[petsc-users] TSSetIFunction
Sat Dec 12 12:08:24 CST 2015
> On Dec 12, 2015, at 7:43 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I use TSSetIFunction and put RHS stuff in here, and don't use TSSetRHSFunction.
> This works fine with beuler, but euler gives a zero solution, so I assume explicit solvers do not call TSSetIFunction.
  Correct
>  I assume "I" is for implicit, but I also have a DAE and "When solving DAEs you must use this [TSSetIFunction] function."  I infer that I can not do DAEs explicitly, but I just wanted to check.
  Correct
> Thanks,
> Mark
