[petsc-users] Seg fault when trying to access the graph of pointSF from DMPlexDistribute
Wed Apr 8 18:05:00 CDT 2015
On Wed, Apr 8, 2015 at 5:47 PM, Ataollah Mesgarnejad <amesga1 at tigers.lsu.edu
> wrote:
> Dear all,
> I get a weird segmentation fault when I try to access the arrays of
> PetscInt and PetscSFNode from are the graph of the pointSF that
> DMPlexDistribute returns. I'm attaching a small test that can show the
> problem. You can run with:
The leaves can be NULL if it is a contiguous array covering all indices.
You can see that the Plex code checks for this.
    Matt
> testPointSF -i TwoTri.gen
> As always thank you for your help,
> Ata
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/687d287c/attachment.html>
