[petsc-users] Slow MatAssemblyBegin MAT_FINAL_ASSEMBLY
Jose A. Abell M. jaabell at ucdavis.edu
Thu Dec 17 09:10:30 CST 2015
Thank you Dave!
Do you have a rough idea of how long a matrix like that should take to
assemble?
Not hours. Right?
Jose
José Abell
*PhD Candidate*
Computational Geomechanics Group
Dept. of Civil and Environmental Engineering
UC Davis
www.joseabell.com
On Thu, Dec 17, 2015 at 12:58 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 17 December 2015 at 08:06, Jose A. Abell M. <jaabell at ucdavis.edu>
> wrote:
>> Hello dear PETSc users,
>> This is a problem that pops up often, from what I see, in the mailing
>> list. My program takes a long time assembling the matrix.
>> What I know:
>>    - Matrix Size is (MatMPIAIJ) 2670402
>>    - Number of processes running PETSc: 95
>>    - Not going to virtual memory (no swapping, used mem well withing
>>    each node's capacity)
>>    - System is partitioned with ParMETIS for load balancing
>>    - I see memory moving around in each node (total used memory changes
>>    a bit, grows and then frees)
>>    - Matrix is filled in blocks of size 81x81 (FEM code, so this ends up
>>    being a sparse matrix)
>>    - I don't do flushes at all. Only MAT_FINAL_ASSEMBLY when all the
>>    MatSetValues are done.
>> Should I do MAT_FLUSH_ASSEMBLY even though I have enough memory to store
>> the buffers? If so, how often? Every 100 blocks?
>> What else could it be?
>> Its taking several hours to asseble this matrix. I re-use the sparsity
>> pattern, so subsequent assemblies are fast. Does this mean that my
>> preallocation is wrong?
> The preallocation could be wrong. That is the usual cause of very slow
> matrix assembly. To confirm this hypothesis, run your code with the command
> line option -info. You will get an enormous amount of information in
> stdout. You might consider using -info with a smallish problem size / core
> count.
> Inspect the output generated by -info and look for lines like this:
> [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> If the number of mallocs during MatSetValues() is not zero, then your
> preallocation is not exactly correct. A small number of mallocs, say less
> than 10, might be accepted (performance wise). However if the number of
> mallocs is > 100, then assembly time will be terribly slow.
> Thanks,
>   Dave
>> Regards,
>> José Abell
>> *PhD Candidate*
>> UC Davis
>> www.joseabell.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151217/9d862eca/attachment.html>
