[petsc-users] PetscOptionsGetString Not Finding Option
Jared Crean jcrean01 at gmail.com
Tue Nov 3 21:01:14 CST 2015
   Hell Hong,
         Is there a way to directly query the options database to get
the value of Petsc options?  This is related to the discussion here:
http://lists.mcs.anl.gov/pipermail/petsc-dev/2015-July/017944.html .  I
though PetscOptionsGetString and PetscOptionsSetValue would provide this
capability, but now it seems like petsc options cannot be accessed.
     Jared Crean
On 11/01/2015 10:19 AM, Hong wrote:
> Jared :
> Either call KSPSetPCSide() or change
> const char name[] = "-ksp_pc_side"
> to a non-petsc option name, e.g., "-my_ksp_pc_side".
> Hong
>     Hello,
>         I am trying to use PetscOptionsGetString to retrieve the value
>     of an option in the options database, but the value returned in
>     the last argument indicates the option was not found.   In the
>     attached code (a modified version of ksp example 2), the string
>     "-ksp_pc_side" is passed in as the argument name. If I run the code as
>         ./jc2 -pc_type ilu -ksp_pc_side right
>         I get the output:
>         option -ksp_pc_side was found
>         from line 71 of the file.  Petsc does not complain of unused
>     options when the program finishes.  Am I using this function
>     incorrectly?
>         Jared Crean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151103/1bc3b7c6/attachment.html>
