[petsc-users] Problem Iterating DMPlex
Tue Nov 17 10:53:01 CST 2015
On Tue, Nov 17, 2015 at 10:11 AM, Morten Nobel-Jørgensen <mono at mek.dtu.dk>
wrote:
> After distributing a DMPlex it seems like my cells are appearing twice (or
> rather multiple cells maps onto the same vertices).
Your code is creating the serial mesh on each process. You only want
nonzero sizes on one proc.
You can see the mesh using -dm_view, and everything using -dm_view
::ascii_info_detail
     Matt
> I’m assuming the way I’m iterating the DMPlex is wrong. Essentially I
> iterate the DMPlex the following way after distribution (see code snippet
> below – or attached file).
> A related problem; Since distribution of a DMPlex reorders the point
> indices, how to do I map between distributed point indices and the original
> point indices.
> And a final question: After distributing a DMPlex, some of the vertices
> are shared and exists in multiple instances. When adding dofs to these, how
> I I know if dof is owned by the current instance or it is a ghost dof?
> I hope someone can point me in the right direction :)
> Kind regards,
> Morten
> Code snippet
> PetscInt from,to,dof,off;
> DMPlexGetHeightStratum(dm, 0,&from, &to);
> for (int cellIndex=from;cellIndex<to;cellIndex++){
>     const PetscInt *edges;
>     PetscInt       numEdges;
>     DMPlexGetConeSize(dm, cellIndex, &numEdges);
>     DMPlexGetCone(dm, cellIndex, &edges);
>     for (int e = 0;e<numEdges;e++) {
>         int edgeIndex = edges[e];
>         const PetscInt *vertices;
>         PetscInt       numVertices;
>         DMPlexGetConeSize(dm, edgeIndex, &numVertices);
>         DMPlexGetCone(dm, edgeIndex, &vertices);
>         for (int v = 0;v<numVertices;v++){
>             int vertexIndex = vertices[v];
> For a non distibuted mesh the top of the hasse diagram looks like this:
> 0 --> 2
> 0 --> 3
> 0 --> 4
> 1 --> 4
> 1 --> 5
> 1 --> 6
> But when distributing (on two cores) it looks like this, where both cells
> maps to the same edges (true for both cores):
> 0 --> 11
> 0 --> 12
> 0 --> 13
> 1 --> 11
> 1 --> 12
> 1 --> 13
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151117/ad6503a9/attachment.html>
