[petsc-users] Recommended examples for using KSP and multigrid with DM
Fri Apr 10 17:43:45 CDT 2015
  Are you using DMDA or DMPLEX or some other DM? Does the Poisson equation change (variable coefficient) or is it a constant coefficient with the same values for all solves? ex29.c could still possibly serve as a model for the Poisson subproblem, why do you say it is no longer valid?
  Barry
> On Apr 8, 2015, at 10:18 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> I was following example ex29 in the past to write the code to solve my Poisson eqn using DM. Now it seems that ex29 is no longer valid. Which example should I follow now?
> Also, I am using KSPBCGS to solve my momentum eqn in the past. Do I need to change much if I'm now using DM? If so, what is a good example?
> Thank you
> Yours sincerely,
> TAY wee-beng
