[petsc-users] [petsc-dev] [SLEPc] For users of PETSc master branch, API change
Jose E. Roman jroman at dsic.upv.es
Mon Nov 9 08:48:16 CST 2015
The fix is already in SLEPc's branches 'jose/sync-with-petsc' and 'next'.
Will merge into 'master' tomorrow.
Jose
> El 9/11/2015, a las 15:44, Satish Balay <balay at mcs.anl.gov> escribió:
> you can try using a slightly older 'master' snapshot' [until you get
> the slpec fix]
> For eg:
> git checkout d916695f21d798ebdf80dc439ef54c5223c9183c
> And once the slepc fix is available - you can do:
> git checkout master
> git pull
> Satish
> On Mon, 9 Nov 2015, Leoni, Massimiliano wrote:
>> Ok, sorry!
>> It looks like I chose the worst possible day to update :D
>> Best,
>> Massimiliano
>>> -----Original Message-----
>>> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
>>> Sent: 09 November 2015 14:26
>>> To: Leoni, Massimiliano
>>> Cc: Barry Smith; PETSc; petsc-dev
>>> Subject: Re: [petsc-dev] [SLEPc] For users of PETSc master branch, API
>>> change
>>> Working on it. Be patient. Should be available on master tomorrow.
>>> Jose
>>>> El 9/11/2015, a las 15:23, Leoni, Massimiliano <Massimiliano.Leoni at Rolls-
>>> Royce.com> escribió:
>>>> Is there a branch in the SLEPc repo that supports this?
>>>> Massimiliano
>>>>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
>>>>> bounces at mcs.anl.gov] On Behalf Of Barry Smith
>>>>> Sent: 09 November 2015 00:21
>>>>> To: PETSc; petsc-dev
>>>>> Subject: [petsc-dev] For users of PETSc master branch, API change
>>>>>  For users of the PETSc master branch.
>>>>>  I have pushed into master some API changes for the
>>>>> PetscOptionsGetXXX() and related routines. The first argument is now
>>>>> a PetscOptions object, which is optional, if you pass a NULL in for
>>>>> the first argument (or a PETSC_NULL_OBJECT in Fortran) you will
>>>>> retain the same functionality as you had previously.
>>>>>  Barry
>>>> The data contained in, or attached to, this e-mail, may contain confidential
>>> information. If you have received it in error you should notify the sender
>>> immediately by reply e-mail, delete the message from your system and
>>> contact +44 (0) 3301235850 (Security Operations Centre) if you need
>>> assistance. Please do not copy it for any purpose, or disclose its contents to
>>> any other person.
>>>> An e-mail response to this address may be subject to interception or
>>> monitoring for operational reasons or for lawful business practices.
>>>> (c) 2015 Rolls-Royce plc
>>>> Registered office: 62 Buckingham Gate, London SW1E 6AT Company
>>> number: 1003142. Registered in England.
>> The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
>> An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
>> Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
