[petsc-users] Issue when calling multiple processors from PETSc
Thu Dec 24 10:37:43 CST 2015
On Thu, Dec 24, 2015 at 10:16 AM, Ajit Desai <ajit.ndesai at gmail.com> wrote:
> Hello everyone,
> New user of PETSc and trying to get familiar with it for parallel
> computing applications.
> I wrote simple hello world code using PETSc environment and found a issue
> with the output. For instance :
> When I compile and execute "PETSc_helloWorld.F90" code with multiple
> processor. It prints following output.
Almost certainly you are using an 'mpiexec' that does not match the MPI
library that you built PETSc with. Did you
use --download-mpich? Try this
  cd $PETSC_DIR
  make check
That will test it with the correct mpiexec.
  Matt
> MacUser$ *mpiexec -np 4 ./PETSc_helloWorld*
> * Hello from PETSc World, rank: 0   of total   1  processes.*
> Similar code with MPI prints following output:
> ​MacUser​
> *mpiexec -np 4 ./a.out *
> * Hello from MPI World, rank: 0 *
> * of total  4  processes.*
> * Hello from MPI World, rank: 1 *
> * of total ​  ​4  processes.*
> * Hello from MPI World, rank: 2 *
> * Hello from MPI World, rank: 3   of total  4  processes. *
> ​I am not sure is this the issue with the PETSc installation ​in my
> machine or am I missing something here?
> I have attached both codes and *log_summary* of PETSc for your
> convenience.
> Thanks & Regards,
> *Ajit Desai*
> *  Carleton University *
> *  Ottawa, Canada*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151224/551c776c/attachment.html>
