[petsc-users] Issue when calling multiple processors from PETSc
Ajit Desai ajit.ndesai at gmail.com
Thu Dec 24 10:47:17 CST 2015
Thanks for your quick reply Matt.
I was using different MPIexec. The issue is now resolved.
Ajit
*Ajit Desai*
*  PhD Scholar, Carleton University *
*  Ottawa, Canada*
On Thu, Dec 24, 2015 at 11:37 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 24, 2015 at 10:16 AM, Ajit Desai <ajit.ndesai at gmail.com>
> wrote:
>> Hello everyone,
>> New user of PETSc and trying to get familiar with it for parallel
>> computing applications.
>> I wrote simple hello world code using PETSc environment and found a issue
>> with the output. For instance :
>> When I compile and execute "PETSc_helloWorld.F90" code with multiple
>> processor. It prints following output.
> Almost certainly you are using an 'mpiexec' that does not match the MPI
> library that you built PETSc with. Did you
> use --download-mpich? Try this
>   cd $PETSC_DIR
>   make check
> That will test it with the correct mpiexec.
>   Matt
>> MacUser$ *mpiexec -np 4 ./PETSc_helloWorld*
>> * Hello from PETSc World, rank: 0   of total   1  processes.*
>> Similar code with MPI prints following output:
>> ​MacUser​
>> *mpiexec -np 4 ./a.out *
>> * Hello from MPI World, rank: 0 *
>> * of total  4  processes.*
>> * Hello from MPI World, rank: 1 *
>> * of total ​  ​4  processes.*
>> * Hello from MPI World, rank: 2 *
>> * Hello from MPI World, rank: 3   of total  4  processes. *
>> ​I am not sure is this the issue with the PETSc installation ​in my
>> machine or am I missing something here?
>> I have attached both codes and *log_summary* of PETSc for your
>> convenience.
>> Thanks & Regards,
>> *Ajit Desai*
>> *  Carleton University *
>> *  Ottawa, Canada*
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151224/d921f717/attachment.html>
