[petsc-users] Support of NetCDF
Jed Brown jed at jedbrown.org
Mon Dec 28 22:00:21 CST 2015
Chao Yang <yangchao at iscas.ac.cn> writes:
> Thanks, Fande. But it is NetCDF that I need, not HDF5, for some specific reason, though they are somehow connected.
There is no raw NetCDF, but Exodus is a NetCDF-based format.
>> 在 2015年12月29日,上午2:10,Fande Kong <fdkong.jd at gmail.com> 写道:
>> >Message: 2
>> > Date: Mon, 28 Dec 2015 11:17:07 +0800
>> >From: Chao Yang <yangchao at iscas.ac.cn <mailto:yangchao at iscas.ac.cn>>
>> >To: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>> >Subject: [petsc-users] Support of NetCDF
>> >Message-ID: <656D5E79-BD12-4189-A495-5B9006F941E5 at iscas.ac.cn <mailto:656D5E79-BD12-4189-A495-5B9006F941E5 at iscas.ac.cn>>
>> >Content-Type: text/plain; charset=us-ascii
>> >Hi,
>> >A quick question. Does PETSc support NetCDF format for input/output?
>> DMPlex supports input only through exodus. http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateExodus.html <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateExodus.html>
>> >Any suggestion is highly appreciated. Thanks!
>> If you want to do parallel IO, it is better to use HDF5 and has both input and output for vector and IS.
>> >Best regards,
>> >Chao
>> Fande,
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151228/26a57107/attachment.pgp>
