[petsc-users] Mapping between application ordering and Petsc ordering
Sat Aug 8 16:58:49 CDT 2015
On Sat, Aug 8, 2015 at 4:56 PM, Mani Chandra <mc0710 at gmail.com> wrote:
> So basically one needs to correctly map
> iPetsc, jPetsc -> iApplication, jApplication ?
> Is there is any standard way to do this? Can I get petsc to automatically
> follow the same parallel topology as the host application?
If you want to use DMDA, there is only one mapping of ranks, namely
lexicographic. However, every structured grid code I have
ever seen uses that mapping, perhaps with a permutation of the directions
{x, y, z}. Thus, the user needs to map the directions
in PETSc in the right order for the application. I am not sure how you
would automate this seeing as it depends on the application.
     Matt
> Thanks,
> Mani
> On Sat, Aug 8, 2015 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > On Aug 8, 2015, at 3:08 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>> > Tried flipping the indices, I get a seg fault.
>>   You would have to be careful in exactly what you flip.  Note that the
>> meaning of N1 and N2 etc would also be reversed between your code and the
>> PETSc DMDA code.
>>   I would create a tiny DMDA and put entires like 1 2 3 4 ... into the
>> array so you can track where the values go
>>   Barry
>> > On Sat, Aug 8, 2015 at 3:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > > On Aug 8, 2015, at 2:45 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>> > > Thanks. Any suggestions for a fix?
>> >   Just flip the meaning of the x indices and the y indices in the PETSc
>> parts of the code?
>> >   Also run with a very different N1 and  N2 (instead of equal size) to
>> better test the code coupling.
>> >   Barry
>> > > Reorder the indices in arrayApplication?
>> > > On Sat, Aug 8, 2015 at 2:19 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > > On Sat, Aug 8, 2015 at 1:52 PM, Mani Chandra <mc0710 at gmail.com>
>> wrote:
>> > > Hi,
>> > > I'm having trouble interfacing petsc to an application which I think
>> is related to the ordering of the nodes. Here's what I'm trying to do:
>> > > The application uses a structured grid with a global array having
>> dimensions N1 x N2, which is then decomposed into a local array with
>> dimensions NX1 x NX2.
>> > > I create a Petsc DMDA using
>> > >     DMDACreate2d(MPI_COMM_WORLD,
>> > >                  DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC,
>> > >                  DMDA_STENCIL_BOX,
>> > >                  N1, N2,
>> > >                  N1/NX1, N2/NX2,
>> > >                  1, nghost, PETSC_NULL, PETSC_NULL,
>> > >                  &dmda);
>> > > and then use this to create a vec:
>> > >   DMCreateGlobalVector(dmda, &vec);
>> > > Now I copy the local contents of the application array to the petsc
>> array using the following:
>> > > Let i, j be the application indices and iPetsc and jPetsc be petsc's
>> indices, then:
>> > > DMDAGetCorners(dmda, &iStart, &jStart, &kStart,
>> > >                                          &iSize, &jSize, &kSize
>> > > double **arrayPetsc;
>> > > DMDAVecGetArray(dmda, vec, &arrayPetsc);
>> > > for (int j=0, jPetsc=jStart; j<NX2, jPetsc<jStart+jSize; j++,
>> jPetsc++)
>> > >   for (int i=0, iPetsc=iStart; i<NX1, iPetsc<iStart+iSize; i++,
>> iPetsc++)
>> > >      arrayPetsc[jPetsc][iPetsc] = arrayApplication[j][i];
>> > > DMDAVecRestoreArray(dmda, vec, &arrayPetsc);
>> > > Now if I VecView(vec, viewer) and look at the data that petsc has, it
>> looks right when run with 1 proc, but if I use 4 procs it's all messed up
>> (see attached plots).
>> > > I should probably be using the AO object but its not clear how. Could
>> you help me out?
>> > > It looks like you have the global order of processes reversed,
>> meaning you have
>> > >   1   3
>> > >   0   2
>> > > and it should be
>> > >   2  3
>> > >   0  1
>> > >   Thanks,
>> > >       Matt
>> > > Thanks,
>> > > Mani
>> > > What most experimenters take for granted before they begin their
>> experiments lead.
>> > > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150808/2a36898f/attachment.html>
