[petsc-users] DMCreateMatrix from one DMDA to an another
Timothée Nicolas timothee.nicolas at gmail.com
Tue Dec 22 00:02:48 CST 2015
I'd like to take advantage of the stencil structure of the DMDA to write
into my matrix. I have already written all my routines so that I can use
MatSetValuesStencil so it's most convenient for me, otherwise I will have
to rethink all the structure.
Since I don't create my rectangular matrix with DMCreateMatrix but with
MatCreate and MatSetSizes instead, the manual tells me I have to call first
MatSetStencil and MatSetLocalToGlobalMapping before being allowed to call
MatSetValuesStencil. So before going on the full example, I tried to do
this on a simple square matrix but I can't get the thing to work. It must
be an obvious mistake but can't find it. My code is
  PetscErrorCode :: ierr
  DM :: da
  Mat :: A
  PetscInt :: xm
  ISLocalToGlobalMapping :: ltog
  PetscInt :: dims(1), starts(1)
  PetscInt :: dim
  MatStencil :: row(4,1), col(4,1)
  PetscScalar :: v
  call DMDACreate1d
(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,iten,ione,ione,PETSC_NULL_INTEGER,da,ierr)
  call DMDAGetCorners(da,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
       &              xm,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
  call MatCreate(PETSC_COMM_WORLD,A,ierr)
  call MatSetSizes(A,xm,xm,PETSC_DETERMINE,PETSC_DETERMINE,ierr)
  call DMGetLocalToGlobalMapping(da,ltog,ierr)
  call MatSetLocalToGlobalMapping(A,ltog,ltog,ierr)
  call DMDAGetGhostCorners(da,starts(1),PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
dims(1),PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
  dim=ione
  call MatSetStencil(A,dim,dims,starts,ione,ierr)
  row(MatStencil_i,1) = 0
  col(MatStencil_i,1) = 0
  call MatSetValuesStencil(A,ione,row,ione,col,zero,INSERT_VALUES,ierr)
But I keep getting a segmentation fault error.
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
[0]PETSC ERROR: ./miips on a arch-darwin-c-debug named
iMac27Nicolas.nifs.ac.jp by timotheenicolas Tue Dec 22 14:57:46 2015
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-fblaslapack --download-mpich
--with-debugging=no
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[cli_0]: aborting job:
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 9812 RUNNING AT iMac27Nicolas.nifs.ac.jp
=   EXIT CODE: 59
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
If I replace everything with call DMCreateMatrix(da,A,ierr) it works fine.
What information did I miss from the manual ? What am I doing wrong ?
Best
Timothee
2015-12-06 23:16 GMT+09:00 Timothée Nicolas <timothee.nicolas at gmail.com>:
> Wow, Great answer, thanks, I should probably be able to do it like this,
> I'll try my best !
> I actually do want the assembled matrix now. I have coded the matrix-free
> version already and it works fine, but I want to use multigrid and I
> figured that in order to be be most efficient at the coarse level it is
> best to use -ksp_type preonly -pc_type lu, which requires a true matrix
> (the matrix I am talking about is the product between a matrix 3dof -->
> 5dof with a matrix 5dof --> 3dof, which ends up square). But I want to
> retain a memory light implementation so I use matrix-free formulation at
> all the levels but the last, which is also light by definition, so I should
> not suffer much in terms of memory.
> Thanks
> Timothée
> 2015-12-06 22:29 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
>> On 6 December 2015 at 11:19, Timothée Nicolas <timothee.nicolas at gmail.com
>> > wrote:
>>> Hi,
>>> The answer to the first question is yes. I was puzzled about the second
>>> part of the answer, but I realize I was not clear enough. I don't want to
>>> just transfer information between 2 DMDAs, I want to perform an operation
>>> on vectors with a rectangular matrix.
>> Okay - I misunderstood.
>>> To be more explicit, the input vector of the operation is a vector with
>>> 3 components (hence dof=3), and the results of the operator is put in one
>>> vector equation + 2 scalar equation, which makes it dof = 5.
>>> So, either I cannot fill my matrix (if the number of rows exceeds what
>>> is allowed by the DMDA), or I can fill my matrix but then the matrix and
>>> vectors are not compatible, as in this error :
>> Do you need to explicitly assemble this rectangular operator?
>> Expressing this operator via a matrix-free representation would be
>> relatively straight forward.
