[petsc-users] Diagnosing Poisson Solver Behavior
K. N. Ramachandran knram06 at gmail.com
Mon Oct 12 14:52:18 CDT 2015
Hello Matt,
Thanks for your reply. I am actually retrying against the latest PETSc and
will revert once I get the information.
On Mon, Oct 12, 2015 at 9:39 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Oct 10, 2015 at 7:56 PM, K. N. Ramachandran <knram06 at gmail.com>
> wrote:
>> Sorry, some more questions.
>> 3) Also, for Dirichlet bc, I specify the value through Identity rows,
>> i.e. A_ii = 1 and the rhs value would correspond to the Dirichlet
>> condition. I am specifying it this way for my convenience. I am aware that
>> MatZerosRowColumns might help here, but would keeping it this way be
>> detrimental?
> That is fine. However you would want to scale these entries to be
> approximately the same size as the other diagonal entries.
>> 4) Can I expect symmetric matrices to perform better, i.e. if I eliminate
>> Dirichlet rows? But I would still be left with Neumann boundary conditions,
>> where I use the second order formulation. If I used the first order
>> formulation and made it symmetric, would that be an advantage? I tried the
>> latter, but I didn't see the condition number change much.
> Will not matter for MG.
>     Matt
K.N.Ramachandran
Ph: 814-441-4279
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151012/9ea66a0d/attachment.html>
