[petsc-users] Problem with linking PETSc
Thu Aug 27 23:46:48 CDT 2015
I don't see a compile of ex2f in the copy/paste. Assuming that ran
correctly and [ex2f was not an old binary lying arround] - it implies
that your project file has bugs.
Perhaps there is a verbose mode that it provides that you can use to
see the exact compile command its using.
I suspect its missing the equivalent of the following options:
-L/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/petsc-3.6.1_win64_impi_vs2008/lib  -lpetsc
Satish
On Thu, 27 Aug 2015, TAY wee-beng wrote:
> On 27/8/2015 11:38 PM, Satish Balay wrote:
> > Are you able to compile and run both C and fortran petsc examples
> > using the corresponding makefile?
> > Satish
> Hi Satish,
> Yes, there is no problem except for a minor warning:
> /*$ make ex2*//*
> *//*/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/bin/win32fe/win32fe cl -o ex2.o
> -c -MT -wd4996 -Z7 -I/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/include
> -I/cygdrive/c*//*
> *//*/wtay/Backup/Codes/petsc-3.6.1/petsc-3.6.1_win64_impi_vs2008/include
> -I/cygdrive/c/Program\ Files\
> \(x86\)/IntelSWTools/mpi/5.1.1.110/intel64/include    `pwd`/e*//*
> *//*x2.c*//*
> *//*ex2.c*//*
> *//*You are using an Intel supplied intrinsic header file with a third-party
> compiler.*//*
> *//*/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/bin/win32fe/win32fe cl -MT
> -wd4996 -Z7  -o ex2 ex2.o
> -L/cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/petsc-3.6.1_win64_im*//*
> *//*pi_vs2008/lib  -lpetsc
> -L/cygdrive/c/wtay/Lib/petsc-3.6.1_win64_impi_vs2008/lib -lflapack -lfblas
> /cygdrive/c/Program\ Files\ \(x86\)/IntelSWTools/mpi/5.1.1.110*//*
> *//*/intel64/lib/debug/impi.lib /cygdrive/c/Program\ Files\
> \(x86\)/IntelSWTools/mpi/5.1.1.110/intel64/lib/impicxx.lib
> /cygdrive/c/Program\ Files\ \(x86\)/IntelSWTo*//*
> *//*ols/mpi/5.1.1.110/intel64/lib/impicxxd.lib /cygdrive/c/Program\ Files\
> \(x86\)/IntelSWTools/mpi/5.1.1.110/intel64/lib/libmpi_ilp64.lib Gdi32.lib
> User32.lib Adva*//*
> *//*pi32.lib Kernel32.lib Ws2_32.lib*//*
> *//*/usr/bin/rm -f ex2.o*//*
> *//*tsltaywb at 1C3YYY1
> /cygdrive/c/wtay/Backup/Codes/petsc-3.6.1/src/ksp/ksp/examples/tutorials*//*
> *//*$ ./ex2f*//*
> *//*Norm of error  0.1192E-05 iterations     4*//*
> *//*$ mpiexec -n 2 ./ex2f*//*
> *//*Norm of error < 1.e-12,iterations     7*/
> > > Hi,
> > > I used to compile and link using PETSc 3.6.0 + MPICH2 on VS2008.
> > > Due to some MPICH2 issues, I am trying to use Intel MPI (newest version).
> > > Building and testing of PETSc 3.6.1 with Intel MPI all went smoothly.
> > > However, I now have problem linking the files on VS2008 to create the
> > > final
> > > exe. The error is:
> > > /*1>Compiling manifest to resources...*//*
> > > *//*1>Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0*//*
> > > *//*1>Copyright (C) Microsoft Corporation.  All rights reserved.*//*
> > > *//*1>Linking...*//*
> > > *//*1>global.obj : error LNK2019: unresolved external symbol MATCREATEAIJ
> > > referenced in function GLOBAL_DATA_mp_ALLO_VAR*//*
> > > MATSETFROMOPTIONS
> > > *//*1>PETSc_solvers.obj : error LNK2019: unresolved external symbol
> > > VECGETARRAY referenced in function
> > > PETSC_SOLVERS_mp_P_MATRIX_SOLV_PETSC*//*
> > > VECRESTOREARRAY referenced in function
> > > DMLOCALTOLOCALBEGIN referenced in function
> > > PETSC_SOLVERS_mp_DM_UPDATE_ARRAY*//*
> > > DMLOCALTOLOCALEND referenced in function
> > > *//*1>ibm3d_high_Re.obj : error LNK2019: unresolved external symbol
> > > PETSCINITIALIZE referenced in function MAIN__*//*
> > > *//*1>C:\Obj_tmp\ibm3d_IIB_mpi_old\Debug\ibm3d_IIB_mpi.exe : fatal error
> > > LNK1120: 74 unresolved externals*//*
> > > *//*1>*//*
> > > *//*1>Build log written to
> > > "file://C:\Obj_tmp\ibm3d_IIB_mpi_old\Debug\BuildLog.htm"*//*
> > > *//*1>ibm3d_IIB_mpi_old - 165 error(s), 0 warning(s)*//*
> > > *//*========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========*/
> > > I did not do much changes since the prev PETSc worked. I only changed the
> > > directory $(PETSC_DIR) and $(IMPI) to the new directory in win7
> > > environment
> > > variables. I wonder what's wrong.
