.75
  7 KSP preconditioned resid norm 3.982515401127e+03 true resid norm 1.212451741093e+03 ||r(i)||/||b|| 8.892201988217e-03
  7 KSP Residual norm 3982.52
  8 KSP preconditioned resid norm 3.394848744858e+03 true resid norm 1.063430700112e+03 ||r(i)||/||b|| 7.799271727993e-03
  8 KSP Residual norm 3394.85
  9 KSP preconditioned resid norm 2.946986523448e+03 true resid norm 8.843206088626e+02 ||r(i)||/||b|| 6.485666364962e-03
  9 KSP Residual norm 2946.99
 10 KSP preconditioned resid norm 2.594904096175e+03 true resid norm 7.983337243771e+02 ||r(i)||/||b|| 5.855032815380e-03
 10 KSP Residual norm 2594.9
 11 KSP preconditioned resid norm 2.311968790169e+03 true resid norm 6.870824933131e+02 ||r(i)||/||b|| 5.039108861849e-03
 11 KSP Residual norm 2311.97
 12 KSP preconditioned resid norm 2.079971665605e+03 true resid norm 6.318318176146e+02 ||r(i)||/||b|| 4.633896718846e-03
 12 KSP Residual norm 2079.97
 13 KSP preconditioned resid norm 1.886761216402e+03 true resid norm 5.568184911310e+02 ||r(i)||/||b|| 4.083743976025e-03
 13 KSP Residual norm 1886.76
 14 KSP preconditioned resid norm 1.723585875997e+03 true resid norm 5.186529765921e+02 ||r(i)||/||b|| 3.803835545230e-03
 14 KSP Residual norm 1723.59
 15 KSP preconditioned resid norm 1.584135487528e+03 true resid norm 4.650731464720e+02 ||r(i)||/||b|| 3.410877495211e-03
 15 KSP Residual norm 1584.14
 16 KSP preconditioned resid norm 1.463755818509e+03 true resid norm 4.372612193339e+02 ||r(i)||/||b|| 3.206902965412e-03
 16 KSP Residual norm 1463.76
 17 KSP preconditioned resid norm 1.358866173679e+03 true resid norm 3.973337643902e+02 ||r(i)||/||b|| 2.914072346096e-03
 17 KSP Residual norm 1358.87
 18 KSP preconditioned resid norm 1.266778761650e+03 true resid norm 3.762590528147e+02 ||r(i)||/||b|| 2.759509004875e-03
 18 KSP Residual norm 1266.78
 19 KSP preconditioned resid norm 1.185305963597e+03 true resid norm 3.455095285668e+02 ||r(i)||/||b|| 2.533989941817e-03
 19 KSP Residual norm 1185.31
 20 KSP preconditioned resid norm 1.112713644522e+03 true resid norm 3.290695809019e+02 ||r(i)||/||b|| 2.413418268441e-03
 20 KSP Residual norm 1112.71
 21 KSP preconditioned resid norm 1.047330743723e+03 true resid norm 3.046859841789e+02 ||r(i)||/||b|| 2.234587342713e-03
 21 KSP Residual norm 1047.33
 22 KSP preconditioned resid norm 9.872190361077e+02 true resid norm 2.915418293043e+02 ||r(i)||/||b|| 2.138187233622e-03
 22 KSP Residual norm 987.219
 23 KSP preconditioned resid norm 9.297158200274e+02 true resid norm 2.707299670068e+02 ||r(i)||/||b|| 1.985551646548e-03
 23 KSP Residual norm 929.716
 24 KSP preconditioned resid norm 8.711168180798e+02 true resid norm 2.585284824328e+02 ||r(i)||/||b|| 1.896065144355e-03
 24 KSP Residual norm 871.117
 25 KSP preconditioned resid norm 8.071257590769e+02 true resid norm 2.362350597501e+02 ||r(i)||/||b|| 1.732563694537e-03
 25 KSP Residual norm 807.126
 26 KSP preconditioned resid norm 7.337148004310e+02 true resid norm 2.198162674440e+02 ||r(i)||/||b|| 1.612147175974e-03
