[petsc-users] Insert values into matrix using MatSetValuesStencil or MatSetValuesLocal
Wee Beng Tay zonexo at gmail.com
Mon Aug 24 21:01:47 CDT 2015
Sent using CloudMagic [https://cloudmagic.com/k/d/mailapp?ct=pa&cv=7.2.9&pv=5.0.2] On Mon, Aug 24, 2015 at 6:21 PM, Matthew Knepley < knepley at gmail.com [knepley at gmail.com] > wrote:
On Mon, Aug 24, 2015 at 4:09 AM, Wee-Beng Tay < zonexo at gmail.com [zonexo at gmail.com] > wrote:
I'm modifying my 3d fortran code from MPI along 1 direction (z) to MPI along 2
directions (y,z)
Previously I was using MatSetValues with global indices. However, now I'm using
DM and global indices is much more difficult.
I come across MatSetValuesStencil or MatSetValuesLocal.
So what's the difference bet the one since they both seem to work locally?
No. MatSetValuesLocal() takes local indices. MatSetValuesStencil() takes global
vertex numbers.
So MatSetValuesStencil() takes global vertex numbers. Do you mean the natural or
petsc ordering?
Which is a simpler/better option?
MatSetValuesStencil() Is there an example in Fortran for MatSetValuesStencil?
Timothée Nicolas shows one in his reply.
Do I also need to use DMDAGetAO together with MatSetValuesStencil or
MatSetValuesLocal?
No.
Matt Thanks!
What most experimenters take for granted before they begin their experiments is
infinitely more interesting than any results to which their experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150825/f59579cb/attachment.html>
