[petsc-users] Insert values into matrix using MatSetValuesStencil or MatSetValuesLocal
Mon Aug 24 05:21:21 CDT 2015
On Mon, Aug 24, 2015 at 4:09 AM, Wee-Beng Tay <zonexo at gmail.com> wrote:
> Hi,
> I'm modifying my 3d fortran code from MPI along 1 direction (z) to MPI
> along 2 directions (y,z)
> Previously I was using MatSetValues with global indices. However, now I'm
> using DM and global indices is much more difficult.
> I come across MatSetValuesStencil or MatSetValuesLocal.
> So what's the difference bet the one since they both seem to work locally?
No. MatSetValuesLocal() takes local indices. MatSetValuesStencil() takes
global vertex numbers.
> Which is a simpler/better option?
> Is there an example in Fortran for MatSetValuesStencil?
Timothée Nicolas shows one in his reply.
Do I also need to use DMDAGetAO together with MatSetValuesStencil or
> MatSetValuesLocal?
No.
     Matt
> Thanks!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150824/35e8b8c3/attachment.html>
