[petsc-users] Petsc Draw to pixmap
Thu Dec 3 07:01:09 CST 2015
> On Dec 3, 2015, at 5:54 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 3, 2015 at 2:06 AM, Sean Dettrick <sdettrick at trialphaenergy.com> wrote:
> No, it is my fault, when I was unable to download from afterstep.org earlier I didn’t realize that it was probably my work firewall blocking me.  Thus sending me on a wild goose chase with macports and home-brew and github version, which didn’t compile.
> But now I’ve tried to follow your advice, and have a new problem.
> I installed Afterimage from your suggested site, with suggested X lib flags:
>    ./configure --x-includes=/opt/X11/include -x-libraries=/opt/X11/lib
> Did you check that it worked? Configure can (semi-)silently turn things off.
   Yes, I think Matt is right. This is the error message you get if afterimage was installed without X. Check through all the logs and build stuff of afterimage.
  Barry
>   Thanks,
>     Matt
>    make
>    make install
> No errors.  Then re-configured and built petsc:
>    export PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1
>    export PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage
>   ./configure --with-afterimage --download-hdf5 --download-mpich --PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage --PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1
>    make PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1 PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage all
> No errors.  Then try to run an example with image output:
>    cd src/dm/examples/tutorials/
>    make ex5
>    ./ex5
>    ./ex5 -draw_save test.png
> The example generates the error you mentioned, which it didn’t before installing afterimage:
> X Error of failed request:  BadValue (integer parameter out of range for operation)
>   Major opcode of failed request:  1 (X_CreateWindow)
>   Value in failed request:  0x40
>   Serial number of failed request:  7
>   Current serial number in output stream:  14
> Browsing through configure.log, it seems that petsc is using the same X11 library.
> Did I miss something?
> Thanks!
> Sean
>> On Dec 2, 2015, at 11:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  I am such an idiot. No I did build it from source I forgot the comment in afterimage.py
>>  After image is available from http://www.afterstep.org/afterimage/getcode.php
>> #  It is used by the PetscDrawSetSave() routine to save X windows graphics to files
>> #  If installing on an Apple make sure to read the details on PetscDrawSetSave manual
>> #  page before installing
>> from that page I found
>> If X windows generates an error message about X_CreateWindow() failing then Afterimage was installed without X windows. Reinstall Afterimage using the
>>   ./configure flags --x-includes=/pathtoXincludes --x-libraries=/pathtoXlibraries   For example under Mac OS X Mountain Lion --x-includes=/opt/X11/include -x-libraries=/opt/X11/lib
>> Did you try all this stuff?
>>  Barry
>>> On Dec 3, 2015, at 1:00 AM, Sean Dettrick <sdettrick at trialphaenergy.com> wrote:
>>> Hi Barry,
>>> Thanks for the amazingly fast reply.  I installed home-brew but then was unable to find afterstep available as a package.  The closest thing I could find was asterm (after step terminal emulator.  Do you remember if you installed it from a canonical repo?
>>> I did find afterstep on github, but had trouble installing it on the mac.
>>> Meanwhile, a colleague has given me a python script, so I’ll probably use that instead for now.
>>> Thanks again,
>>> Sean
>>>> On Dec 2, 2015, at 1:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Sean,
>>>> I have never been able to build from that source either.
>>>> I used homebrew to install it and its worked for several years.
>>>> I also tried to see if one could pull the image from the X pixel map and it looked like a huge project (the pixmap stuff is not as trivial as one would think it would be) so I gave up on that and started using afterimage (which essentially does all the for you).
>>>> Barry
>>>>> On Dec 2, 2015, at 3:39 PM, Sean Dettrick <sdettrick at trialphaenergy.com> wrote:
>>>>> Hi,
>>>>> I’d like to have petsc draw output to a pixmap, but have been unable to install afterstep on my Mac.  Direct download of the tar files from http://www.afterstep.org/afterimage/getcode.php failed, as did cvs checkout.  It seems the target sites may not exist at present.
>>>>> Is there another way to install afterstep?
>>>>> Alternatively, is there a way to manually redirect the X11 output using something like XCreatePixmap?
>>>>> Thanks!
>>>>> Sean Dettrick
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