 26 KSP Residual norm 733.715
 27 KSP preconditioned resid norm 6.481079316784e+02 true resid norm 1.907931213373e+02 ||r(i)||/||b|| 1.399289485422e-03
 27 KSP Residual norm 648.108
 28 KSP preconditioned resid norm 5.498721728382e+02 true resid norm 1.657972791351e+02 ||r(i)||/||b|| 1.215968310489e-03
 28 KSP Residual norm 549.872
 29 KSP preconditioned resid norm 4.405443763836e+02 true resid norm 1.299168725341e+02 ||r(i)||/||b|| 9.528190138183e-04
 29 KSP Residual norm 440.544
 30 KSP preconditioned resid norm 3.240236086790e+02 true resid norm 9.742416896340e+01 ||r(i)||/||b|| 7.145153572674e-04
 30 KSP Residual norm 324.024
 31 KSP preconditioned resid norm 2.059166803676e+02 true resid norm 6.038871504357e+01 ||r(i)||/||b|| 4.428948664728e-04
 31 KSP Residual norm 205.917
 32 KSP preconditioned resid norm 9.928747101615e+01 true resid norm 2.942859533885e+01 ||r(i)||/||b|| 2.158312822798e-04
 32 KSP Residual norm 99.2875
 33 KSP preconditioned resid norm 3.081144236888e+01 true resid norm 9.001159617176e+00 ||r(i)||/||b|| 6.601510536983e-05
 33 KSP Residual norm 30.8114
 34 KSP preconditioned resid norm 9.499307885981e+00 true resid norm 3.197499073879e+00 ||r(i)||/||b|| 2.345067160894e-05
 34 KSP Residual norm 9.49931
 35 KSP preconditioned resid norm 6.301154502299e+00 true resid norm 2.131038916952e+00 ||r(i)||/||b|| 1.562918164248e-05
 35 KSP Residual norm 6.30115
 36 KSP preconditioned resid norm 5.232116757360e+00 true resid norm 1.680863714690e+00 ||r(i)||/||b|| 1.232756666440e-05
 36 KSP Residual norm 5.23212
 37 KSP preconditioned resid norm 4.383648958169e+00 true resid norm 1.503916846559e+00 ||r(i)||/||b|| 1.102982652408e-05
 37 KSP Residual norm 4.38365
 38 KSP preconditioned resid norm 3.496300521941e+00 true resid norm 1.019488875098e+00 ||r(i)||/||b|| 7.476999450667e-06
 38 KSP Residual norm 3.4963
 39 KSP preconditioned resid norm 1.329417775526e+00 true resid norm 6.305255432772e-01 ||r(i)||/||b|| 4.624316415674e-06
 39 KSP Residual norm 1.32942
 40 KSP preconditioned resid norm 1.173715165878e+00 true resid norm 3.391746525136e-01 ||r(i)||/||b|| 2.487529538054e-06
 40 KSP Residual norm 1.17372
 41 KSP preconditioned resid norm 1.010471503016e+00 true resid norm 2.898013854885e-01 ||r(i)||/||b|| 2.125422702519e-06
 41 KSP Residual norm 1.01047
 42 KSP preconditioned resid norm 5.986676220588e-01 true resid norm 3.726978951592e-01 ||r(i)||/||b|| 2.733391236958e-06
 42 KSP Residual norm 0.598668
 43 KSP preconditioned resid norm 3.865662538772e-01 true resid norm 1.104258914088e-01 ||r(i)||/||b|| 8.098708574169e-07
 43 KSP Residual norm 0.386566
 44 KSP preconditioned resid norm 3.873809044313e-01 true resid norm 1.199838094365e-01 ||r(i)||/||b|| 8.799692661280e-07
 44 KSP Residual norm 0.387381
 45 KSP preconditioned resid norm 2.363433250281e-01 true resid norm 1.144972173805e-01 ||r(i)||/||b|| 8.397302338134e-07
 45 KSP Residual norm 0.236343
