[petsc-users] Slow MatAssemblyBegin MAT_FINAL_ASSEMBLY
Dave May dave.mayhem23 at gmail.com
Thu Dec 17 11:12:38 CST 2015
On Thursday, 17 December 2015, Jose A. Abell M. <jaabell at ucdavis.edu> wrote:
> Thank you Dave!
> Do you have a rough idea of how long a matrix like that should take to
> assemble?
> Not hours. Right?
If the preallocation is correct, and most of the entries to be inserted
live locally (and don't need to be scattered to another rank), it should
definitely not take hours.
> Regards,
> Jose
> José Abell
> *PhD Candidate*
> Computational Geomechanics Group
> Dept. of Civil and Environmental Engineering
> UC Davis
> www.joseabell.com
> On Thu, Dec 17, 2015 at 12:58 AM, Dave May <dave.mayhem23 at gmail.com
> <javascript:_e(%7B%7D,'cvml','dave.mayhem23 at gmail.com');>> wrote:
>> On 17 December 2015 at 08:06, Jose A. Abell M. <jaabell at ucdavis.edu
>> <javascript:_e(%7B%7D,'cvml','jaabell at ucdavis.edu');>> wrote:
>>> Hello dear PETSc users,
>>> This is a problem that pops up often, from what I see, in the mailing
>>> list. My program takes a long time assembling the matrix.
>>> What I know:
>>>    - Matrix Size is (MatMPIAIJ) 2670402
>>>    - Number of processes running PETSc: 95
>>>    - Not going to virtual memory (no swapping, used mem well withing
>>>    each node's capacity)
>>>    - System is partitioned with ParMETIS for load balancing
>>>    - I see memory moving around in each node (total used memory changes
>>>    a bit, grows and then frees)
>>>    - Matrix is filled in blocks of size 81x81 (FEM code, so this ends
>>>    up being a sparse matrix)
>>>    - I don't do flushes at all. Only MAT_FINAL_ASSEMBLY when all the
>>>    MatSetValues are done.
>>> Should I do MAT_FLUSH_ASSEMBLY even though I have enough memory to
>>> store the buffers? If so, how often? Every 100 blocks?
>>> What else could it be?
>>> Its taking several hours to asseble this matrix. I re-use the sparsity
>>> pattern, so subsequent assemblies are fast. Does this mean that my
>>> preallocation is wrong?
>> The preallocation could be wrong. That is the usual cause of very slow
>> matrix assembly. To confirm this hypothesis, run your code with the command
>> line option -info. You will get an enormous amount of information in
>> stdout. You might consider using -info with a smallish problem size / core
>> count.
>> Inspect the output generated by -info and look for lines like this:
>> [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> If the number of mallocs during MatSetValues() is not zero, then your
>> preallocation is not exactly correct. A small number of mallocs, say less
>> than 10, might be accepted (performance wise). However if the number of
>> mallocs is > 100, then assembly time will be terribly slow.
>> Thanks,
>>   Dave
>>> Regards,
>>> José Abell
>>> *PhD Candidate*
>>> UC Davis
>>> www.joseabell.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151217/86b7647d/attachment-0001.html>
