[petsc-users] Fail to Configure petsc-3.6.1
Rongliang Chen rongliang.chan at gmail.com
Wed Aug 5 01:05:55 CDT 2015
Hi Jed,
Thanks for your reply.
I checked the netcdf and hdf5's config.log and could not find any
possible solutions. Can you help me check these two files again? The two
files are attached. Thanks.
Best regards,
Rongliang
On 08/05/2015 12:26 PM, Jed Brown wrote:
> Rongliang Chen <rongliang.chan at gmail.com> writes:
>> Hi there,
>> I tried to configure the petsc-3.6.1 on my laptop but failed with the
>> following error. The configure.log is attached. Any suggestions? Thanks.
>> configure: error: Can't find or link to the hdf5 library. Use
>> --disable-netcdf-4, or see config.log for errors.
> Looks like you'll have to check NetCDF's config.log for the details.
> Either something is wrong with the HDF5 install or the wrong options are
> being passed to NetCDF configure.
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/77fb9058/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/77fb9058/attachment-0003.bin>