 46 KSP preconditioned resid norm 1.677043408823e-01 true resid norm 4.861518916415e-02 ||r(i)||/||b|| 3.565470419080e-07
 46 KSP Residual norm 0.167704
 47 KSP preconditioned resid norm 1.210646694945e-01 true resid norm 4.991913563286e-02 ||r(i)||/||b|| 3.661102723349e-07
 47 KSP Residual norm 0.121065
 48 KSP preconditioned resid norm 1.178117227582e-01 true resid norm 3.372010481766e-02 ||r(i)||/||b|| 2.473054992128e-07
 48 KSP Residual norm 0.117812
 49 KSP preconditioned resid norm 1.101626826323e-01 true resid norm 3.628562416903e-02 ||r(i)||/||b|| 2.661211893585e-07
 49 KSP Residual norm 0.110163
 50 KSP preconditioned resid norm 8.417129350461e-02 true resid norm 2.581841783845e-02 ||r(i)||/||b|| 1.893539995486e-07
 50 KSP Residual norm 0.0841713
 51 KSP preconditioned resid norm 7.799903830399e-02 true resid norm 2.243536442089e-02 ||r(i)||/||b|| 1.645424599992e-07
 51 KSP Residual norm 0.077999
 52 KSP preconditioned resid norm 1.317723328638e-01 true resid norm 4.126139787619e-02 ||r(i)||/||b|| 3.026138458100e-07
 52 KSP Residual norm 0.131772
 53 KSP preconditioned resid norm 6.069947269632e-02 true resid norm 2.216505265229e-02 ||r(i)||/||b|| 1.625599754477e-07
 53 KSP Residual norm 0.0606995
 54 KSP preconditioned resid norm 5.435441953157e-02 true resid norm 1.552684149554e-02 ||r(i)||/||b|| 1.138748917898e-07
 54 KSP Residual norm 0.0543544
 55 KSP preconditioned resid norm 2.547161131414e-02 true resid norm 1.577103638976e-02 ||r(i)||/||b|| 1.156658334416e-07
 55 KSP Residual norm 0.0254716
 56 KSP preconditioned resid norm 2.001933827413e-02 true resid norm 5.694615940615e-03 ||r(i)||/||b|| 4.176469336718e-08
 56 KSP Residual norm 0.0200193
 57 KSP preconditioned resid norm 1.876429465485e-02 true resid norm 5.519797333920e-03 ||r(i)||/||b|| 4.048256203828e-08
 57 KSP Residual norm 0.0187643
 58 KSP preconditioned resid norm 1.692036543945e-02 true resid norm 5.453246578101e-03 ||r(i)||/||b|| 3.999447435351e-08
 58 KSP Residual norm 0.0169204
 59 KSP preconditioned resid norm 1.582371180583e-02 true resid norm 4.496211187034e-03 ||r(i)||/||b|| 3.297551292288e-08
 59 KSP Residual norm 0.0158237
 60 KSP preconditioned resid norm 1.190913027763e-02 true resid norm 3.914110514439e-03 ||r(i)||/||b|| 2.870634774066e-08
 60 KSP Residual norm 0.0119091
 61 KSP preconditioned resid norm 1.146442223272e-02 true resid norm 3.271054008401e-03 ||r(i)||/||b|| 2.399012840778e-08
 61 KSP Residual norm 0.0114644
 62 KSP preconditioned resid norm 1.067803229789e-02 true resid norm 6.183719226703e-03 ||r(i)||/||b|| 4.535180951011e-08
 62 KSP Residual norm 0.010678
 63 KSP preconditioned resid norm 8.643055835024e-03 true resid norm 2.460641084429e-03 ||r(i)||/||b|| 1.804650593640e-08
 63 KSP Residual norm 0.00864306
 64 KSP preconditioned resid norm 8.464933444833e-03 true resid norm 2.410422764398e-03 ||r(i)||/||b|| 1.767820142573e-08
 64 KSP Residual norm 0.00846493
