[petsc-users] problem using 64-bit-indices
Randall Mackie rlmackie862 at gmail.com
Tue Nov 17 11:07:20 CST 2015
I ran into a problem yesterday where a call to DMDACreate3d gave an error message about the size being too big and that I should use —with-64-bit-indices.
So I recompiled PETSc (latest version, 3.6.2) with that option, but when I recompiled my code, I found the following errors:
  call VecGetArrayF90(vSeqZero,ptr_a,ierr)
                                       1
Error: Type mismatch in argument 'ierr' at (1); passed INTEGER(8) to INTEGER(4)
  call VecRestoreArrayF90(vSeqZero,ptr_a,ierr)
                                           1
  call DMDAVecGetArrayF90(da,J,ptr_j,ierr)
                                                 1
Error: There is no specific subroutine for the generic 'dmdavecgetarrayf90' at (1)
So strangely, even though all my variables are defined like PetscInt, PetscReal, etc, VecGetArrayF90 is still expecting a 4 byte integer, which is easy enough for me to do, but there seems to be a problem with DMDAVecGetArrayF90. In the meantime, I’ll switch to VecGetArrayF90, and retry my code, but I thought I’d pass along these error messages.
Randy M.
