[petsc-users] Mapping between application ordering and Petsc ordering
Mani Chandra mc0710 at gmail.com
Sat Aug 8 13:52:00 CDT 2015
I'm having trouble interfacing petsc to an application which I think is
related to the ordering of the nodes. Here's what I'm trying to do:
The application uses a structured grid with a global array having
dimensions N1 x N2, which is then decomposed into a local array with
dimensions NX1 x NX2.
I create a Petsc DMDA using
    DMDACreate2d(MPI_COMM_WORLD,
                 DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC,
                 DMDA_STENCIL_BOX,
                 N1, N2,
                 N1/NX1, N2/NX2,
                 1, nghost, PETSC_NULL, PETSC_NULL,
                 &dmda);
and then use this to create a vec:
  DMCreateGlobalVector(dmda, &vec);
Now I copy the local contents of the application array to the petsc array
using the following:
Let i, j be the application indices and iPetsc and jPetsc be petsc's
indices, then:
DMDAGetCorners(dmda, &iStart, &jStart, &kStart,
                                         &iSize, &jSize, &kSize
double **arrayPetsc;
DMDAVecGetArray(dmda, vec, &arrayPetsc);
for (int j=0, jPetsc=jStart; j<NX2, jPetsc<jStart+jSize; j++, jPetsc++)
  for (int i=0, iPetsc=iStart; i<NX1, iPetsc<iStart+iSize; i++, iPetsc++)
     arrayPetsc[jPetsc][iPetsc] = arrayApplication[j][i];
DMDAVecRestoreArray(dmda, vec, &arrayPetsc);
Now if I VecView(vec, viewer) and look at the data that petsc has, it looks
right when run with 1 proc, but if I use 4 procs it's all messed up (see
attached plots).
I should probably be using the AO object but its not clear how. Could you
help me out?
Mani
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150808/c045b080/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150808/c045b080/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150808/c045b080/attachment-0003.png>
