[petsc-users] Memory usage with DMDACreate3d and DMDAGetCorners
TAY wee-beng zonexo at gmail.com
Tue Nov 10 01:33:34 CST 2015
I need a subroutine in Fortran to partition a subset of my grid in the 3
x,y,z directions for MPI. I thought of using DMDACreate3d and
DMDAGetCorners to get the starting and width of the partitioned grid.
Because I need to partition at every time step and the subset grid
changes dimension and index at every time step, so I will also need to
use DMDestroy after each time step
Will that use alot of memory? Will the grid actually be created? So I
wonder if this DMDACreate3d and DMDestroy calls will take a lot of time.
Thank you.
Yours sincerely,
TAY wee-beng
