[petsc-users] Need to update matrix in every loop
Jed Brown jed at jedbrown.org
Fri Aug 14 11:10:02 CDT 2015
Please always use "reply-all" so that your messages go to the list.
This is standard mailing list etiquette.  It is important to preserve
threading for people who find this discussion later and so that we do
not waste our time re-answering the same questions that have already
been answered in private side-conversations.  You'll likely get an
answer faster that way too.
sheng liu <ustc.liu at gmail.com> writes:
> Thank you! I have a small question: What does the "degree of freedom" mean
> in the DMDA object? If I have a spin-1/2 system, and I discrete the system,
> does that mean I have DOF=2?
DOF is the number of PetscScalar values at each grid point.
> 2015-08-12 23:46 GMT+08:00 Jed Brown <jed at jedbrown.org>:
>> > Thank you very much! I have another question. If I need all the
>> eigenvalues
>> > of the sparse matrix, which solver should I use? Thanks!
>> That's O(n^3) with n=1e6.  Better find a way to not need all the
>> eigenvalues or to make the system smaller.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150814/33beb2d5/attachment.pgp>
