[petsc-users] install petsc with valgrind
Fri Apr 17 17:10:45 CDT 2015
On Fri, Apr 17, 2015 at 5:09 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
> I'm not sure if I'm doing the right thing. But I have just
> export PATH=$PATH:dir_to_valgind_bin
> And I rerun the command:
> -@${PETSC_DIR}/bin/petscmpiexec -valgrind -n ${NP} ./test -mx ${ND} -my
> ${ND} -mz ${ND} -ksp_monitor_short -ksp_type fgmres -pc_type asm
> Then it seems to output something, for example:
> ==66450== Invalid write of size 8
> ==66450==    at 0x100055225: Schur_SetMatrix (in ./test)
> ==66450==    by 0x10004F218: StokesSetup (in ./test)
> ==66450==    by 0x1000DC582: main (in ./test)
> ==66450==  Address 0x7fff5f93fb28 is on thread 1's stack
> ==66450==  in frame #0, created by Schur_SetMatrix (???)
> ==66450==
Yes, this worked, and it shows you have a memory overwrite in your code.
You have no line
numbers because you deleted the *.o files without running dsymutil.
> And before those output, it has the following lines:
> --66450-- run: /usr/bin/dsymutil "./test"
> warning: (x86_64) /Users/hus003/projects/LS_BDRY/test/test.o unable to
> open object file
> warning: no debug symbols in executable (-arch x86_64)
> "/Users/hus003/Documents/software/petsc-valgrind/petsc-valgrind-debug/lib/libpetsc.3.05.3.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpicxx.12.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpifort.12.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpi.12.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libpmpi.12.dylib"
> Does it mean that it's working? But what does these two warnings mean?
These warnings mean that symbols are missing from those libraries, which is
no surprise.
   matt
> Best,
> Hui
> From: Barry Smith [bsmith at mcs.anl.gov]
> Sent: Friday, April 17, 2015 2:57 PM
> To: Matthew Knepley
> Cc: Sun, Hui; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] install petsc with valgrind
>   Or make sure valgrind is in your path
> > On Apr 17, 2015, at 4:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > As I said, it cannot find valgrind in your path. Remove it or install
> valgrind.
> >    Matt
> > On Fri, Apr 17, 2015 at 4:55 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
> > Thank you, Matt and Barry. I was trying to run the following:
> > where NP=2, ND=32
> > And in the makefile I have specified the following:
> > include ${PETSC_DIR}/lib/petsc/conf/variables
> > include ${PETSC_DIR}/lib/petsc/conf/rules
> > include ${PETSC_DIR}/lib/petsc/conf/test
> > Best,
> > Hui
> > Sent: Friday, April 17, 2015 2:50 PM
> > To: Sun, Hui
> > Cc: petsc-users at mcs.anl.gov
> >   Please please please always show WHAT YOU RAN with the error message.
> Otherwise we just must guess
> > > On Apr 17, 2015, at 3:58 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
> > > Thank you Barry. I just have it installed. And I was running a code,
> and got the following error message:
> > > HYDU_create_process (utils/launch/launch.c:75): execvp error on file
> valgrind: (No such file or directory)
> > > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > > =   PID 66059 RUNNING AT math178.ucsd.edu
> > > =   EXIT CODE: 255
> > > =   CLEANING UP REMAINING PROCESSES
> > > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > > What does this mean?
> > > Best,
> > > Hui
> > > Sent: Friday, April 17, 2015 1:08 PM
> > > To: Sun, Hui
> > >   The development copy of PETSc allows using --prefix with MPICH
> http://www.mcs.anl.gov/petsc/developers/index.html
> > >> On Apr 17, 2015, at 2:38 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
> > >> Hello,
> > >> I want to install petsc with valgrind. And I read some
> documentations, which suggests me to do
> > >> ./configure --download-mpich --with-valgind-dir=…
> > >> However, I also want to specify --prefix, but petsc doesn't allow me,
> because --download-mpich option does not work with --prefix install.
> > >> Is there anyway that I can have petsc --prefix, together with
> valgrind?
> > >> Best,
> > >> Hui
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150417/4134c0e0/attachment.html>
