[petsc-users] PetscOptionsGetString Not Finding Option
Hong hzhang at mcs.anl.gov
Sun Nov 1 09:19:17 CST 2015
Jared :
Either call KSPSetPCSide() or change
const char name[] = "-ksp_pc_side"
to a non-petsc option name, e.g., "-my_ksp_pc_side".
Hong
Hello,
>     I am trying to use PetscOptionsGetString to retrieve the value of an
> option in the options database, but the value returned in the last argument
> indicates the option was not found.   In the attached code (a modified
> version of ksp example 2), the string "-ksp_pc_side" is passed in as the
> argument name. If I run the code as
>     ./jc2 -pc_type ilu -ksp_pc_side right
>     I get the output:
>     option -ksp_pc_side was found
>     from line 71 of the file.  Petsc does not complain of unused options
> when the program finishes.  Am I using this function incorrectly?
>     Jared Crean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151101/e48b7909/attachment.html>
