[petsc-users] Status of mkl_cpardiso configuration option?
Mon Apr 6 11:19:24 CDT 2015
If you use petsc development branch 'master' from git - you should be
able to use mkl cPardiso.
https://bitbucket.org/petsc/petsc/commits/d305a81be0fbb2fe8c02e3da7510a1143eafa263
Satish
On Mon, 6 Apr 2015, David Knezevic wrote:
> Hi all,
> I'm interested in trying out mkl_cpardiso with PETSc (since I gather that
> mkl_pardiso doesn't work with MPI, and mkl_cpardiso is included in MKL). I
> saw a thread on the petsc-users list about this from 2013 (subject:
> "mkl-cpardiso configuration"), so I was wondering what the status of this
> is?
> I see that there is a configuration option for mkl_pardiso (I tried this
> and it works well for me). But I gather that there is no configuration
> option for mkl_cpardiso at this stage, is that correct? Is this
> configuration option something that you're interested in adding? If so I'd
> be happy to help out if possible.
> Thanks,
> David
