[petsc-users] Conversion between AIJ & BAIJ
Tue Jan 20 16:39:02 CST 2015
  You can do a MatConvert() (requires another copy of the matrix) for the parts that benefit from BAIJ.
  Barry
> On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> Hi,
> Does PETSc provide means for conversion between AIJ & BAIJ.
> My matrix is created as AIJ because it makes life easy for most part of the applications but some part of applications actually get some benefits with BAIJ.  So I wonder if a matrix can exist as two idenfities and I can use either format depend on which one is more convenient at run time.
> So in my case the block size is fixed and identical for all blocks.
> Thanks,
> Kan
