[petsc-users] Support of NetCDF
Chao Yang yangchao at iscas.ac.cn
Tue Dec 29 10:18:12 CST 2015
Thanks, Jed.
> 在 2015年12月29日,下午12:00,Jed Brown <jed at jedbrown.org> 写道:
> Chao Yang <yangchao at iscas.ac.cn> writes:
>> Thanks, Fande. But it is NetCDF that I need, not HDF5, for some specific reason, though they are somehow connected.
> There is no raw NetCDF, but Exodus is a NetCDF-based format.
>>> 在 2015年12月29日,上午2:10,Fande Kong <fdkong.jd at gmail.com> 写道:
>>>> Message: 2
>>>> Date: Mon, 28 Dec 2015 11:17:07 +0800
>>>> From: Chao Yang <yangchao at iscas.ac.cn <mailto:yangchao at iscas.ac.cn>>
>>>> To: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>>>> Subject: [petsc-users] Support of NetCDF
>>>> Message-ID: <656D5E79-BD12-4189-A495-5B9006F941E5 at iscas.ac.cn <mailto:656D5E79-BD12-4189-A495-5B9006F941E5 at iscas.ac.cn>>
>>>> Content-Type: text/plain; charset=us-ascii
>>>> Hi,
>>>> A quick question. Does PETSc support NetCDF format for input/output?
>>> DMPlex supports input only through exodus. http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateExodus.html <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateExodus.html>
>>>> Any suggestion is highly appreciated. Thanks!
>>> If you want to do parallel IO, it is better to use HDF5 and has both input and output for vector and IS.
>>>> Best regards,
>>>> Chao
>>> Fande,