 65 KSP preconditioned resid norm 5.841843565636e-03 true resid norm 3.286620231803e-03 ||r(i)||/||b|| 2.410429212910e-08
 65 KSP Residual norm 0.00584184
 66 KSP preconditioned resid norm 4.549278271976e-03 true resid norm 1.294612772402e-03 ||r(i)||/||b|| 9.494776475261e-09
 66 KSP Residual norm 0.00454928
 67 KSP preconditioned resid norm 3.514982562057e-03 true resid norm 1.010411827086e-03 ||r(i)||/||b|| 7.410427774743e-09
 67 KSP Residual norm 0.00351498
 68 KSP preconditioned resid norm 3.522198184965e-03 true resid norm 1.011773142531e-03 ||r(i)||/||b|| 7.420411753067e-09
 68 KSP Residual norm 0.0035222
 69 KSP preconditioned resid norm 3.073114581057e-03 true resid norm 8.751758033987e-04 ||r(i)||/||b|| 6.418597751365e-09
 69 KSP Residual norm 0.00307311
 70 KSP preconditioned resid norm 3.114994556465e-03 true resid norm 8.879564167853e-04 ||r(i)||/||b|| 6.512331622921e-09
 70 KSP Residual norm 0.00311499
 71 KSP preconditioned resid norm 3.006653595406e-03 true resid norm 1.042656194287e-03 ||r(i)||/||b|| 7.646910115783e-09
 71 KSP Residual norm 0.00300665
 72 KSP preconditioned resid norm 3.374944103191e-03 true resid norm 9.584399807989e-04 ||r(i)||/||b|| 7.029262785471e-09
 72 KSP Residual norm 0.00337494
 73 KSP preconditioned resid norm 2.583871653685e-03 true resid norm 7.512827414514e-04 ||r(i)||/||b|| 5.509957766421e-09
 73 KSP Residual norm 0.00258387
 74 KSP preconditioned resid norm 1.954747455191e-03 true resid norm 5.834519242594e-04 ||r(i)||/||b|| 4.279075352104e-09
 74 KSP Residual norm 0.00195475
 75 KSP preconditioned resid norm 2.481888252857e-03 true resid norm 7.091861543258e-04 ||r(i)||/||b|| 5.201218586915e-09
 75 KSP Residual norm 0.00248189
 76 KSP preconditioned resid norm 3.219625627106e-03 true resid norm 9.215795139409e-04 ||r(i)||/||b|| 6.758925661466e-09
 76 KSP Residual norm 0.00321963
 77 KSP preconditioned resid norm 2.168313805953e-03 true resid norm 6.494908996548e-04 ||r(i)||/||b|| 4.763409605096e-09
 77 KSP Residual norm 0.00216831
 78 KSP preconditioned resid norm 5.430344606505e-04 true resid norm 1.555158829080e-04 ||r(i)||/||b|| 1.140563864378e-09
 78 KSP Residual norm 0.000543034
 79 KSP preconditioned resid norm 1.180633568496e-04 true resid norm 3.412969440973e-05 ||r(i)||/||b|| 2.503094566170e-10
 79 KSP Residual norm 0.000118063
 80 KSP preconditioned resid norm 1.489292655512e-04 true resid norm 5.291253375816e-05 ||r(i)||/||b|| 3.880640539652e-10
 80 KSP Residual norm 0.000148929
 81 KSP preconditioned resid norm 1.725342222348e-05 true resid norm 5.489604690976e-06 ||r(i)||/||b|| 4.026112717988e-11
 81 KSP Residual norm 1.72534e-05
Linear solve converged due to CONVERGED_RTOL iterations 81
  type: bcgs
  type: mg
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0968067, max = 1.06487
          type: gmres
      type: sor
        type: seqaij
        total: nonzeros=6.93209e+06, allocated nonzeros=0
    type: seqaij
-- Ramachandran --
Timing Info
     Solve 4.60000000e+01
