[petsc-users] Fail to Configure petsc-3.6.1
Jed Brown jed at jedbrown.org
Tue Aug 4 23:26:35 CDT 2015
Rongliang Chen <rongliang.chan at gmail.com> writes:
> Hi there,
> I tried to configure the petsc-3.6.1 on my laptop but failed with the
> following error. The configure.log is attached. Any suggestions? Thanks.
> configure: error: Can't find or link to the hdf5 library. Use
> --disable-netcdf-4, or see config.log for errors.
Looks like you'll have to check NetCDF's config.log for the details.
Either something is wrong with the HDF5 install or the wrong options are
being passed to NetCDF configure.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150804/78bd0359/attachment.pgp>
