[petsc-users] Big discrepancy between machines
Timothée Nicolas timothee.nicolas at gmail.com
Mon Dec 14 01:30:44 CST 2015
I see,
To check whether I have a null space or not, in principle, I should see it
by computing the determinant of my matrices, right ? In principle I should
not have a null space, so that would be a good method to check if I have
any coding error, wouldn't it ?
Thx
Timothee
2015-12-14 16:20 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
> On Mon, Dec 14, 2015 at 1:09 AM, Timothée Nicolas <
> timothee.nicolas at gmail.com> wrote:
>> Hi,
>> I have noticed I have a VERY big difference in behaviour between two
>> machines in my problem, solved with SNES. I can't explain it, because I
>> have tested my operators which give the same result. I also checked that
>> the vectors fed to the SNES are the same. The problem happens only with my
>> shell preconditioner. When I don't use it, and simply solve using -snes_mf,
>> I don't see anymore than the usual 3-4 changing digits at the end of the
>> residuals. However, when I use my pcshell, the results are completely
>> different between the two machines.
> I don't think its possible from this info to tell exactly what is
> happening. However, if your shell preconditioner had a null space, you
> could imagine
> that you initially have a consistent approximation, but on one machine you
> get a perturbation in the null direction which never goes away. I have
> no other ideas.
>   Matt
>> I have attached output_SuperComputer.txt and output_DesktopComputer.txt,
>> which correspond to the output from the exact same code and options (and of
>> course same input data file !). More precisely
>> output_SuperComputer.txt : output on a supercomputer called Helios, sorry
>> I don't know the exact specs.
>> In this case, the SNES norms are reduced successively:
>> 0 SNES Function norm 4.867111712420e-03
>> 1 SNES Function norm 5.632325929998e-08
>> 2 SNES Function norm 7.427800084502e-15
>> output_DesktopComputer.txt : output on a Mac OS X Yosemite 3.4 GHz Intel
>> Core i5 16GB 1600 MHz DDr3. (the same happens on an other laptop with Mac
>> OS X Mavericks).
>> In this case, I obtain the following for the SNES norms,
>> while in the other, I obtain
>> 0 SNES Function norm 4.867111713544e-03
>> 1 SNES Function norm 1.560094052222e-03
>> 2 SNES Function norm 1.552118650943e-03
>> 3 SNES Function norm 1.552106297094e-03
>> 4 SNES Function norm 1.552106277949e-03
>> which I can't explain, because otherwise the KSP residual (with the same
>> operator, which I checked) behave well.
>> As you can see, the first time the preconditioner is applied (DB_, DP_,
>> Drho_ and PS_ solves), the two outputs coincide (except for the few last
>> digits, up to 9 actually, which is more than I would expect), and
>> everything starts to diverge at the first print of the main KSP (the one
>> stemming from the SNES) residual norms.
>> Do you have an idea what may cause such a strange behaviour ?
>> Best
>> Timothee
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151214/a6ae79e6/attachment.html>
