[petsc-users] Petsc Draw to pixmap
Sean Dettrick sdettrick at trialphaenergy.com
Thu Dec 3 17:03:28 CST 2015
On Dec 3, 2015, at 5:01 AM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
On Dec 3, 2015, at 5:54 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Thu, Dec 3, 2015 at 2:06 AM, Sean Dettrick <sdettrick at trialphaenergy.com<mailto:sdettrick at trialphaenergy.com>> wrote:
No, it is my fault, when I was unable to download from afterstep.org<http://afterstep.org> earlier I didn’t realize that it was probably my work firewall blocking me.  Thus sending me on a wild goose chase with macports and home-brew and github version, which didn’t compile.
But now I’ve tried to follow your advice, and have a new problem.
I installed Afterimage from your suggested site, with suggested X lib flags:
  ./configure --x-includes=/opt/X11/include -x-libraries=/opt/X11/lib
Did you check that it worked? Configure can (semi-)silently turn things off.
  Yes, I think Matt is right. This is the error message you get if afterimage was installed without X. Check through all the logs and build stuff of afterimage.
Thanks!  The thing finally works.  I had to clean everything and do fresh installs, but now it is fine.
Summarizing my experience of afterimage on a mac in case anybody else wants to do it:
Afterimage on the mac is in theory available via macports as part of the afterstep package, but it failed to build on my Mac (Yosemite).  It is not available in home-brew.  The current github version of afterimage failed to build on my mac.  The version from http://www.afterstep.org/afterimage/getcode.php DOES work, configured as:
./configure --x-includes=/opt/X11/include --x-libraries=/opt/X11/lib --with-x
make
make install
Then petsc is configured as:
./configure --with-afterimage --download-hdf5 --download-mpich
The example src/dm/examples/tutorials/ex5.c then works:
./ex5 -draw_save
Cheers,
Sean
 Barry
   Matt
  make
  make install
No errors.  Then re-configured and built petsc:
  export PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1
  export PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage
 ./configure --with-afterimage --download-hdf5 --download-mpich --PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage --PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1
  make PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1 PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage all
No errors.  Then try to run an example with image output:
  cd src/dm/examples/tutorials/
  make ex5
  ./ex5
  ./ex5 -draw_save test.png
The example generates the error you mentioned, which it didn’t before installing afterimage:
X Error of failed request:  BadValue (integer parameter out of range for operation)
 Major opcode of failed request:  1 (X_CreateWindow)
 Value in failed request:  0x40
 Serial number of failed request:  7
 Current serial number in output stream:  14
Browsing through configure.log, it seems that petsc is using the same X11 library.
Did I miss something?
Thanks!
Sean
On Dec 2, 2015, at 11:10 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
I am such an idiot. No I did build it from source I forgot the comment in afterimage.py
After image is available from http://www.afterstep.org/afterimage/getcode.php
#  It is used by the PetscDrawSetSave() routine to save X windows graphics to files
#  If installing on an Apple make sure to read the details on PetscDrawSetSave manual
#  page before installing
from that page I found
If X windows generates an error message about X_CreateWindow() failing then Afterimage was installed without X windows. Reinstall Afterimage using the
 ./configure flags --x-includes=/pathtoXincludes --x-libraries=/pathtoXlibraries   For example under Mac OS X Mountain Lion --x-includes=/opt/X11/include -x-libraries=/opt/X11/lib
Did you try all this stuff?
Barry
On Dec 3, 2015, at 1:00 AM, Sean Dettrick <sdettrick at trialphaenergy.com<mailto:sdettrick at trialphaenergy.com>> wrote:
Hi Barry,
Thanks for the amazingly fast reply.  I installed home-brew but then was unable to find afterstep available as a package.  The closest thing I could find was asterm (after step terminal emulator.  Do you remember if you installed it from a canonical repo?
I did find afterstep on github, but had trouble installing it on the mac.
Meanwhile, a colleague has given me a python script, so I’ll probably use that instead for now.
Thanks again,
Sean
On Dec 2, 2015, at 1:45 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
Sean,
I have never been able to build from that source either.
I used homebrew to install it and its worked for several years.
I also tried to see if one could pull the image from the X pixel map and it looked like a huge project (the pixmap stuff is not as trivial as one would think it would be) so I gave up on that and started using afterimage (which essentially does all the for you).
Barry
On Dec 2, 2015, at 3:39 PM, Sean Dettrick <sdettrick at trialphaenergy.com<mailto:sdettrick at trialphaenergy.com>> wrote:
I’d like to have petsc draw output to a pixmap, but have been unable to install afterstep on my Mac.  Direct download of the tar files from http://www.afterstep.org/afterimage/getcode.php failed, as did cvs checkout.  It seems the target sites may not exist at present.
Is there another way to install afterstep?
Alternatively, is there a way to manually redirect the X11 output using something like XCreatePixmap?
Thanks!
Sean Dettrick
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151203/faa8aa02/attachment-0001.html>
