[petsc-users] SIGSEGV in Superlu_dist
Wed Aug 12 14:17:08 CDT 2015
On Wed, Aug 12, 2015 at 2:01 PM, Anthony Haas <aph at email.arizona.edu> wrote:
> Hi Hong,
> I have attached a schematic of my matrices. I solve a generalized EVP in
> shift-and-invert mode. As you will see, I have indeed a zero diagonal block
> in the matrices A and B (blocks 4,4). I guess I could just add the zero
> entries to the diagonal elements of A? Is that strictly necessary when
> using a direct (LU) solver? Can you please give me a short explanation of
> why empty diagonal blocks can be problematic?
Yes, the sparse numbering schemes use the location of the diagonal for
faster indexing in many places.
   Matt
> Is the patch still available at:
> https://bitbucket.org/petsc/petsc/commits/ceeba3afeff0c18262ed13ef92e2508ca68b0ecf
> Thanks again,
> Anthony
> On 08/12/2015 08:58 AM, Hong wrote:
>> Anthony,
>> I just patched petsc-maint branch.
>> Your matrix Amat_binary.m has empty diagonal blocks. Most petsc solvers
>> require matrix diagonal entries to be allocated as 'non-zero', i.e., insert
>> zero values to these zero entries. I would suggest you add zeros to
>> Amat_binary.m during its buildup. This would enable petsc solvers, as well
>> as other packages.
>> Again, thanks for bug reporting.
>> Hong
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150812/1fbd1470/attachment.html>
