[petsc-users] Parallel matrix-vector multiplication
Gianluca Meneghello gianmail at gmail.com
Wed Nov 11 22:05:49 CST 2015
I am trying to do something apparently really simple but with no success.
I need to perform a matrix-vector multiplication x = B f , where the length
of x is bigger than the length of f (or viceversa). Thus, B cannot be
created using DMCreateMatrix.
Both x and f are obtained from different DMs, the smaller covering only a
subdomain of the larger. The application is to apply a control f to a
system, e.g. \dot{x} = A x + B f.
The problem is, when running on more than one core, the vector x is not
organized as I would expect (everything works fine on a single core).
I attach a short example where B is intended to map f to the interior of x.
mpirun -n 1 ./test -draw_pause -1     works fine while
mpirun -n 2 ./test -draw_pause -1     shows the problem
I have not found any example with non square matrices in the src folder,
any help is very welcome.
Thanks for your time,
Gianluca
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151111/991c0f96/attachment.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151111/991c0f96/attachment.cpp>
