[petsc-users] TimeStepper norm problems. EMIL Please read this
Emil Constantinescu emconsta at mcs.anl.gov
Mon Mar 30 22:01:40 CDT 2015
On 3/30/15 9:32 PM, Andrew Spott wrote:
> I’m sorry, I didn’t want to imply you were taking too much time.  I was
> just interested in trying to solve the problem myself, especially if it
> was a simpler fix.
Nothing of that sort. I just expected to figure it out sooner,
especially when you were kind enough to produce a very simple case and
an external Crank–Nicolson. We welcome any help. However, as far as I
can tell the issue may not be in the way the theta.c is implemented.
Emil
> I don’t have enough of an understanding of the internals of PETSc
> though, if it depends on the compiler flags.
> Good luck!
> -Andrew
>> Andrew
> On Mon, Mar 30, 2015 at 7:23 PM, Emil Constantinescu
> <emconsta at mcs.anl.gov <mailto:emconsta at mcs.anl.gov>> wrote:
>     Hi Andrew,
>     Sorry for the delay; things are going slower with me over the spring
>     break but we are working on it.
>     The problem that you see may not be related to the integrator, which
>     runs well (we get expected convergence rates and good results) for
>     other
>     problems, in particular, for problems with real variables (and no
>     c++11). So the high level th->endpoint implementation seems fine.
>     For some reason the linear solver is misbehaving when using cn. If you
>     use option -snes_mf the problem disappears.
>     Please do not use -ts_theta_adapt until it is fixed.
>     In conclusion I don't think that looking at theta.c will be productive.
>     We are currently looking at what happens at the lower levels.
>     Thanks,
>     Emil
>     On 3/30/15 4:25 PM, Andrew Spott wrote:
>      > Emil: If I want to fix this myself, do you have any idea where I
>     should
>      > start looking? I assume in the th->endpoint section of
>     TSStep_Theta in
>     http://www.mcs.anl.gov/petsc/petsc-current/src/ts/impls/implicit/theta/theta.c.html?
>      > Thanks,
>      > -Andrew
