[petsc-users] Mapping between application ordering and Petsc ordering
Fabian Fabian.Jakub at physik.uni-muenchen.de
Sun Aug 9 14:31:49 CDT 2015
If the problem is due to the rank-ordering, the following excerpt from
the PETSc FAQ section may help:
<http://www.mcs.anl.gov/petsc/documentation/faq.html#da_mpi_cart>
The PETSc DA object decomposes the domain differently than the
MPI_Cart_create() command. How can one use them together?
The MPI_Cart_create() first divides the mesh along the z direction, then
the y, then the x. DMDA divides along the x, then y, then z. Thus, for
example, rank 1 of the processes will be in a different part of the mesh
for the two schemes. To resolve this you can create a new MPI
communicator that you pass to DMDACreate() that renumbers the process
ranks so that each physical process shares the same part of the mesh
with both the DMDA and the MPI_Cart_create(). The code to determine the
new numbering was provided by Rolf Kuiper.
// the numbers of processors per direction are (int) x_procs, y_procs, z_procs respectively
// (no parallelization in direction 'dir' means dir_procs = 1)
MPI_Comm NewComm;
int MPI_Rank, NewRank, x,y,z;
// get rank from MPI ordering:
MPI_Comm_rank(MPI_COMM_WORLD, &MPI_Rank);
// calculate coordinates of cpus in MPI ordering:
x = MPI_rank / (z_procs*y_procs);
y = (MPI_rank % (z_procs*y_procs)) / z_procs;
z = (MPI_rank % (z_procs*y_procs)) % z_procs;
// set new rank according to PETSc ordering:
NewRank = z*y_procs*x_procs + y*x_procs + x;
// create communicator with new ranks according to
PETSc ordering:
MPI_Comm_split(PETSC_COMM_WORLD, 1, NewRank, &NewComm);
// override the default communicator (was
MPI_COMM_WORLD as default)
PETSC_COMM_WORLD = NewComm;
On 08.08.2015 23:58, Matthew Knepley wrote:
> On Sat, Aug 8, 2015 at 4:56 PM, Mani Chandra <mc0710 at gmail.com
> <mailto:mc0710 at gmail.com>> wrote:
>     So basically one needs to correctly map
>     iPetsc, jPetsc -> iApplication, jApplication ?
>     Is there is any standard way to do this? Can I get petsc to
>     automatically follow the same parallel topology as the host
>     application?
> If you want to use DMDA, there is only one mapping of ranks, namely
> lexicographic. However, every structured grid code I have
> ever seen uses that mapping, perhaps with a permutation of the
> directions {x, y, z}. Thus, the user needs to map the directions
> in PETSc in the right order for the application. I am not sure how you
> would automate this seeing as it depends on the application.
>   Thanks,
>      Matt
>     Thanks,
>     Mani
>     On Sat, Aug 8, 2015 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov
>     <mailto:bsmith at mcs.anl.gov>> wrote:
>         > On Aug 8, 2015, at 3:08 PM, Mani Chandra <mc0710 at gmail.com
>         > Tried flipping the indices, I get a seg fault.
>           You would have to be careful in exactly what you flip.  Note
>         that the meaning of N1 and N2 etc would also be reversed
>         between your code and the PETSc DMDA code.
>           I would create a tiny DMDA and put entires like 1 2 3 4 ...
>         into the array so you can track where the values go
>           Barry
>         > On Sat, Aug 8, 2015 at 3:03 PM, Barry Smith
>         <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>         > > On Aug 8, 2015, at 2:45 PM, Mani Chandra <mc0710 at gmail.com
>         > > Thanks. Any suggestions for a fix?
>         >   Just flip the meaning of the x indices and the y indices
>         in the PETSc parts of the code?
>         >   Also run with a very different N1 and  N2 (instead of
>         equal size) to better test the code coupling.
>         >   Barry
>         > > Reorder the indices in arrayApplication?
>         > > On Sat, Aug 8, 2015 at 2:19 PM, Matthew Knepley
>         <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>         > > On Sat, Aug 8, 2015 at 1:52 PM, Mani Chandra
>         <mc0710 at gmail.com <mailto:mc0710 at gmail.com>> wrote:
>         > > Hi,
>         > > I'm having trouble interfacing petsc to an application
>         which I think is related to the ordering of the nodes. Here's
>         what I'm trying to do:
>         > > The application uses a structured grid with a global array
>         having dimensions N1 x N2, which is then decomposed into a
>         local array with dimensions NX1 x NX2.
>         > > I create a Petsc DMDA using
>         > >     DMDACreate2d(MPI_COMM_WORLD,
>         > >                  DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC,
>         > >                  DMDA_STENCIL_BOX,
>         > >                  N1, N2,
>         > >                  N1/NX1, N2/NX2,
>         > >                  1, nghost, PETSC_NULL, PETSC_NULL,
>         > >                  &dmda);
>         > > and then use this to create a vec:
>         > >   DMCreateGlobalVector(dmda, &vec);
>         > > Now I copy the local contents of the application array to
>         the petsc array using the following:
>         > > Let i, j be the application indices and iPetsc and jPetsc
>         be petsc's indices, then:
>         > > DMDAGetCorners(dmda, &iStart, &jStart, &kStart,
>         > >   &iSize, &jSize, &kSize
>         > > double **arrayPetsc;
>         > > DMDAVecGetArray(dmda, vec, &arrayPetsc);
>         > > for (int j=0, jPetsc=jStart; j<NX2, jPetsc<jStart+jSize;
>         j++, jPetsc++)
>         > >   for (int i=0, iPetsc=iStart; i<NX1, iPetsc<iStart+iSize;
>         i++, iPetsc++)
>         > >      arrayPetsc[jPetsc][iPetsc] = arrayApplication[j][i];
>         > > DMDAVecRestoreArray(dmda, vec, &arrayPetsc);
>         > > Now if I VecView(vec, viewer) and look at the data that
>         petsc has, it looks right when run with 1 proc, but if I use 4
>         procs it's all messed up (see attached plots).
>         > > I should probably be using the AO object but its not clear
>         how. Could you help me out?
>         > > It looks like you have the global order of processes
>         reversed, meaning you have
>         > >   1   3
>         > >   0   2
>         > > and it should be
>         > >   2  3
>         > >   0  1
>         > >   Thanks,
>         > >       Matt
>         > > Thanks,
>         > > Mani
>         > > What most experimenters take for granted before they begin
>         their experiments is infinitely more interesting than any
>         results to which their experiments lead.
>         > > -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150809/044a5df4/attachment.html>
