[petsc-users] DMCreateMatrix from one DMDA to an another
Timothée Nicolas timothee.nicolas at gmail.com
Sun Dec 6 08:16:03 CST 2015
Wow, Great answer, thanks, I should probably be able to do it like this,
I'll try my best !
I actually do want the assembled matrix now. I have coded the matrix-free
version already and it works fine, but I want to use multigrid and I
figured that in order to be be most efficient at the coarse level it is
best to use -ksp_type preonly -pc_type lu, which requires a true matrix
(the matrix I am talking about is the product between a matrix 3dof -->
5dof with a matrix 5dof --> 3dof, which ends up square). But I want to
retain a memory light implementation so I use matrix-free formulation at
all the levels but the last, which is also light by definition, so I should
not suffer much in terms of memory.
Thanks
Timothée
2015-12-06 22:29 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
> On 6 December 2015 at 11:19, Timothée Nicolas <timothee.nicolas at gmail.com>
> wrote:
>> Hi,
>> The answer to the first question is yes. I was puzzled about the second
>> part of the answer, but I realize I was not clear enough. I don't want to
>> just transfer information between 2 DMDAs, I want to perform an operation
>> on vectors with a rectangular matrix.
> Okay - I misunderstood.
>> To be more explicit, the input vector of the operation is a vector with 3
>> components (hence dof=3), and the results of the operator is put in one
>> vector equation + 2 scalar equation, which makes it dof = 5.
>> So, either I cannot fill my matrix (if the number of rows exceeds what is
>> allowed by the DMDA), or I can fill my matrix but then the matrix and
>> vectors are not compatible, as in this error :
> Do you need to explicitly assemble this rectangular operator?
> Expressing this operator via a matrix-free representation would be
> relatively straight forward.
> However, since the DMDA's have the same parallel layout you are in good
> shape to define the rectangular matrix if you really want the assembled
> thing. Your row space would be defined by the DMDA with block size 5 and
> the column space would be defined by the DMDA with block size 3. For
> example the matrix would be created like in the following way (assuming a
> 2D DMDA)
> PetscInt m,n,M,N;
> DMDAGetInfo(dm3,NULL,&M,&N,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL);
> nodes = M *N;
> DMDAGetCorners(dm3,NULL,NULL,NULL,&m,&n,NULL);
> lnodes = m * n;
> MatCreate(PETSC_COMM_WORLD,&A);
> MatSetSizes(A,lnodes*5,lnodes*3,nodes*5,nodes*3);
> The sparsity pattern is defined by the connectivity of the DMDA points AND
> the different block sizes.
> To define the non-zero structure, you need to traverse the part of the
> dmda defined by the natural indices given by si <= i < si+m, sj <= j < sj+n
> and check whether the the 5x3 block associated with each i,j is living
> within the diagonal or off-diagonal block of the matrix. For a given i,j
> the off-diagonal is defined by any i',j' associated your stencil which is
> not in the range si <= i' <= si + m, sj <= j' < sj + n. (e.g. it is a ghost
> node).
> Your arrays counting the non-zero entries on the diagonal (nnz[]) and off
> diag (nnz_od[]) can be indexed using i + j * m. This corresponds to the
> indexing used by the DMDA. Your non-zero counting function would look
> something like the pseudo code below
> PetscInt *nnz,*nnz_od;
> PetscMalloc(sizeof(PetscInt)*m*n*5,&nnz);
> PetscMalloc(sizeof(PetscInt)*m*n*5,&nnz_od);
> PetscMemzero(nnz,sizeof(PetscInt)*m*n*5);
> PetscMemzero(nnz_od,sizeof(PetscInt)*m*n*5);
> for (j=0; j<n; j++) {
> for (i=0; i<m; i++) {
>   PetscInt idx,d,cnti,cntg;
>   PetscBool is_ghost;
>   idx = i + j * m;
>   cnti = 0;
>   cntg = 0;
>   for (all_points_in_stencil) { /* User logic to define this loop */
>    is_ghost = PETSC_FALSE;
>    /*User logic goes here to test if stencil point is a ghost point */
>     /* accumulate counts for the stencil */
>     if (is_ghost) { cntg++; } /* values living on a neighbour rank */
>     else { cnti++; } /* values local to current rank */
>   /* assume all dofs in row and col space in block are coupled to each
> other */
>   for (d=0; d<5; d++) {
>     nnz[5*idx+d]       = 3 * cnti;
>     nnz_od[5*idx+d] = 3 * cntg;
> Thanks,
>   Dave
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Nonconforming object sizes
>> [0]PETSC ERROR: Mat mat,Vec y: global dim 4900 2940
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
>> [0]PETSC ERROR: ./miips on a arch-linux2-c-debug named Carl-9000 by
>> timothee Sun Dec  6 19:17:20 2015
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --download-fblaslapack --download-mpich
>> [0]PETSC ERROR: #1 MatMult() line 2215 in
>> /home/timothee/Documents/petsc-3.6.1/src/mat/interface/matrix.c
>> So I assume it means the matrix is assumed to be square. Is there a way
>> to change this ?
>> Best
>> Timothée
>> 2015-12-05 20:41 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
>>> On 5 December 2015 at 11:15, Timothée Nicolas <
>>> timothee.nicolas at gmail.com> wrote:
>>>> Hi,
>>>> I need to create a rectangular matrix which takes vector structured by
>>>> a DMDA and transforms them to vectors structured with an other DMDA. It
>>>> does not look like there is a routine to do this since apparently
>>>> DMCreateMatrix assumes square matrix. What is the clean way to do this ?
>>> Do the DMDA's have exactly the same parallel layout and only differ by
>>> the number of DOFs?
>>> If yes, and you only want to move entries between vectors associated
>>> with the two DMDA's, you can perform the transfer between vectors locally
>>> (rank-wise) in a very simple manner using the local number of points from
>>> DMDA and the known block sizes (DOFs) associated with your DMDA and the
>>> size of the subspace you ultimately want to construct.
>>> Thanks,
>>>   Dave
>>>> The problem is I have a DMDA with 8 degrees of freedom (dof) and my
>>>> matrix sends vectors living in a subspace with 3 dof to the other 5 dof
>>>> subspace. I can define a square matrix living in the large, 8 dof subspace,
>>>> but this is of course very inefficient in terms of memory and time.
>>>> Thanks
>>>> Best
>>>> Timothée
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151206/62e2918f/attachment.html>
