[petsc-users] Seg fault when trying to access the graph of pointSF from DMPlexDistribute
Ataollah Mesgarnejad amesga1 at tigers.lsu.edu
Wed Apr 8 17:47:49 CDT 2015
Dear all,
I get a weird segmentation fault when I try to access the arrays of
PetscInt and PetscSFNode from are the graph of the pointSF that
DMPlexDistribute returns. I'm attaching a small test that can show the
problem. You can run with:
testPointSF -i TwoTri.gen
As always thank you for your help,
Ata
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/79b39a2d/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/79b39a2d/attachment-0001.cpp>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/79b39a2d/attachment-0001.obj>
