[petsc-users] Recommended examples for using KSP and multigrid with DM
TAY wee-beng zonexo at gmail.com
Wed Apr 8 22:18:41 CDT 2015
I was following example ex29 in the past to write the code to solve my
Poisson eqn using DM. Now it seems that ex29 is no longer valid. Which
example should I follow now?
Also, I am using KSPBCGS to solve my momentum eqn in the past. Do I need
to change much if I'm now using DM? If so, what is a good example?
Thank you
Yours sincerely,
TAY wee-beng