>> However, since the DMDA's have the same parallel layout you are in good
>> shape to define the rectangular matrix if you really want the assembled
>> thing. Your row space would be defined by the DMDA with block size 5 and
>> the column space would be defined by the DMDA with block size 3. For
>> example the matrix would be created like in the following way (assuming a
>> 2D DMDA)
>> PetscInt m,n,M,N;
>> DMDAGetInfo(dm3,NULL,&M,&N,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL);
>> nodes = M *N;
>> DMDAGetCorners(dm3,NULL,NULL,NULL,&m,&n,NULL);
>> lnodes = m * n;
>> MatCreate(PETSC_COMM_WORLD,&A);
>> MatSetSizes(A,lnodes*5,lnodes*3,nodes*5,nodes*3);
>> The sparsity pattern is defined by the connectivity of the DMDA points
>> AND the different block sizes.
>> To define the non-zero structure, you need to traverse the part of the
>> dmda defined by the natural indices given by si <= i < si+m, sj <= j < sj+n
>> and check whether the the 5x3 block associated with each i,j is living
>> within the diagonal or off-diagonal block of the matrix. For a given i,j
>> the off-diagonal is defined by any i',j' associated your stencil which is
>> not in the range si <= i' <= si + m, sj <= j' < sj + n. (e.g. it is a ghost
>> node).
>> Your arrays counting the non-zero entries on the diagonal (nnz[]) and off
>> diag (nnz_od[]) can be indexed using i + j * m. This corresponds to the
>> indexing used by the DMDA. Your non-zero counting function would look
>> something like the pseudo code below
>> PetscInt *nnz,*nnz_od;
>> PetscMalloc(sizeof(PetscInt)*m*n*5,&nnz);
>> PetscMalloc(sizeof(PetscInt)*m*n*5,&nnz_od);
>> PetscMemzero(nnz,sizeof(PetscInt)*m*n*5);
>> PetscMemzero(nnz_od,sizeof(PetscInt)*m*n*5);
>> for (j=0; j<n; j++) {
>> for (i=0; i<m; i++) {
>>   PetscInt idx,d,cnti,cntg;
>>   PetscBool is_ghost;
>>   idx = i + j * m;
>>   cnti = 0;
>>   cntg = 0;
>>   for (all_points_in_stencil) { /* User logic to define this loop */
>>    is_ghost = PETSC_FALSE;
>>    /*User logic goes here to test if stencil point is a ghost point */
>>     /* accumulate counts for the stencil */
>>     if (is_ghost) { cntg++; } /* values living on a neighbour rank */
>>     else { cnti++; } /* values local to current rank */
>>   /* assume all dofs in row and col space in block are coupled to each
>> other */
>>   for (d=0; d<5; d++) {
>>     nnz[5*idx+d]       = 3 * cnti;
>>     nnz_od[5*idx+d] = 3 * cntg;
>> Thanks,
>>   Dave
>>> [0]PETSC ERROR: Nonconforming object sizes
>>> [0]PETSC ERROR: Mat mat,Vec y: global dim 4900 2940
>>> for trouble shooting.
>>> [0]PETSC ERROR: ./miips on a arch-linux2-c-debug named Carl-9000 by
>>> timothee Sun Dec  6 19:17:20 2015
>>> [0]PETSC ERROR: #1 MatMult() line 2215 in
>>> /home/timothee/Documents/petsc-3.6.1/src/mat/interface/matrix.c
>>> So I assume it means the matrix is assumed to be square. Is there a way
>>> to change this ?
>>> Best
>>> Timothée
>>> 2015-12-05 20:41 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
>>>> On 5 December 2015 at 11:15, Timothée Nicolas <
>>>> timothee.nicolas at gmail.com> wrote:
>>>>> Hi,
>>>>> I need to create a rectangular matrix which takes vector structured by
>>>>> a DMDA and transforms them to vectors structured with an other DMDA. It
>>>>> does not look like there is a routine to do this since apparently
>>>>> DMCreateMatrix assumes square matrix. What is the clean way to do this ?
>>>> Do the DMDA's have exactly the same parallel layout and only differ by
>>>> the number of DOFs?
>>>> If yes, and you only want to move entries between vectors associated
>>>> with the two DMDA's, you can perform the transfer between vectors locally
>>>> (rank-wise) in a very simple manner using the local number of points from
>>>> DMDA and the known block sizes (DOFs) associated with your DMDA and the
>>>> size of the subspace you ultimately want to construct.
>>>> Thanks,
>>>>   Dave
>>>>> The problem is I have a DMDA with 8 degrees of freedom (dof) and my
>>>>> matrix sends vectors living in a subspace with 3 dof to the other 5 dof
>>>>> subspace. I can define a square matrix living in the large, 8 dof subspace,
>>>>> but this is of course very inefficient in terms of memory and time.
>>>>> Thanks
>>>>> Best
>>>>> Timothée
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151222/12c6080f/attachment-0001.html>
