[petsc-users] Problem with linking PETSc
TAY wee-beng zonexo at gmail.com
Fri Aug 28 03:20:22 CDT 2015
Hi Satish,
Was searching high and low at the wrong place! I accidentally removed
the libpetsc.lib from the library files...
Now it worked.
Thank you
Yours sincerely,
TAY wee-beng
On 28/8/2015 12:46 PM, Satish Balay wrote:
> I don't see a compile of ex2f in the copy/paste. Assuming that ran
> correctly and [ex2f was not an old binary lying arround] - it implies
> that your project file has bugs.
> Perhaps there is a verbose mode that it provides that you can use to
> see the exact compile command its using.
> I suspect its missing the equivalent of the following options:
> -L/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/petsc-3.6.1_win64_impi_vs2008/lib  -lpetsc
> Satish
> On Thu, 27 Aug 2015, TAY wee-beng wrote:
>> On 27/8/2015 11:38 PM, Satish Balay wrote:
>>> Are you able to compile and run both C and fortran petsc examples
>>> using the corresponding makefile?
>>> Satish
>> Hi Satish,
>> Yes, there is no problem except for a minor warning:
>> /*$ make ex2*//*
>> *//*/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/bin/win32fe/win32fe cl -o ex2.o
>> -c -MT -wd4996 -Z7 -I/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/include
>> -I/cygdrive/c*//*
>> *//*/wtay/Backup/Codes/petsc-3.6.1/petsc-3.6.1_win64_impi_vs2008/include
>> -I/cygdrive/c/Program\ Files\
>> \(x86\)/IntelSWTools/mpi/5.1.1.110/intel64/include    `pwd`/e*//*
>> *//*x2.c*//*
>> *//*ex2.c*//*
>> *//*You are using an Intel supplied intrinsic header file with a third-party
>> compiler.*//*
>> *//*/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/bin/win32fe/win32fe cl -MT
>> -wd4996 -Z7  -o ex2 ex2.o
>> -L/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/petsc-3.6.1_win64_im*//*
>> *//*pi_vs2008/lib  -lpetsc
>> -L/cygdrive/c/wtay/Lib/petsc-3.6.1_win64_impi_vs2008/lib -lflapack -lfblas
>> /cygdrive/c/Program\ Files\ \(x86\)/IntelSWTools/mpi/5.1.1.110*//*
>> *//*/intel64/lib/debug/impi.lib /cygdrive/c/Program\ Files\
>> \(x86\)/IntelSWTools/mpi/5.1.1.110/intel64/lib/impicxx.lib
>> /cygdrive/c/Program\ Files\ \(x86\)/IntelSWTo*//*
>> *//*ols/mpi/5.1.1.110/intel64/lib/impicxxd.lib /cygdrive/c/Program\ Files\
>> \(x86\)/IntelSWTools/mpi/5.1.1.110/intel64/lib/libmpi_ilp64.lib Gdi32.lib
>> User32.lib Adva*//*
>> *//*pi32.lib Kernel32.lib Ws2_32.lib*//*
>> *//*/usr/bin/rm -f ex2.o*//*
>> *//*tsltaywb at 1C3YYY1
>> /cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/src/ksp/ksp/examples/tutorials*//*
>> *//*$ ./ex2f*//*
>> *//*Norm of error  0.1192E-05 iterations     4*//*
>> *//*$ mpiexec -n 2 ./ex2f*//*
>> *//*Norm of error < 1.e-12,iterations     7*/
>>>> Hi,
>>>> I used to compile and link using PETSc 3.6.0 + MPICH2 on VS2008.
>>>> Due to some MPICH2 issues, I am trying to use Intel MPI (newest version).
>>>> Building and testing of PETSc 3.6.1 with Intel MPI all went smoothly.
>>>> However, I now have problem linking the files on VS2008 to create the
>>>> final
>>>> exe. The error is:
>>>> /*1>Compiling manifest to resources...*//*
>>>> *//*1>Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0*//*
>>>> *//*1>Copyright (C) Microsoft Corporation.  All rights reserved.*//*
>>>> *//*1>Linking...*//*
>>>> *//*1>global.obj : error LNK2019: unresolved external symbol MATCREATEAIJ
>>>> referenced in function GLOBAL_DATA_mp_ALLO_VAR*//*
>>>> MATSETFROMOPTIONS
>>>> *//*1>PETSc_solvers.obj : error LNK2019: unresolved external symbol
>>>> VECGETARRAY referenced in function
>>>> PETSC_SOLVERS_mp_P_MATRIX_SOLV_PETSC*//*
>>>> VECRESTOREARRAY referenced in function
>>>> DMLOCALTOLOCALBEGIN referenced in function
>>>> PETSC_SOLVERS_mp_DM_UPDATE_ARRAY*//*
>>>> DMLOCALTOLOCALEND referenced in function
>>>> *//*1>ibm3d_high_Re.obj : error LNK2019: unresolved external symbol
>>>> PETSCINITIALIZE referenced in function MAIN__*//*
>>>> *//*1>C:\Obj_tmp\ibm3d_IIB_mpi_old\Debug\ibm3d_IIB_mpi.exe : fatal error
>>>> LNK1120: 74 unresolved externals*//*
>>>> *//*1>*//*
>>>> *//*1>Build log written to
>>>> "file://C:\Obj_tmp\ibm3d_IIB_mpi_old\Debug\BuildLog.htm"*//*
>>>> *//*1>ibm3d_IIB_mpi_old - 165 error(s), 0 warning(s)*//*
>>>> *//*========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========*/
>>>> I did not do much changes since the prev PETSc worked. I only changed the
>>>> directory $(PETSC_DIR) and $(IMPI) to the new directory in win7
>>>> environment
>>>> variables. I wonder what's wrong.
