[petsc-users] PETSc runtime error
W. Miah wadud.miah at gmail.com
Sun Dec 13 15:38:01 CST 2015
Hello,
I am getting the following error:
[2]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Invalid argument!
[3]PETSC ERROR: Invalid object classid 0
This often happens if you compile with PETSC_USE_DYNAMIC_LIBRARIES, but
link with static libraries.!
[3]PETSC ERROR:
[3]PETSC ERROR: [1]PETSC ERROR:
I can't see why using static libraries should make any difference than
using shared libraries. The configure options used were:
[1]PETSC ERROR: Configure options --prefix=/home/wm/petsc-3.3.0-omp
--with-blas-lapack-dir=/usr/local/intel_6/xe_2013_sp1.2.144/mkl/lib/intel64
--with-debugging=0 --with-fortran-interfaces=1 --with-openmp=1 --CC=mpiicc
--CXX=mpiicpc --FC=mpiifort --with-x=0
It was built using intelmpi/intel/4.0.3 and intel/14.0.Any help will be
greatly appreciated.
Thanks in advance,
Wadud.
web: http://miahw.wordpress.com
mobile: 07905 755604
gnupg: 2E29 B22F
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151213/a380bd3c/attachment.html>
