[petsc-users] install petsc with valgrind
Sun, Hui hus003 at ucsd.edu
Fri Apr 17 17:17:02 CDT 2015
Thank you Matt!
Hui
Sent: Friday, April 17, 2015 3:10 PM
To: Sun, Hui
Cc: Barry Smith; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] install petsc with valgrind
On Fri, Apr 17, 2015 at 5:09 PM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
I'm not sure if I'm doing the right thing. But I have just
export PATH=$PATH:dir_to_valgind_bin
And I rerun the command:
-@${PETSC_DIR}/bin/petscmpiexec -valgrind -n ${NP} ./test -mx ${ND} -my ${ND} -mz ${ND} -ksp_monitor_short -ksp_type fgmres -pc_type asm
Then it seems to output something, for example:
==66450== Invalid write of size 8
==66450==    at 0x100055225: Schur_SetMatrix (in ./test)
==66450==    by 0x10004F218: StokesSetup (in ./test)
==66450==    by 0x1000DC582: main (in ./test)
==66450==  Address 0x7fff5f93fb28 is on thread 1's stack
==66450==  in frame #0, created by Schur_SetMatrix (???)
==66450==
Yes, this worked, and it shows you have a memory overwrite in your code. You have no line
numbers because you deleted the *.o files without running dsymutil.
And before those output, it has the following lines:
--66450-- run: /usr/bin/dsymutil "./test"
warning: (x86_64) /Users/hus003/projects/LS_BDRY/test/test.o unable to open object file
warning: no debug symbols in executable (-arch x86_64)
--66450-- run: /usr/bin/dsymutil "/Users/hus003/Documents/software/petsc-valgrind/petsc-valgrind-debug/lib/libpetsc.3.05.3.dylib"
--66450-- run: /usr/bin/dsymutil "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpicxx.12.dylib"
--66450-- run: /usr/bin/dsymutil "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpifort.12.dylib"
--66450-- run: /usr/bin/dsymutil "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpi.12.dylib"
--66450-- run: /usr/bin/dsymutil "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libpmpi.12.dylib"
Does it mean that it's working? But what does these two warnings mean?
These warnings mean that symbols are missing from those libraries, which is no surprise.
   matt
Best,
Hui
From: Barry Smith [bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>]
Sent: Friday, April 17, 2015 2:57 PM
To: Matthew Knepley
Cc: Sun, Hui; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
  Or make sure valgrind is in your path
> On Apr 17, 2015, at 4:56 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
> As I said, it cannot find valgrind in your path. Remove it or install valgrind.
>    Matt
> On Fri, Apr 17, 2015 at 4:55 PM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
> Thank you, Matt and Barry. I was trying to run the following:
> where NP=2, ND=32
> And in the makefile I have specified the following:
> include ${PETSC_DIR}/lib/petsc/conf/variables
> include ${PETSC_DIR}/lib/petsc/conf/rules
> include ${PETSC_DIR}/lib/petsc/conf/test
> Best,
> Hui
> Sent: Friday, April 17, 2015 2:50 PM
> To: Sun, Hui
> Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
>   Please please please always show WHAT YOU RAN with the error message. Otherwise we just must guess
> > On Apr 17, 2015, at 3:58 PM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
> > Thank you Barry. I just have it installed. And I was running a code, and got the following error message:
> > HYDU_create_process (utils/launch/launch.c:75): execvp error on file valgrind: (No such file or directory)
> > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > =   PID 66059 RUNNING AT math178.ucsd.edu<http://math178.ucsd.edu>
> > =   EXIT CODE: 255
> > =   CLEANING UP REMAINING PROCESSES
> > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > What does this mean?
> > Best,
> > Hui
> > Sent: Friday, April 17, 2015 1:08 PM
> > To: Sun, Hui
> >   The development copy of PETSc allows using --prefix with MPICH  http://www.mcs.anl.gov/petsc/developers/index.html
> >> On Apr 17, 2015, at 2:38 PM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
> >> Hello,
> >> I want to install petsc with valgrind. And I read some documentations, which suggests me to do
> >> ./configure --download-mpich --with-valgind-dir=…
> >> However, I also want to specify --prefix, but petsc doesn't allow me, because --download-mpich option does not work with --prefix install.
> >> Is there anyway that I can have petsc --prefix, together with valgrind?
> >> Best,
> >> Hui
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150417/850f969b/attachment-0001.html>
