[petsc-users] GAMG and zero pivots follow up
Jed Brown jed at jedbrown.org
Wed Nov 11 12:01:39 CST 2015
David Knezevic <david.knezevic at akselos.com> writes:
> Do you have any further thoughts about what might cause the "strange
> blocking" that you referred to? If there's something non-standard that
> libMesh is doing with the blocks, I'd be interested to look into that. I
> can send over the matrix if that would be helpful.
Are you running Libmesh with --node_major_dofs?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151111/63465c14/attachment.pgp>
